Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
How to reset a Samsung SP46L5HX
I replaced my projector lamp (with the correct one) on my rear projection Television.
When I powered it on, the "lamp" green light comes on the front, flashes 3 times and then stays on, then flashes again soon after. It's definatelt installed correctly as i have checked everything.
Am I supposed to reset the TV? Is the a menu I can enter to reset the TV?
Thank you
    President:
  • 4,402 Answers
With set off...mute + 1 + 8 + 2 + power.
Arrow down to "Options" push enter.
Lamp reset and lamp hours should be in there.
Power off 2 minutes or until fan kicks off to exit.
Posted on Feb 07, 2008
The tv comes on but no sound or picture
Your rear projection lamp is defective you need to reset the program when your replace the lamp because you already reach the hrs use of the projector. Or the connector on the lamp lose.
Sep 24, 2011 | RCA D52W19 52" Rear Projection Television
After a loud pop, TV made loud noise and kept trying to "reboot." We replaced the color wheel (shattered) and projector lamp (which had a crack). When I turn it on now the Lamp light blinks.
I would say the next thing to replace would be the ballast for the lamp and if that does not work the power supply board may have failed. When I replace the power supply, I also replace the ballast at the same time.
Jun 01, 2011 | Samsung HL-R4667W Rear Projection...
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    I have the Samsung HLN5065W DLP television, and if I press the power button the TV will act like it is going to power on but won't. The lamp light will blink but I never get a picture. It seems like it...
    It seems tv needs lamp replacement, please check lamp in tv and if lamp has not been replaced in last 2-3 years or lamp is broken, replace it to solve tv problem.
    Thanks.
    Jan 22, 2011 | Samsung HLN5065W 50" Rear Projection...
    How much does a new lamp for a samsung tv sp46l5hx cost
    Hi the lamp do you need is a BP96-00271C and I recommend for you to get the Phillips that will give you 6000 to 8000 lamp hours, I found your lam p at the links below please check them out
    http://www.discount-merchant.com/BP96-00271C-Bulb-p/samsung-bp96-00271c-lamp.htm?click=52978
    or also on Ebay
    http://shop.ebay.com/i.html?_nkw=BP96-00271C&_sacat=0&_trksid=p3286.m270.l1313&_odkw=BP9600271C&_osacat=0
    Good luck
    Please rate this if it was helpful,as I do this for free
    Regards
    Jan 06, 2010 | Samsung HCN4226W 42" Rear Projection...
    Demagnetize a Samsung SP46L5HX
    This tv been hits or drop before?Tries move the tv around West,East,North so on help.Unplug replug for the dequaging coil inside to work.
    Nov 22, 2009 | Samsung HCN4226W 42" Rear Projection...
    Green projection lamp not working
    1. you will need a manual screwdriver to remove the panel. You need a soft non-abrasive cloth to avoid any contact with your fingers and the lamp assembly.
    2. Turn off the Projector. After the unit has cooled down properly, remove the power cord from the outlet..
    3. Remove Lamp Compartment Door. The lamp compartment on projectors islocated underneath the projector unit. For Rear Projection TVs, the lamp compartment is located in the rear bottom left or right side of the TV.. Remove the screws and the lamp compartment door.
    4. Remove Lamp Assembly. pull out the lamp assembly disconnect any power cords that is still connected to the lamp assembly. Put it aside and don't get it confused with your new lamp!
    5. Clean Lamp Compartment. Dust gets everywhere and while you have the projector open, use a soft cloth to remove any loose dust from the lamp compartment.
    6. Insert New Lamp Assembly. reconnect any power cables to the new lamp if present and slide the new lamp into the compartment in the same orientation that the original lamp came out.
    7. Replace Lamp Compartment Door. Set the lamp compartment door back into place and securely screw in the door without screwing it in too tight
    Nov 03, 2009 | RCA P52939 52" Rear Projection Television
    3 flashing lights
    the 3 blinking LEDs mean the lamp may be defective. Be sure the lamp is making contact with the sockets within the lamp compartment, also make sure the lamp is the correct one for your model. The set can be reset by unpluggimg the power cord for 5 minutes then plug it back in, if the 3 LEDs still blink check the lamp if its making contact and its the correct lamp for your model, suspect the ballast
    May 25, 2009 | Samsung HLP6163W 61" Rear Projection...
    51 magnavox projection tv-color mixing wrong
    The are controls on the inside of the tv above the circuit boards for focus and to turn up intensity of the projector lamps (red, green, and blu). If you turn it up too far all three projector lamps kick off. If this happens, power off the set and turn down the lamp that you turned up. Power it back on and slowly turn the projector lamp up until the picture looks OK. You have to take off the panel on back of set to get to the controls.
    Nov 19, 2007 | Philips Magnavox 51MP392H Rear Projection...
    Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
    1,360 people viewed this question
    Henry  Thomas
    Henry Thomas
