Question about Roper 24 in. RUD4000M Built-in Dishwasher
Clogged Dishwasher How do I unclog the dishwasher? I have a pool of water in the bottom of it, ran the cycle several times and still it is clogged. I was given advice to add a cup of bleach, but it didn't work.
  • 1 more comment
  • kat195708 May 27, 2008
    when i started dishwasher heard the water then i quit now the bottom is full of water what do i do
  • mom4fun Dec 02, 2008
    Same issue.  The water won't drain and once last week the water and suds overflowed out of it.  Guess it may be time for a new one...
  • noodle82 Mar 27, 2009
    there is usually water left in bottom of dishwasher at the end of the cycle????
3 Suggested Answers
SOURCE: GE Profile dishwasher with ''SmartDispense'' technology is clogged
I had this problem myself and the purge solution listed above did not work for me. There was just so much gelled and hardened junk in the dispenser container, it would have forever to clean out. Additionally, I think it could have had the chance of damaging the pump. Here is what I did instead:
* Remove power to the dishwasher (via circuit breaker or pull plug under sink).
* Take all dishes and bottom rack out of the dishwasher.
* Close dishwasher door.
* Remove bottom 2 screwbolts with a rachet.
* Open dishwasher door.
* Put a small box that is big enough to hold the panel while the door is opened.
* Remove screws holding inner door to outside panel. Don't remove the screws heading into side of door itself. Also, there are 2 screws near the latch that you don't want to take out...just loosen them and you'll see they don't behave like the other screws.
* The panel will separate from the door, BUT there are 2 ribbon cables connecting them. Have someone hold onto the door...so it won't pull up hard on the ribbon cables.
* GENTLY pull back and forth (side to side) on the white ribbon cable on the door. It will come off with a connector.
* Use a small flathead screwdriver to gently press the tab in on the blue connector and gently pull the blue ribbon cable straight out.
* Remove panel completely and put aside.
* Gently close dishwasher door. It will want to fly up since it doesn't weigh as much.
* Look for a red/green cable from the detergent container (detergent level sensor) and disconnect it.
* Open dishwasher door and take off detergent cap.
* Have someone hold onto the detergent container from the other side and un-twist the detergent locking ring (the item you normally screw the cap into). You can use your hands or put a cloth over it and gently remove with channellock pliers. The detergent container will now be free, but connected to a rubber tube that leads to the detergent dispenser pump. It will easily disconnect by pulling the container away from the tube/pump. The container is now free!
* Shake the living hell out of the detergent container over a trashcan. Mine had tons of white and blue gel in it. Once you remove most of the gunk, bring it under the faucet in the sink and rinse with warm/hot water. Shake, rinse, empty, shake, rinse, empty. The hole where the detergent comes out should be 100% cleaned out. Use the handle of a small paintbrush (or something) to push the hardened gunk out of the hole. Be sure the container is totally cleaned. Take your time on this.
* Put everything back in reverse order. The only thing I did differently is putting the door panel back on the door: Close door, reattach container & cable, bring over panel and re-attach ribbon cables, hang panel on the top two white plastic blocks that you loosened the 2 screws by the latch with earlier. Then screw on the bottom 2 door screws (do not tighten until all screws are put back in place). Put all screws back...don't overtighten.
* Re-apply power and you should see the 'Add detergent' light come on. That's a good sign!!!
* Put in fresh detergent and you should be good to go.
* Lesson learned: DON'T mix enzyme and bleach based detergent ever again!
This was easier than I thought it was going to be...and didn't waste electricity, water, or time based on the purging method. After all, if it is clogged, you can't purge it. Enjoy!
Posted on Jun 19, 2009
heatman101
  • 43501 Answers
SOURCE: dishwasher did not drain all the water
The house drain is clogged...
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 29, 2010
My dishwasher says DE and does not empty the water after the wash cycle ????
Most commonly, this is due to as clogged dishwasher drain hose. If you have had agarbage disposal installed, it can also be due to the dishwasher plug not having been removed from the disposal. This can be done with a screwdriver (just make sure to remove the plastic plug from the disposal). These will most commonly run from underneath your dishwasher to your garbage disposal (or to a drain pipe under sink). Many times they can be unclogged by removing the hose from under the sink and using a wet/dry vacuum (with the filter removed, so it can suck up wet stuff) to auction the end of the hose. If the hose is not clogged, the vacuum will suck the water through the hose and our if the dishwasher. If it is clogged, hopefully, the vacuum will suck pour the clog, and then suck the water from the sink.
Hope this helps
Oct 31, 2013 | Whirlpool ADG450 Slim-Line Built-in...
Our dishwasher won't drain completely. I ran it through a regular cycle but it was left with water in the bottom.
Have you tried canceling the cycle? To cancel, turn the on/off switch to on, then press and hold for three seconds the two buttons labeled "Cancel Drain". Keep the door closed for the next minute so that the dishwasher can complete the cycle. During this time the pump will remove any water from the washer. Also you will notice that Bosch dishwashers always leave a little water in the system to keep the seals from drying out and going bad.
Hope this helps
Jan 20, 2013 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Our sink and garbage disposal was clogged up. We got the sink unclogged, but the dishwasher had dirty water in the bottom and won't drain.
Your dishwasher drains into the garbage disposal. It you tried to use a plunger to clear your clogged sink or run the disposal with to much junk in it you may have force debris into the dishwasher drain hose. With both the dishwasher and garbage disposal disconnect from power disconnect the dishwasher drain hose from the garbage disposal. This is usually about a one inch black hose. Clear out any debris in the hose and inlet nipple on the garbage disposal. If debris is compacted far down the hose it will need to be disconnected from the dishwasher end and remove to clear the blockage.
Steve
Feb 10, 2012 | Asko 1385 Dishwasher
Hello the bottom of my dishwasher keeps filling up with water. How can i fix that??
The problem may be in one of several places, here's a list of things to try, starting with the easiest and progressing to more difficult:
1. Run your hand around the bottom of the pool in the dishwasher looking for paper or cellophane that may be covering the screen of the drain. 2. Disconnect the drain hose from under the sink (get a bucket and rags) looking for a clog at that point of connection. Run the dishwasher drain cycle while you have this hose pointed into a bucket - if nothing comes out, the problem is between points 1 and 2. 3. Partially remove the dishwasher so you can get to the drain hose where it connects to the dishwasher. Temporarily put another drain hose on it, with the other end in a bucket. Run the drain cycle of the dishwasher. If it comes gushing out, the drain hose is clogged. If it still won't drain, your will need some disassembly of the drain & pump. good luck, Al K
Dec 21, 2010 | Mx Commercial Line Drano Max Clog Remover
Bosch dishwasher shx55m with bottom tub full of water
The dishwasher really shouldn't pass any particles near large enough to clog the drain hose. It sounds more like a mechanical issue. Check the circuit breaker to make sure it's not tripped. See if you can hit a cancel button or something to make it drain. Try to run another cycle. If the computer is stuck or acting funny, trying cutting the power for a while, holding down a stop/reset/cancel button, or running a cycle that you don't usually run. I had this kitchenaid that would randomly refuse the normal wash cycle, but would run fine when you ran rinse only or something, then regular wash and everything would be fine again too. If the line somehow is clogged, there's a good chance it's right where the hose connects to the disposal or drain pipe.
Feb 18, 2010 | Bosch Integra® 500 SHX55M05UC Built-in...
Water in bottom of dishwasher, can't get it to drain
pull your water drain line out and place in a bucket on the floor. then try to drain it again. alot of time the hose get an air gap or blocked with gunk.
Feb 16, 2009 | General Electric Adora GHDA670N Built-in...
Water pooling up in bottom of dishwasher
is there any way to run the cycle from the beginning and listen to hear if the machine is draining at all when the cycle starts do you hear the water spraying on the inside ? if not then you have several different possibilities....clogged drain line, pump impeller broken(sounds like running but no action), water just flowing back to washer the last one's an easy fix just loop the excess drain hose up like a reverse "p" trap on a kitchen sink drain this keeps the water from flowing back to the machine
Dec 15, 2008 | Whirlpool Dishwashers
My dishwasher won't drain
It is possible that it ran thru the entire cycle but was unable to drain teh waste water ( usually the result of a clogged filter screen in the bottom of your dishwasher).. I suggest you either hand bail the water out and look for the drain filter screen or check where the drain hose is hooked up under your sink and possibly into the side of a garbage disposal..That could be clogged up too... Hope that helps...
Aug 27, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwasher did not drain all the water
Your sink drain is clogged and the back pressure is not allowing the dishwasher to drain competely. Do not use a liquide drain cleaner, it will damage your disposal. take apart p-trap hopefully the clog is there, otherwise the line will need to be snaked.
Sep 22, 2007 | Roper 24 in. RUD4000M Built-in Dishwasher
Dishwashers Logo
206 people viewed this question
Top Roper Dishwashers Experts
Mike
paul
paul
Adzhall
Are you a Roper Dishwasher Expert? Answer questions, earn points and help others
