Question about Video Cameras
Distorted crackling Sound Recording
My Camcorder now has a problem with recorded sound which is badly distorted and crackles. The unit is approx 18 months old and has had little use. Any idea what is wrong ?
Thanks
Mark
    Sergeant:
    Champion:
  • 209 Answers
Im guessing it's digital, if the distorted sound is heard when you replay it on the computer try exiting everything else when uploading videos.
Check if the "mic-hole" has any damage.
Thats all I got for now
Please reply with more info on the camcorder and such.
Good luck.
Posted on Feb 07, 2008
  • 4,102 Answers
Hi this is a fault alot of people have it usually starts to happen when you have been recording and then a loud noise has happened this then damages the mic on the camcorders.
The problem you might have is going to be getting a new mic fitted as alot of the newer camcorders they dont sell replacement parts unless its a top of the range one but if the parts are not available then their is no way of repairng it the bets thing to try is look in the phone book or online for a camera repair shop or even ring a camera shop up and ask them if their are parts available for your camcorder let me know if you need further assistance
Sigmac NE32AB1 Sound Distorted
Interference. Separate wiring in back, so there is no cross-talk of signals. If speakers are failing, go to walmart and buy a new set, <$20.00, hook up and sound is great.
Feb 13, 2014 | Sigmac NE32AB1 32" LCD HDTV
Dell xps 15 L501x sub woofer giving crackling sound
hi you can detached or disconnected the subwoofer cable, for temporary or permanent fix, as the speaker sound also produced good quality sound..
here how i disconected the subwoofer cable, it easy to find at the bootoom, see also utube video inside the link given below
http://atozcs.net/dell-xps-l501x-subwoofer-produce-distorted-crackle-sound/
Aug 09, 2013 | Dell Xps 15 L502x Subwoofer Speaker Pn57g
When i record videos with my easycap a crackling sound happens
Please check if the source audio output volume isn't too high and also if the audio input isn't set at max volume, these may cause that recorded audio get distorted, the solution is to set a lower volume to a normal level if this is the case.
Mar 02, 2011 | Televison & Video
Seem to have developed a problem with my audio recording and playback using Roland's FA-66 (Editrol). I use Cakewalk SONAR, Sony Sound Forge and Vegas Video softwares, and all of them show the same sound...
www.rolawww.scottyp-music.com/geardos/?p=21 nd.com/products/en/_support/dld.cfm?...FA-66
try these 2 sites, i believe they have some good info you need and will probably solve your issue. ive heard some horror stories about norton. unistall and see what comes about. it seems as though too many connections are going to screw this item up and norton will do the same.
Nov 15, 2009 | Edirol FA-66 Sound Card
Distorted sound on playback, samsung mini dv camcorder.
Try a DV tape cleaner first. If that doesn't work, see what it would take to get the audio heads realigned. Any camera store can do that for you.
Dec 18, 2008 | Samsung SC-D67 Mini DV Digital Camcorder
There is a crackling sound after I record.
The problem was the VIA chipset firewire card. I changed it with a Texas Instruments one. Works perfectly now.
Sep 04, 2008 | M-Audio Solo Audio External Sound System
Crackling when recording with saffire
Without much info to go on I would first make sure that your input levels are not set too high when recording causing clipping and digital distortion on playback. Usually this is the thing that causes crackling sounds. Rather hard to fix after the fact and you may have to rerecord those tracks to get a cleaner sound you are happy with.
Jan 03, 2008 | Focusrite Saffire LE FireWire Audio...
Recorded sound problem
It's possible that you were recording something too far away from the camcorder.
Sep 06, 2005 | RCA CC-432 Camcorder
Open Questions:
My Hitachi VM H710A plays just fine, and the picture looks fine. But when it playsback footage or records footage, five to ten seconds later, it stops abruptly, and flashes the word "TAPE". First thing I must add, is that I was using a prerecorded videotape, and was testing it from the beginning of the cassette and the middle of the cassette. I thought maybe the heads were dirty, and so I cleaned them using a cotton swab and rubbing alcohol. I cleaned the head drum with a piece of paper soaked with rubbing alcohol so that I wouldn't get any fibres in the heads. I waited for it to dry and then I put a cleaning cassette inside. To which, it still stopped abruptly five to ten seconds in during playback. I then decided to look at the manual of the camcorder and see the symptom. It says that due to temperature changes that it might cause this symptom. I placed it in a cool room and left it there all day and checked on it, and the camcorder is still doing the same thing as before hand. Then another cause said that it might sense some moisture. I made sure that the camcorder was dry externally and internally, and yet still, same problem. Thats when I decided to take it apart and look inside to see if there was anything odd inside the camcorder causing it to function the way it does. The belt seemed to be working fine, and there was no missing parts. The tracking poles and path alignment was fine, and not loose. Everything simply seemed just fine. So I am unsure as to why my camcorder is operating like this.
Sep 17, 2018 | Hitachi Video Cameras
Video Cameras Logo
240 people viewed this question
Top Video Cameras Experts
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
