Question about Toshiba TP55H60 55" Rear Projection Television
Tp5560h I fixed my convergence problem, but my red is not red enough. Is there an adjustment for that on the main controller?
  • eaglescout43 Feb 08, 2008
    Thank you very much!!! Have a nice day....
    Champion:
  • 206 Answers
Well let see if we can talk you thu "grayscaling " a set, first remove the speaker grill and the front cover to expose the screen/focus controls these will be six controls mounted on a plastic looking box, next turn the set on and get a good signal, Then from the custmer menu simpley go the the pix settings and turn the color all the way down, next use the screen controls to make the pix the best black and white you can. Next turn to a input that has no signal and the pix should be black, if there are small retrace lines simply turn down that color till it goes away , then back to a signal source that should still have a good black and white pix. Put everything back together and turn the color back up
Posted on Feb 07, 2008
Our tv looks like a 3d tv. Out of focus
Try to adjust the convergence using the original remote control of your tv, then go to the convergence setting menu, then go to convergence section. You should be able to move the blue and red in any directions right, left and up, down. Or if you cannot move them far enough the convergence chip is defective replacing the bad convergence chip will fix the problem. Feel free to send feed back good day and best regards.
Aug 21, 2011 | RCA Televison & Video
Convergence issue; red 3D effect. In grid convergence mode blue will converge w/green fixed lines and red horizontal will but the verticle red will not adjust far enough left to converge. has ajustment...
Convergence is dead.Must know how to solders?Must replaced ICS and all of it resistors.Tries Tv repair World.com,Tvrepairkits.com for a convergence kit.The shop will cost u $300 for parts and labors.
Jan 24, 2010 | Hitachi 43FDX01B TV
Iqc60h95w zenith=hitachi i can set up convergence but when i press swits on the main board to retorne the picture the convergence wont stay on memory.witch butons on the remote i have to press before press...
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jan 01, 2010 | Zenith IQC60H95W 60" Rear Projection...
Characters on picture look double and colors not lined up
HI, the convergence board or unit is failing at this point. you will need to replace the entire board in this case. most of the components are damaged.
The convergence board is the main regulator of the RGB stream. it also controls color focus as well. replace the convergence board asap.
Jul 22, 2009 | JVC AV-48WP30 48" Rear Projection...
Have colored shadows around everything on my Mitsubishi HDTV 1080
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jun 24, 2009 | Mitsubishi WS-55613 55" Rear Projection...
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
Convergence problem with TV Pojection Sony KDP65WS550
  • Screen looks 3D
Oct 08, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Red convergence wont move
if the red line is blurry and you have adjusted the screen focus control and does not work then you prob have a bad red CRT or bad red CRT fluid.........
convergence STK have nothing to do with the red being blurry
Dec 09, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Samsung 52" rear Projection TV Convergence Problem
Replace both STK392-040 convergence IC's with OEM or better
quality = I use Panasonic with great success. They are soldered
in and requires at least PCB removal or perhaps entire chassis.
Please post response if you need more help...................T
Sep 03, 2007 | Televison & Video
Hitachi 50" - 50GX30B
You will need to replace the convergence IC inside the TV set.
Aug 12, 2007 | Hitachi 50GX30B 50". Rear Projection...
Toshiba TP55H60 55" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
