'89 Nissan Pulsar won't start
Parked the car in the driveway Tuesday evening. Got in to start today (Thursday) and it will not start. The engine turns over just fine and no weak battery. Any suggestions?
  • 99 Answers
It could be any of two problems. First did you check to see if you have gas going to the injectors, and second did you check for spark at your plugs. After you have done this get back to me and i will advise.
Posted on Feb 09, 2008
Immobiliser does not work - engine immoblised. Rest of electrics operate normally.
WHEN U SAY WNT START DO U MEAN CRANK OR JUST TURNS OVER WITHOUT RUNNING.. IF IT TURNS OVER AND DOES NOT START IM ASSUMING U CHECKED FUEL PRESSURE. IF SO CHECK UNDER DASH memory fuse. also check ignition fuse
Mar 24, 2014 | 1990 Nissan Pulsar
89 Nissan Pulsar Cranks but won't START!
id look into injectors and maybe also look into fuel pressure regulator or just fuel pressure in general
Dec 05, 2012 | 1989 Nissan Pulsar
1991 eagle talon will crank, but won't start up. 2 days ago I was driving home from work when i turned around in a parking lot and went to my parents house. about a half an hour there i needed to move...
That sounds like the fuel pump may have lost it's prime. Does it have fuel injection, or a carburetor on the engine? How much gas was in the tank while it was parked on an incline? Have you tried any starting fluid sprayed into the air intake hose, toward the engine? Warning! Don't use much starting fluid! Perhaps a one or two second burst, and have someone crank it immediately after you have stepped back at least 6 feet from the engine. If it fires, then it is definitely a fuel delivery problem! But it won't run long like that unless the fuel pump starts working again ... which is most likely when the engine is cold!
Apr 19, 2017 | 1991 Eagle Talon
Nissan pulsar '88. replaced starter motor, then
Is it a manual, or an automatic? Earlier Nissans sometimes have a problem with the neutral safety switch (a device that keeps the engine from rolling over in gear or without the clutch depressed.) Generally, if their bad, they need to be a little warm before they'll start, like setting in the sunlight for a few hours.
Good Luck!
May 22, 2010 | 1988 Nissan Pulsar
My nissan pulsar 89 model won't start turns over fine but just won't start
There are only two problems but many solutions. Check if there is fire to the plugs. If there is fire check if there is gas going to the cylinder. Once you determine which of these you can address the specific problem.
May 16, 2010 | 1989 Nissan Pulsar
Car will not turn over not a single sound from starter
is the security light flashing or on,,u mite have to turn ignition on (but not all the way to start) leave on for 15 minuets,,then turn off,,then try to start,,if the security system is on,,,,it will not start,, hoped it helped,,
Apr 24, 2010 | 2003 Pontiac Grand Am
Check engine light
Must have codes extracted to determine what set light.
Apr 03, 2009 | 1994 Mercedes-Benz C-Class
HELP!!!!Have a 1995 sl1 saturn. had starting issues...it wouldn't. so I bought a new battery. Started great all day tuesday and wednesday. Went to go to work today..thursday. Won't start. Tried to pop the...
Have you had your alternator checked? If batt. and alt. check out ok, then I would check to see if it is getting fire when it won't start and have the fuel pressure checked.
Feb 19, 2009 | 1993 Saturn SL2
Computers & Internet Logo
104 people viewed this question
David Payne
David Payne
