Question about PfaFF Tiptronic 2030
Sewing machine repair
Under the bottom pressure plate got stuck when my needle goes down the part underneath will not move or rotate it is a pfaff 1170
  • kharpole Aug 31, 2008
    pfaff tiptronic 2030 "hits the bobbin" on the down stroke.
    Scholar:
  • 35 Answers
I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional repair guide written by an expert. You can learn how to repair different brands of sewing machine as well.
Posted on Sep 08, 2010
Pfaff 3.5 was working fine,suddenly thread is bunching/getting caught under plate.Thread goes around the bobbin ok,when gets near to needle gets stuck on hook on right side.Any idea how to fix please?
Just guessing. You might try :
Installing a brand new needle
tightening the top tension a bit
If it continues to be a problem, most likely the machine is out of time and requires adjustment. Search for sewing machine timing or take it for service.
Apr 24, 2017 | PfaFF Sewing Machines
Needle stays down, will not come up.
sounds like the machine froze up, machine needs to be serviced
Sep 25, 2015 | Singer 5400 Sew Mate 60-Stitch Sewing...
Pfaff Clasic 2025 and when I start to sew I get a stitch and then it just sets there. the needle just goes up and down in the same stitch and doesn't move forward.
check the feeder feet with out material under the presser foot see if they are up or down and moving or not . some I do know the feed feet are retractable .
May 06, 2015 | PfaFF Sewing Machines
I have a Pfaff 4.2 Quilt Expression. I am free motion quilting and the bobbin thread keeps hanging up. Any suggestions?
1. The top loading bobbin cases have small brackets to keep them from turning or moving up or down.
2. Adjust brackets with small screwdriver. Allow enough room for thread to flow through.
3. Rotate hand wheel both directions to make sure the bobbin case doesn't move around. Also, watch the thread to see if it is flowing across the top of the bobbin case.
4. You may need to slow down movement of your "free motion". Also, make sure you are using the right pressure foot.
Mar 20, 2015 | PfaFF Sewing Machines
Hi I have a pfaff industrial zig zag 428, the bobbin has stopped all rotation
bobbin case should be stationary, bobbin itself is rotated as thread unwound, check hook timing. Simply turn hand wheel towards you and watch needle go down, when it reaches lowest point turn it slowly until needle rises 3/16" or so. Hook should be behind needle and slightly above eye.
Feb 12, 2014 | PfaFF Sewing Machines
Needle stuck in the material while sewing a straight stitch.
See if you can release the bobbin from the case.
Dec 30, 2009 | PfaFF Sewing Machines
2020 rotary hook continuous one direction pfaff tiptronic 2020
You are absolutely correct - your machine doesn't come apart much because it is an electronic machine. There really are very few moving parts in modern sewing machines - and the electronics are better left to a technician who's been specifically trained.
It sounds as if your machine is no longer in time (needle rubbing the plate as it goes around if I'm understanding correctly). While not really a "major" repair, unfortunately with computerized/electronic machines, retiming your machine is something better left to an authorized Pfaff technician.
If the needle struck metal as you were stitching/basting, there may also be a rough spot/burr on the hook that your technician will be able to smooth off as well.
Hope this helps get you back up and running soon.
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Nov 23, 2008 | PfaFF Tiptronic 2030
Needle is hitting plate under the bobbin
ure needle is too long. They sell differant size needles
Nov 18, 2008 | Singer 7422
Sewing Machines Logo
347 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
