Question about Targus Wireless Remote Presenter Mouse
Targus mouse remote
What type of battery, and red light stays on how do you change battery
    President:
  • 8,637 Answers
If the Red Light is on the batteries should be good enough to function. Try
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Posted on Jan 20, 2009
Targus Model PAWM002 optical mouse will not work. When I plug the stick in the red light comes on and I have replaced the batteries in the mouse. Turned the switch on the underside of the mouse on and the...
click start control panel administration tool computer managenent device manager scroll to mice and other pointing devices you might see a yellow question mark? right click to update drivers
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
(if applicable)
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps dont forget to vote
Feb 28, 2011 | Targus Wireless Mini Optical Mouse
I have Targu Laptop Remote Mouse #Pakp003, and I want to change batteries as it is not responding to my Kensington Usb adapter. How do I change batteries as havent used for 1 yr.
I discovered you had to push top of mouse near the rolling click, and then slide off cover towards the back of mouse. I earlier thought the battery access must have been on bottom of mouse.
Jan 27, 2010 | Targus (PAUM31U) Remote Mouse
Changed battery and still does not work - hear pinging in computer
There are buttons on the transmitter/receiver and the mouse(small red on bottom). Turn off the mouse. Plug in the USB Tx/Rx and hold down the button. Then press the red button on the mouse and hold for one second. Do this until the rapidly flashing light on the Tx/Rx slows down. The unit's frequencies are then encoded/decode and can communicate.
Jun 13, 2009 | Targus PAWM001U Mouse
Change batteries in a targus portable mouse
I found the user guide in French. It says to slide back the cover behind the Logo on top.
also found it in English:
Installing the Batteries
Optical Mouse
1 Remove the battery cover from the top of the mouse by
pressing the top center (over the Targus logo) and
sliding it back.
2 Insert the supplied batteries , making sure that the
positive (+) and negative (-) ends of each battery match
the polarity indicators inside the battery housing.
WARNINGS: When replacing the batteries, you may use
alkaline or other heavy-duty NiMH batteries. Never
combine an alkaline with a NiMH battery in a device.
Avoid mixing new and used batteries in a device.
3 Slide the battery cover back in to position until it “clicks”
firmly into place.
4 Turn on the mouse by sliding the on/off switch on the
bottom of the mouse to the “on” position.
The optical sensor, located on the bottom of the mouse,
glows red.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 07, 2009 | Targus PAWM001U Mouse
Targus amw15us not working
have you tried to change batteries? low battery will cause your mouse not to connect to the receiver.
Feb 04, 2009 | Targus Wireless Optical Notebook Mouse...
How to operate the targus mouse pawn001.
Try pressing both the red syncing button and the black reset button (on the base of the USB-connected charger( simultaneously.
Aug 22, 2008 | Targus PAWM001U Mouse
Targus Wireless Remote Presenter Mouse Logo
274 people viewed this question
Top Targus Computers & Internet Experts
dhnguyen
Josh Whitehead
Josh Whitehead
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
