Question about D-Link DFL-800 Firewall
I have tried to setup the firewal to accept access for port 80
I have tried almost everything with this firewall, I just can't get the firewall to accept trafic on port 80.
I have set up the server int the Address book and I have published the IP on the Wan Port and I have set up the rules with SAT and Allow. I have followed the instrucktions completely and still the firewall will not accept trafic on port 80
any sugestions?
Mats
Some ISP's block port 80, the problem is not the firewall, following the procedure as described on d-link website should do it. If the problem is really the ISP, you have two choices:
Switching to a plan that allows you to use port 80.
Use port 8080, as alternate web port. The disadvantage is that acess will require http://ipadress:8080
Posted on Nov 20, 2008
I bought a D-link TM-g5240 . The wizard setup doesnt work. error:Your ethernet connection could not be verified. It says disanle firewal. I did disable everything, antivirus and firewal. Same...
Are you trying to connect to this router wirelessly or with an ethernet cable? If you are already using an ethernet cable, try using a different cable in case the first cable is damaged.
May 05, 2011 | Computers & Internet
Netgear firewall is blocking my email access. How do I fix?
It depends how you are accessing your email. If you are using a web based email such as gmail, I am guessing that a firewall is not your problem. If you are using an application such as Thunderbird and accessing a pop account, you may need to open up some ports in the firewall. Here are some common port numbers for email.
    POP3 - port 110
    IMAP - port 143
    SMTP - port 25
    HTTP - port 80
    Secure SMTP (SSMTP) - port 465
    Secure IMAP (IMAP4-SSL) - port 585
    IMAP4 over SSL (IMAPS) - port 993
    Secure POP3 (SSL-POP) - port 995
Mar 01, 2011 | NetGear WGR614 Wireless Router
I have a cisco RV120W small business router. I am trying to access a server on the LAN from an external public IP. I have created a firewall rule but have not been successful in getting it to work. I can...
Well, you will need to do two things, make sure your ACL's are set up right and you will need an ip route statement, such as this:
ip nat inside source static tcp 192.168.1.15 80 1.2.3.4 80 extendable
In this example, any traffic from outside coming into IP 1.2.3.4 on port 80 will be forwarded to a server on 192.168.1.15 port 80.
Feb 23, 2011 | Cisco RV120W WIRELESSN VPN FIREWALL Router
I have a zyxel p600 series modem connected to a Belkin wireless router. I am trying to run a web server on port 80. The modem was using port 80 for access to the internal settings. I changed that to...
Your setup looks correct to me. It might very well be that your ISP is blocking port 80. Go here and check from your server if port 80 is accessible.
If you are the only one that wants to connect to you server, you can simply choose another port to use, i.e. www.myserver.com:801. Set port forwarding form port 80 to 801 in your router.
TCP&UDP - from 801 - to 80 - [serverIP] - [Webserver]
The better way is to use a service like DynDNS.com or No-IP.com. You can register a DNS name (like myserver.dyn.com), which redirects to your public IP. The trick is to update your IP address, so even if you have a dynamic IP assigned from your ISP, the redirect will point always to your server. Most routers have the ability to set up with DynDNS, so the process runs in the background and you don't have to update manually - check your router manual.
The second part of this beauty is the redirect to a different port. So even if your port 80 (and 25 for that matter) are blocked, you don't have to have an arbitrary number in your URL (http;//myserver.com:801). You can find more detailed information here.
For a quick check, change your webserver to run on port 801, enter the redirect in your router and see if you can get to your server from the outside (internet). If you still can't access the webserver, the problem is not a blocked port.
Hope this helps, but if you have any more questions, just come back here and leave a comment - I'm happy to help you figuring this out.
Oct 23, 2009 | Computers & Internet
LINUX SQUID SERVER IN TRANSPARENT MODE
Dear Friend....
The examples below are based on the discussion of Linux iptables in Chapter 14, "Linux Firewalls Using iptables". Additional commands may be necessary for you particular network topology.
In both cases below, the firewall is connected to the Internet on interface eth0 and to the home network on interface eth1. The firewall is also the default gateway for the home network and handles network address translation on all the network's traffic to the Internet.
Only the Squid server has access to the Internet on port 80 (HTTP), because all HTTP traffic, except that coming from the Squid server, is redirected.
If the Squid server and firewall are the same server, all HTTP traffic from the home network is redirected to the firewall itself on the Squid port of 3128 and then only the firewall itself is allowed to access the Internet on port 80.
iptables -t nat -A PREROUTING -i eth1 -p tcp --dport 80 \
-j REDIRECT --to-port 3128
iptables -A INPUT -j ACCEPT -m state \
--state NEW,ESTABLISHED,RELATED -i eth1 -p tcp \
--dport 3128
iptables -A OUTPUT -j ACCEPT -m state \
--state NEW,ESTABLISHED,RELATED -o eth0 -p tcp \
--dport 80
--state ESTABLISHED,RELATED -i eth0 -p tcp \
--sport 80
--state ESTABLISHED,RELATED -o eth1 -p tcp \
--sport 80
Note: This example is specific to HTTP traffic. You won't be able to adapt this example to support HTTPS web browsing on TCP port 443, as that protocol specifically doesn't allow the insertion of a "man in the middle" server for security purposes. One solution is to add IP masquerading statements for port 443, or any other important traffic, immediately after the code snippet. This will allow non HTTP traffic to access the Internet without being cached by Squid.
If the Squid server and firewall are different servers, the statements are different. You need to set up iptables so that all connections to the Web, not originating from the Squid server, are actually converted into three connections; one from the Web browser client to the firewall and another from the firewall to the Squid server, which triggers the Squid server to make its own connection to the Web to service the request. The Squid server then gets the data and replies to the firewall which then relays this information to the Web browser client. The iptables program does all this using these NAT statements:
iptables -t nat -A PREROUTING -i eth1 -s ! 192.168.1.100 \
-p tcp --dport 80 -j DNAT --to 192.168.1.100:3128
iptables -t nat -A POSTROUTING -o eth1 -s 192.168.1.0/24 \
-d 192.168.1.100 -j SNAT --to 192.168.1.1
iptables -A FORWARD -s 192.168.1.0/24 -d 192.168.1.100 \
-i eth1 -o eth1 -m state
--state NEW,ESTABLISHED,RELATED \
-p tcp --dport 3128 -j ACCEPT
iptables -A FORWARD -d 192.168.1.0/24 -s 192.168.1.100 \
-i eth1 -o eth1 -m state --state ESTABLISHED,RELATED \
-p tcp --sport 3128 -j ACCEPT
In the first statement all HTTP traffic from the home network except from the Squid server at IP address 192.168.1.100 is redirected to the Squid server on port 3128 using destination NAT. The second statement makes this redirected traffic also undergo source NAT to make it appear as if it is coming from the firewall itself. The FORWARD statements are used to ensure the traffic is allowed to flow to the Squid server after the NAT process is complete. The unusual feature is that the NAT all takes place on one interface; that of the home network (eth1).
You will additionally have to make sure your firewall has rules to allow your Squid server to access the Internet on HTTP TCP port 80 as covered in Chapter 14, "Linux Firewalls Using iptables".
Good Luck!
Jun 22, 2009 | Computers & Internet
When i click on youtube it comes up with bad request and something about port80
Are you trying to access Youtube from work? Some companies setup firewalls and it maybe blocking Port 80, which is typically the port for Web Servers to bust thru firewalls to connect to the outside world.
May 09, 2009 | YouTube Videos
Firewall is blocking incoming emails
Do you have an email server in place? If so, you need to setup port 25 for inbound access to the IP address of the email server. I would suggest that you don't allow all as that will open up everything and kind of negates the reason to have a firewall. Some ISPs block port 25 though and use port 587.
If you don't have an email server then the problem might be with your email client configuration.
Apr 01, 2009 | D-Link NetDefend DFL-700 Firewall
Restricting websites at router or firewall level
The pix does not allow you to block urls except if you use it in conjunction with websense for example. You could however deny all outgoing traffic to port 80 except for the ip address of the websites you want to be able to access.
To do that you would setup an access-list allowing you internal network to access certain ips on port 80 and deny all other traffic outgoing.
Let me know if you need more information on how to accomplish this.
Jan 04, 2009 | Cisco PIX 515E Firewall
Port forwarding?
You can follow the steps on this link, click here. This is the steps on how to setup port forwarding for pc anywhere on a DFL-200. There is big possibility that the DFL-80 might have the setup configuration page as the DFL-200.
I hope this one helps.
Jul 07, 2008 | D-Link DFL 80 (DFL-80) Firewall
Can't connect firewall
Have you checked the subnet? i.e. 255.255.225.248, make sure both PC and firewall are set the same.
Check the firewall settings on the PC, for port 80, 8080 & 443 and the ip address of the unit if you connecting with web access.
Try to up the IP on the PC to 169.254.236.185, it some times does not like being before the device.
Aslo, some times the PC needs to have the network port reset, as windows keeps the old IP address, but shows the new. The quick way to check this, is to disable the network connection and then enable it again.
Apr 22, 2008 | WatchGuard Technologies Firebox 1000...
D-Link DFL-800 Firewall Logo
361 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
