Question about Dishwashers
Frigidaire Ultra Quiet 111 - ground up dirt on dishes
Hi -
After I run the dishwasher, there are brown dirt particles on the surfaces of my dishes, especially on the top rack. You can see the dirt floating in the water on the tops of cups. I have cleaned the filter twice and changed dishwasher detergents. HELP!
Thanks
  • 1 more comment
  • theprinces Feb 15, 2008
    I have the same problem with y Maytag. I would LOVE a solution. I have tried different detergents, ran only hot water, cleaned dishwasher with vinegar, etc. HELP!
  • KS5757 Feb 21, 2009
    ditto for a maytag QS300
  • Anonymous Mar 11, 2009
    I have the same issue. There is a fine sandy dusting of dirt on my dishes, especially on the top rack after "washing".
Remove the bottom plate near the floor. You can then look in under the dishwasher machine. The feet are adjustable up/down with a wrench most of the time. The dishwasher machine should tilt slightly away from the over flow sensor. In this case, Frigidaire Ultra Quiet, the rear feet should be lowered, or the front feet raised. If you have a machine with the over flow sensor on the bottom, at the back, tilt your machine slightly forward. Use detergent that dissolves food proteins. Problem solved. If you care to reward me, put a small symbolic sum to paypal account carolehel@aol.com
Posted on Apr 28, 2011
Why do my frigidaire ultra quiet ii does not dry?
Good Afternoon Friend,
I understand your Frigidaire dishwasher, model# FDB1050REC, is not drying your dishes. I also see you want to know which part needs to be replaced. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose and determine what exactly is causing your appliance to not dry the dishes. Hope this is helpful.
-Best Regards-
WP
Jul 05, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
I have a frigidaire Ultra Quiet 111 and the soap dispenser will not latch. It will not close at all.
Hi Hulo - Sounds like the dispenser detergent drawer latch may possibly be damaged or broken. Consult a professional to accurately diagnosis the unit and assist with the repairs.
Feb 12, 2013 | Frigidaire 24 in. FDB750RCC Stainless...
There is food and grit stuck to my glasses. Where is this coming from? I am rinsing all the dishes before I put them in , so it must be in the dishwasher somewhere,
We used to have this problem with a Kenmore that had a built-in "garbage disposal"--it was a little blade that ground up larger food particles. Occasionally a cherry or olive pit would get inside and dull, chip or break the blade, and the symptom was food particles on the dishes. The solution was to replace the grinder.
Jul 26, 2011 | Frigidaire Professional Series 24 in....
I have a frigidaire ultra quiet 2 that is not cleaning the dishes. I think that the arms are not spinning. Can it be fixed?
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Feb 21, 2011 | Frigidaire Dishwashers
Hi - After I run the dishwasher, there are brown dirt particles on the surfaces of my dishes, especially on the top rack. You can see the dirt floating in the water on the tops of cups. I have cleaned...
your spray arms are blocked with food debris and not turning to check this put appliance on for a few mins and check position of spray arms i bet the top one isnt moving, the very end holes are particulary important as they drive the arms round under water pressure.
Nov 01, 2010 | Dishwashers
TOP RACK NOT CLEANING DISHES
Possible that the motor impeller has good particles in it, causing poor water pressure, which would be most evident on the top rack. You would have to remove the spray arm, then the filter, then the torx screws to get at impeller....unfortunately, that model of dishwasher isn't the greatest in the first place for washing, since it only has the one spray arm.
Apr 04, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Won't turn on. Frigidaire, precision wash, ultra quiet 1
I have the same issue and it occurred around the same time as your post. Do you think there is a conspiracy? :-)
Feb 28, 2010 | Frigidaire 24 in. FDB126RB Built-in...
My diswasher is leaving a grimy film on all the dishes after they are run through the cycle, I'm wondering if it is because the dishwasher itself needs a cleaning and if so how do I clean it its a...
Go to you local Supermarket and purcase a bottle of disjwasher cleaner is about 8 bucks a bottle in some cases you may need to use two bottles I would buy 2 but use just one if it works save the other one for a future occasion.Follow all directions on bottle..Make sure you use it in an empty dishwasher and turn hot water tap on closest to dishawsher to make sure it is filling with hot water...You will be quite surprised at how clean your first load of dishes will look after the cleaning
Jan 23, 2010 | Frigidaire Precision Select 24" Tall Tub...
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
Frigidaire ultra quiet I dishwasher
Sounds like the water may not be turned on to the dish washer.
The arm spins with water pressure
Oct 16, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
Dishwashers Logo
811 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
