Question about Kitchen Ranges
Kenmore elite 790.3670 oven door locked
The range made a buzzing sound and noticed that the clock reset to 12:00 AND immediately LOC came up on the display the oven door was locked. I pressed clear for 3sec and it continued locked and keeped try but with no luck. I removed the power for a few seconds, and minuted and hours and even over night to try to reset it bu nothing has worked. As i connect the power PF is displayed and and a blinking door lock, if i pull to try to open oven door dr is displayed and finally twice the code F93 has come up as well.
THANK YOU PLEASE HELP!
  • 9 more comments
  • id4edson Mar 05, 2008
    I have the same problem. Our Kenmore wall oven door is locked and I have tried different combinations on the keypad to no avail. I have switched power off overnight hoping for a complete reset and nothing. The model number is 911-4742991. Can you help?
  • Viretarmis Mar 10, 2008
    I put the burner on, heard a beep and looked at the control panel. The "lock" indicator was shining red and the overn door remains locked despite unplugging/resetting etc. HELP!
  • mesarat Apr 03, 2008
    I have a Kenmore 790.3670 and the oven door is locked and I can't get it open as well. Nothing seems to work. it's 3 weeks out of warranty! Sears is of no help.
  • Frank P Scot Jun 03, 2008
    My son put the stove onto clean by mistake (instead of broil). He closed the door because "door" was flashing on the display then realised he'd hit the wrong button so did a cancel.
    Door is now locked. Tried doing a short clean to trick it - but "door" flashes for 10 seconds, stove buzzes, it clicks out of clean mode and stays locked...
  • alanthony Jun 09, 2008
    Me to!! I have a 79095413203 I attempted the self clean button, the lock door button is lit, screen beeps will flash F9, can not get the beeping to shut off regardless of unpluging time ie. 1 week!!! I can open the door although it states it is locked!! Help!!!
  • nolens2 Jun 27, 2008
    Had the same problem, dicovered that if you press and hold clear for three seconds, it will still show as locked, but will allow you to open the door. It started to beep and became very annoying. So, what I discovered was that if you open the door, leave it open while pushing clear for three seconds again, it will reset and be back to normal. I was able to use the oven immediately with no problems.
  • Anonymous Jul 15, 2008
    I had the same problem. Thank you for the solution!
  • Panamadg Oct 05, 2008
    Same problem with Kenmore elite oven door lock. Could really use a solution.
  • Anonymous Dec 19, 2008
    I have tried holding the stop button for 3 sec, as suggested, but is not working for me. Any other suggestions?
  • Anonymous Feb 25, 2009
    same problem as above and i thought i could just phone sears and they told me that my warrenty is up and it will cost me a min of 80 for sevice call then any other parts nessasry i think that its a bunch of **** that theycan charge for a problem with thier defective equiptment!!!
  • linda collins Jan 23, 2013
    I have the same exact problem but F11 came up. This is frustrating
I held down the clear button for three seconds, it unlocked but still showed the lock button lit. It began beeping over and over. I opened the door and pressed the clear button again for three seconds. It stopped and the oven works just fine now. In fact, I used it right after I got it cleared out.
Posted on Jun 27, 2008
Had the same problem, I held the clear botton for 3 seconds and it allowed me to open the door. As the door was open, I held the clear button for three seconds until an error message came up. I quickly closed and opened again and it clear it up. Back to normal.
Hope this helps.
Posted on May 31, 2009
I had the same thing and with some sheer luck, I was able to open the door. Don't ask me how but I started pressing buttons. One of them was holding down on the STOP button. It will beep and flash "Door Locked" and the display will show LOC. I tried this a couple of times before even trying to open the door only to realize the door was unlocked. Hope this helps. After awhile, the beeps will go away and the door stays unlocked.
Posted on Jun 15, 2008
I held the "Stop" button down for 3 seconds: this unlocks the oven (give the latch a few seconds to release the door), but the lock icon is still displayed and the burners are still inoperable.....but the oven works!
Posted on Dec 25, 2009
  • ally5 Dec 25, 2009
    We just realize that the reason the Burners were not working, is because they were locked. To unlock the burners, hold down the "CLOCK" button for 3 sec. The lock icon stays lit until both are unlocked (Kenmore Elite c970).
There is a button sequence, my 2 yr old could find it, but we just unplug it and the computer resets. I;m not giving kenmore any more money for this exoensive oven.
Posted on Mar 15, 2009
We had the same problem and the company would not offer any solutions. Thanks to this site we pushed clear for 3 seconds and could open the door. When we tried to push clear again for 3 seconds so that the beeping would be cleared, an error message popped up. We started over and once the door was open, we closed and opened it quickly again, somehow fooling the door. We heard a click and the problem was solved.
Posted on Aug 17, 2008
Thank you all. I did as told and I can cook again. I had great pleasure cancelling my service appointment!
Posted on Feb 27, 2013
I did follow instruction about holding down CANCEL and lock icon gone, owen door did open and owen is fully functional again.
Thank you, Thank you !!!
Posted on Oct 02, 2011
This site rock!!!!!!!!
Trully saved me tons of time and money!!!
Posted on Sep 15, 2010
  • 2 more comments
  • pstoterau Oct 17, 2010
    The Kenmore Gas Range cost big money! Sears is aware of this problem and still continues to sell this product without informing the consumer! I'm very upset! I too am having this problem and I bought this oven after you all had this problem..,.However no one at the store said ANYTHING about this! I even asked if any customers have had ANY problems with this oven that I should know about.
    This was OBVIOUSLY a FRAUDULENT sale, as I know now! Please, lets get the word out as customers, and lets stop the big companies from screwing us!!!!!
  • billysmith Nov 28, 2010
    I have the same problems twice in 2 years, We are treated like a fool by Searsand Kenmore. First time, I phoned up Sears, fwait for the techician for 2 days. and he would not fix the problem, and I have to wait for one week for him to fix it. so I have to eat out for the whole week, now I have the same problem again, I am so upset and the clean button is a money making machine for Kenmore and Sears.
    I will not buy a Kenmore product and Sears again
  • mrfixit1970 Nov 29, 2010
    A Kenmore could be made by LG, GE, Whirlpool, etc. Sears doesn't make anything. They put a Kenmore label on someone elses stuff. FYI.
Nothing worked for me. When I tried holding clear for 3 seconds... the oven light flashes and ERR pops up in organge.
Posted on Aug 09, 2008
I ended up replacing the Circuit board ($185) and haven't had any problems since.
Posted on Jun 16, 2008
Whirlpool loc
From a google search the following is copied:
LOC is a control panel lock not a door lock, see below.
The Control Lock shuts down the control panel pads to prevent
unintended use of the ovens.
When the control is locked, only the CLOCK, TIMER SET and
TIMER OFF pads will function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Before locking, make sure the ovens,
Timer and Timed Cooking are off. Press and hold START/ENTER
until a single tone sounds and "Loc," a picture of a lock and
"START?" will appear on the oven display, about 5 seconds.
Repeat to unlock and remove "Loc" from display.
If the above does not work have you tried removing power from the uit for a few minutes to see if it will reset.
________________
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/499415-whirlpool-double-oven-shows-loc-display.html
Jan 26, 2018 | Ovens
CONTROL PANEL FOR OVEN NOT WORKING AT ALL
Hi - I understand that the burners work, however I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another question, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. Then a beep will sound and LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed, confirm that there isn't a wiring failure or a faulty element.
Oct 17, 2012 | Frigidaire FEF366 Electric Kitchen Range
Electrolux oven won't heat up at all
Hello Le'Cinda Rhone - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another question, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. Then a beep will sound and LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failure.
Sep 27, 2012 | Electrolux 30 Inch White 30" Electric...
How do you unlock a kenmore elite cooktop?
You can do this by:
Check the oven display to see whether the screen says "LOC." When "LOC" is displayed, the oven lock is activated and the door cannot be opened. You need to make sure it is locked so you do not mistakenly lock the door.
  • 2 Press and hold the "Stop" button on the oven control panel until "LOC" disappears from the display. Some oven models have a button marked "Oven Lock," which should be used instead of the "Stop" button.
  • Lock the oven again by pressing and holding the "Stop" or "Oven Lock" button until "LOC" appears in the display
  • Feb 03, 2011 | Kenmore Elite 44173 30 in. Electric...
    I was able to clear the locked door message, and get over working following steps above, but cannot get the lock mechanism to release, and therefore cannot close the door
    Check out these steps at the following link... http://www.geappliances.com/search/fast/infobase/10004586.htm
    Range - "LOC DOOR" flashes in the display
    If "LOC DOOR" is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
    Motorized Switch
      1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
      2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
      3. While you hold the door jamb switch in this position, complete the following steps.
      4. Press the Clean pad, wait 10 seconds.
      5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
      6. Wait 10 seconds for the display to clear.
      7. The door should unlock and there should not be a need for service.
    Manual Switch
      1. Press the Clean pad.
      2. Close the door.
      3. Slide the latch to lock the door.
      4. Hit the cancel button immediately.
      5. Unlock the door.
    Motorized Switch
    Manual Switch
      2. Close the door.
      5. Unlock the door.
    Nov 24, 2010 | GE Profile JTP18 Electric Single Oven
    DOOR ON KENMORE ELITE IN LOC POSITION AND CANNOT CLEAR
    unplug for 40 minutes and re-try.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Aug 08, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    Kenmore range
    Found the manual
    1) let oven cool
    2) unplugged, replugged, reset clock
    3) Held stop button for about 3 seconds to reset the oven door lock.
    Still not sure what caused it, but seemed to solve the problem.
    Jun 17, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
    Kenmore elite oven lock
    None of above worked for me. But, gave me a clue. I pressed the Stop/Clear button for apprx 10 sceonds. the "door locked" flashed for 5 seconds and then cleared and the door unlocked. Panel worked fine after that.
    Mar 10, 2008 | Tappan TGF320 Gas Kitchen Range
    Kenmore Elite Electric Range, Display stuck on LOC
    I pressed the lock icon on the panel and held it for a few seconds and the display cleared.
    Feb 03, 2008 | Kitchen Ranges
    Kenmore Elite Range door locked error message
    Hold down the number three button until the LOC message disappears and then the door will open.
    Dec 23, 2007 | Kitchen Ranges
    Kitchen Ranges Logo
    4,813 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
