Question about Palm Treo 600 Handheld
Palm treo 600, hangs while picking up calls and wireless mode goes off, deleting all data
  • 1 more comment
  • veerepunjab Feb 08, 2008
    even after doing this harder reset with backspace,k and reset button, problem is still same.
    call comes, i try to pick iy up with centre button or touch screen , phone hangs then wireless mode goes off and all data goes off.
    it was working fine, i m getting this problem since i used internet on it.
    can any body help please
    even ethen it did not work after this hard reset as suggested by Frosty555
  • Anonymous Dec 10, 2008
    I have tried all these (hard reset) number of times, but the problem remains as it is. Is this battery related problem ?
    Novelist:
  • 171 Answers
Perform a hard reset, and clear the data off the treo.
Hold down backspace and the K key. While holding both of those down, hit the reset button on the back. Hold all for a few seconds. The screen will flash white and then turn off.
Then plug it into the charger cable. It'll turn back on and get you to put in all the settings again.
Then it will work correctly.
Posted on Feb 08, 2008
Wireless mode of my treo 600 constantly off
have you tried to hard reset the unit - backup your personal data before you do
Sep 01, 2009 | Palm Treo 600 Handheld
Deleting calls in call log
Yes you can. When viewing call log, press Menu button. Then scrool down to Delete Item and confirm when asked.
Works for my Treo 600
Mario Martins
Sep 06, 2008 | Palm Treo 600 Handheld
My palm treo 600 has a serious issue.
Ok this problem is very common in 600`s i have good and bad news
first go to the phone application and phone info
see what hardware u have A B C
A&B are toast and nothing can correct the problem
if your in hardware C your in good luck
bad news my first treo had this same exact problem and i had to replace it:( BUT BUT BUT!! it was caused by a 3rd party program that messed would auto reset my treo everytime it came on unfourntely uninstalling it didnt work and the wireless mode never came on..
got my second treo and had the same problem but i did not hot sync and intsted beamed using infared all my data and the problem never occured but sometimes
Aug 10, 2008 | Palm Treo 600 Handheld
Palm treo 600
Sorry, but this is not my area of expertise. Please try consulting another expert. I do apologize.
And oh yes, please do not rate this solution, as I haven't really posted any!
Thanks.
May 11, 2008 | Palm Treo 600 Handheld
"not enough power to activate wireless mode" problem for treo 600
call to your wireless provider and they will help you turn it on
Apr 03, 2008 | Palm Treo 600 Handheld
Microphone or some problem with Ring & Voice
Go to Palms support site and follow the directions for Hard Rest on your unit. ENSURE you follow the directions on backing up your data as this erases EVERYTHING on the unit!
After doing the hard reset, see if the issue is still present. If not, begin adding your thrid-party applications back one by one until the problem presents itself. Once you discover the app causing the issue you need to remove it and get with the developer of that app to remedy the issue.
If this does not fix the issue, the phone may need to be sent to Palm for repair. Or, if you carry insurance on the unit, you may be able to go that route for a replacement.
Nov 11, 2007 | Palm Treo 600 Handheld
Phone hangs when connected to charger
Sounds like a problem with the battery. Is it a problem to make a telephone call and do you have a humming noise?(gsm sound)?
Jan 03, 2007 | Palm Treo 600 Handheld
Deletinjg contacts.
I suggest you hard reset the Treo 600 to remove all former data and the username associated with the phone. Press the power button next tot he antenna and perform a soft reset at the same time. Dont let go of the power button until the Palm Logo appears. Then you will see a message asking if you want to delete all data. Removing portions of the old data is not an easy task.
Sep 12, 2005 | Palm Treo 600 Handheld
BIG PROBLEM: After hotsynch Palm resets over and over
You need to hold the "up arrow" while resetting, this will allow you to delete all info. That may not be what you want to do, if so, the only other option you really have is to do a soft reset, which is holding the up arrow and selecting "don't delete data". If the delete all data is STILL hanging after a hard reset, you can do a battery reset, which drains the battery, erases all data and goes back to "factory settings" There are two methods for this: While holding down the J & L keys, click the reset button on the back and hold it for 4 seconds. Or While holding down the K & backspace keys, click the reset button on the back and hold it for 4 seconds. Google "treo 600 battery reset" for more details
Can you change from Palm to Outlook on your Treo 600
Simplest method for 'switchers': Assume that your Treo 600 has the data you need (it does but you are focusing on your Palm Desktop in your question). Install the Palm Desktop software again using the CD but this time, choose the option to synchronize with Outlook during the installation process. This will switch the synchronization to Treo <-> Outlook instalead of Treo<->Palm Desktop. Assuming your Treo is recently synched with Palm Desktop, this will merge the data you have in the Treo with that of your Outlook profile.
Sep 11, 2005 | Palm Treo 600 Handheld
Palm Treo 600 Handheld Logo
188 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
