Question about HP OfficeJet 4315 All-In-One InkJet Printer
HP 4315 Installation problems
Trying to install new HP 4315. Disk --when put into drive creates onscreen message :setup.exe application error????
  • 3 more comments
  • powells5 Feb 15, 2008
    cannot install
  • Anonymous Mar 07, 2008
    this is a compaq me 5000 an it will not download the printer dish
    it;s to old but it is a goog computer can i get some software free by download
    thanks my daught has wrote a book but can not print it out
    thanks again harold
  • Anonymous May 02, 2008
    Printing out Fax Report
  • chenn2012 May 08, 2008
    not acepting the disk
  • Anonymous Mar 19, 2014
    Trying to reload factory disks
Where do iget the update
Posted on Aug 14, 2008
Did you call hp might need updated software
Posted on Feb 09, 2008
Tip
Install Windows 7 or Windows Vista on a Pc Without DVD Media
For user who doesn’t want to waste a DVD disc to burn the ISO to physical media, and does not have WinPE (Windows PE) startup disc, here’s a workaround method to install Windows Vista and Windows 7 into physical computer’s hard disk drive or partition (volume) directly with ISO without writing or burning to disc. The without-disc installation method is useful especially during beta and RC period of new operating system in the making, where the new build and new versionis launching and publishing every now and then. This tutorial guide assumes that the new Windows 7 or Windows Vista will be installed and replaced the original existing operating system currently installed. The instructions can be modified slightly (mainly on hard disk partition used) to fit into need of readers who want to have a dual-boot, multi-boot, or simply just to upgrade install to new OS.
1. Install a virtual CD/DVD drive on existing Windows operating system.
2. Mount the Windows Vista or Windows 7 installation DVD ISO image using the virtual drive.
3. Copy all files inside the virtual CD/DVD drive mounted with the ISO into any folder on any partition or hard disk drive not going to be used to install the Windows OS. For example, copy into E:\Windows7.
4. Copy the bootmgr and boot folders nested inside the copied folder (i.e. \Windows7) to root directory of system boot drive, typically C:\.
Note: For Windows Vista, users may need to use this step: Copy the bootmgr folder from E:\Windows7 to C:\ root directory, copy E:\Windows7\boot\boot.sdi file to same folder in C:\boot folder, and then copy bootsect.exe from the E:\Windows7\boot\ folder to C:\ drive.
Note: boot folder in system boot drive is hidden system folder.
5. Create a new folder named sources under the C:\ root folder.
6. Copy the boot.win file inside \Windows7\sources folder to the source folder created in the system boot drive, normally C:\.
7. Open a command prompt as administrator.
8. Run the following command (change the C to your drive path letter if applicable):
C:\boot\bootsect.exe /nt60 C:
For Windows Vista users who copied bootsect.exe to C:\ root folder, use the following command instead:
C:\bootsect.exe /nt60 C:
A successful message is the command completes successfully.
9. Change the name or label of the boot system partition local disk to BDCP or any name you prefer that easier to remember and type (in DOS command promot, use label command).
10. Restart the computer.
11. After booting up, the system will start the corresponding Windows installation process. Select the applicable language to install, time and currency format (regional settings locale) and keyboard or input method in the installation wizard dialog.
12. On the next screen, user will be presented with option to Install Windows. DO NOT press on Install Windows button, instead, click on Repair My Computer link on the bottom left corner.
13. In the Windows Recovery Environment (WinRE) System Recovery Options dialog window, click on Command Prompt to open a DOS Prompt window.
14. Run the format command to format the primary hard disk or partition to clean state:
format c: /q
Note: /q switch, which perform quick format can be omitted to full format. And if existing hard disk partition is of FAT32 filesystem format, use format c: /q /fs:ntfs to convert the file system to NTFS while formatting. Before formatting begins, the command may prompt for hard disk drive or partition label name, if so, enter accordingly (i.e. BDCP).
15. After format completed, start the Windows Vista or Windows 7 installation process again by manually running the setup.exe located in the copied. Note that the setup.exe is not the one located on boot system drive which copied at later step, as the boot drive has been formatted. For example:
E:\Windows7\sources\setup.exe
16. Continue with installation procedures by following on-screen instructions as per normal practice.
on May 19, 2010 | Computers & Internet
I'm unable to install Mortal kombat 4 in Windows XP SP 2. As soon as I activated setup, it exits with the error Msg "Start Menu Error". Please help
I've been trying to solve the same problem. Here's a solution I discovered that worked for the same problem in Vista; it may work also for XP.
To install and play Mortal Kombat 4 in Vista:
Click setup.exe.
Choose installation folder (create it later).
Get error message.
Do not click "Clean up."
CTRL-SHIFT-ESC and kill setup.exe process.
Create installation folder (selected during setup).
Copy all files in DATA folder on CD to installation folder.
Rename MK4.exe to Mortal Kombat 4.exe.
Install patch (optional).
FIGHT!
Regards,
Amillennialist
Feb 01, 2009 | Midway Home Entertainment Mortal Kombat 4...
When installing the 6310 all in one printer, at a certain point I get the following message: "The application HPIO Trap Monitor quit unexpectedly. Mac OSX and other applications are not affected. Click...
There are two ways for install the Scanner using only "the driver" and using "HP Photosmart Studio Includes Support for Mac OS X v10.3, v10.4 and v10.5 (Leopard)" using the driver not include IRIS OCR software only the driver to scan and thats why say "An OCR error ocurred, couldn't create file". Installing the HP Photosmart Studio fix the problem.
If fixed the problem visit my page www.richardsite.com.mx
Jan 16, 2009 | HP Officejet 6310 All-In-One InkJet...
Old alchemy game will not install
Try this:
Right click on the D:/Poppack-setup.exe -> Properties = Compatability Tab.
There should be a box that says "Compatibility Mode" that you need to chek, and then select Win95 and hit OK.
Try installing again.
If it still gives the same error, go back to the tab and go lower than the Compatibility Mode box, to Display settings, and chek "Run in 256 colors" and "Disable Visual Themes"
Try again.
If it still wont work, please respond. If it gives a different error at any time or a different problem, please respond.
If it works, please rate. :)
Dec 12, 2008 | TalonSoft Video Game Consoles & Games
DVD/Cd Burner won't run programs.
All you need to do is that put the CD in the CD/DVD drive that you have access and not properly closed. For example here is the situation. I put a cd installer with a file named in the cd setup.exe and it is located in drive D: i access the file setup.exe and I run it or install.. then I decided not to install the programs.. what I did is that is did not cancel the installation but rather I immediately open my cd/dvd drive and get the cd..
What are going to happen? the installation is in the process and I did not cancel the installation properly. In the installation logs of the windows it still have to install the programs but it cannot find the file setup.exe that is located in the Drive D:.
Try to put a cd in your cd/dvd drive with file named setupexe on the cd.. that will solve your problems. TY
HOPE I CAN HELP
Dec 05, 2008 | Acer Aspireā„¢ T180 PC Desktop
Initialization failed
You can still try to make the game compatible for installing it on the Windows Vista by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply".
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
You can delete all the files copied from the CD after completing the installation
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
After the game is successfully installed right click on the game shortcut or the game "AOM.exe" in the root folder of the game and click and click on "Properties".
In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply". (You can also try with the other options also)
The same set of steps can be used for installation of older games installation on Windows Vista.
Nov 19, 2008 | Microsoft Age of Mythology for Windows
Let's Ride Corral Club will not run
To make the all the files of the game compatible to Windows Vista you need to install the game and then make changes to the game exe file.
Some game ".exe" file (executeable file) would let you make changes in the Compatibility option, whereas older games might not give that option at all.
9. After the game is installed go to the game directory and find the "LetsRide.exe" and click on "Properties" and repeat step no.7
There are lot of files that need to be changed in order to get full functionality and to communicate with operating system and the hardware, hence there is no guarantee that the game might run even in cases where you will successfully install an older version of the game with the above mentioned steps.
Nov 11, 2008 | ValuSoft Let's Ride: Corral Club for...
Install
This solution is not for the XBOX version of the game, this is only for the PC version of the game Bard's Tale.
You can still try to make the game compatible for installing it on the Windows XP 64 bit by following the steps below.
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP" and then click on "Apply".
The same set of Compatibility steps can be used for installation of older games installation on Windows XP 64 bit and Windows Vista.
Again, this solution is not for the XBOX version of the game.
Sep 06, 2008 | Vivendi Universal Bards Tale: Song of the...
Missing Operating System error
your bought compag computer is a new one , because that error is appears only if the hard drive or the harddisk is defective or damage. Your installation of windows xp is finished totally because sometimes the error is appears because the system installation is not finished and the os system cannot read. try to re install again the windows and delete the old partitions and create again if the problem is the same even there is no error in the installation until it's finished i say that the problem is in the harddisk. Maybe the harddisk develop a bad sector in the master boot record of the hardrive
Apr 15, 2008 | Compaq Presario 700 470024-192 Notebook
HP OfficeJet 4315 All-In-One InkJet Printer Logo
145 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
