1. Pop off the triangular piece that is just cosmetic on the upper flat part of the mirror where it is attached to the van.
2. Under this piece are two visible bolts which you will need a Torx driver to remove.
3. Open the passenger door all the way open and remove the 3rd bolt, which is exposed from the outside of the car.
4. Expose the wiring harness plug by doing the following:
a. Pull off the door weatherstripping along the top of the door and on
the pillar (the part of the car to the left of the windshield) Do not
completely remove the weatherstip - simply pull it away enough to
execute the next step.
b. Remove the plastic pillar cover: it simply snaps in. Pull hard and it will pop off
c. Lift up the plastic cover over the speaker on top of the dashboard.
This piece goes all the way across the dashboard. Simply lift it up
enough to get your hands underneath it. There is no need to free it
from the passenger side.
d. Follow the mirror wiring harness around the rear of the speaker (the
side nearest the engine) and unplug it from the female connector at the
right-rear of the speaker. There may be a wire clip at the left-rear of
the speaker that you will need to get the wire out of.
5. Unplug the wire, remove the mirror, replace the mirror, reinstall everything
hope its work
