Question about Maytag Neptune MAH5500B Front Load Washer
NEPTUNE WASHER MY NEPTUNE WASHER IS NOT DISPENSING THE BLEACH AND FABRIC SOFTNER PROPERLY. THE SOFTNER IS LEFT IN THE HOLDER AND NOT DISPENSED. I CLEANED THE DISPENSER IN CASE IT WAS CLOGGED. IT DID NOT HELP.
  • 3 more comments
  • whitetigerz Feb 16, 2008
    My softener will not dispense either after cleaning lines, hopefully it isn't just because I have hard well water! Can't wait for an answer..otherwise does anyone know how to make washer stop before the rinse cycle so I can add softener manually(as standing & waiting is Not my forté)!!
    Thanks. Danielle
  • Anonymous Feb 23, 2008
    Hi, Our problem is similar with the fabric softener not incorporating, however the cycle always stops around the 1 where the rinse cylce is supposed to start. I have checked the hoses and they are fine. Replaced the pump so that is fine. Not a problem with the wax motor. Any ideas?
  • Riqq Mar 14, 2008
    Yep, same deal.
  • elm29 Mar 23, 2009
    I have the same problem, were you able to figure out what was causing it? I already have to fix the door latching lock engageing problem. If you have a solution let me know please. thanks
  • Anonymous Mar 13, 2014
    WASHER NOT DISPENSING FABRIC SOFTNER INTHE GE FRON TLOAD WASHER
My washer had the same problem, first not dispensing bleach or softner and then it began stopping altogether several times during the wash cycle. One we removed the water hoses and thoroughly cleaned them out, the problem was solved-apparently not enough water was flowing and the washer couldn't cycle properly. Good luck.
Posted on Feb 18, 2008
    Sniper:
  • 65 Answers
"downy ball" is designed to open at the end of first spin that is the way to go without stopping machine. works very well and costs just a few dollars
I have a Lady Kenmore Ultra Fabric Care Heavy Duty 90 series model # 1108281120. The drain for the fabric softner and bleach do not fill up and if you put the softer in it just drains out in the wash....
take out the draw where you fill the fluid to you will find that the fluid has built up into paste and is not letting the small valve to close properly happy cleaning eric
Dec 21, 2017 | Kenmore Washing Machines
Soap, bleach, softner dispenser not working
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Dec 28, 2010 | Frigidaire ATF6000ES Front Load Washer
Fabric softner isnt being dispensed into the wash...
YOU HAVE TO YAKE OUT WHERE U PUT IN THE FABRIC SOFTNER AND CLEAN OUT THE WHOLES WERE IT COMES OUT
Dec 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Bleach will not dispense
Here is a tip that I wrote about the problem I found with my fridgidaire not dispensing fabric softner. Hopefully this will help you out...
http://www.fixya.com/support/r5660917-fridgidaire_washing_machine_fabric
heatman101
Aug 20, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have a frontload. The bleach is not dispensing. I have taken it apart and cleaned it but that did not seem to help. I do not use fabric softner so not sure if that side works
i have a maytag neptune 6500. we have tried both the bleach and the fabric softner. neither work. we've tried selecting every option on the machine, cleaning it, using hot water instead of warm; nothing is working.
i packed up the manual in the process of moving so i can't get to it right now. i'm surprised there's no solution yet online!
sorry this isn't a solution, but more problems.
Jun 25, 2010 | Maytag Neptune MAH6500A Front Load Washer
Maytag MAH8700AWW will not dispense fabric softener
u need to replace the water valve theres 2 the cold is what u would replace
May 21, 2009 | Maytag MAH8700AWM Neptune Front Load...
FABRIC SOFTNER DOES NOT DISPENCE
Check to make sure the litle cups are set in place correctly and also make sure they are not blocked with hard fabric softner. A quick test: pour water directly into the fabric sofnter cup and fill it up,IF it siphons out, you will need a new inlet valve for that unit. The inlet valve has soliniods on it for the bleach & fabric softner.
Good Luck!
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Fabric Softener & bleach dispensing
The control board program has many sensors built into the unit to determine when to dispense the bleach and the softener.  LG tech documents doesn't list when these liquids are dispensed so there must be a program that matches the current operation and loads of each wash program.  That's the best answer I can give you at this time.
Jun 05, 2008 | LG WM2688H Front Load Washer
Bleach and fabric softner containers do not dispense
I have the exact same problem. However the bleach dispenser has ruined colored clothes by dispensing leftover bleach from the previous white wash on colored clothes. i have had many parts replaced to no avail. Maytag has just agreed to buy back the washer for the full purchase price and replace it with a Maytag or Whirlpool product of my choice. I hope I have better kuck this time.
Feb 21, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
437 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
