Question about InFocus SOFTCASE, LP425Z Multimedia Projector
Flickering color, color flickers in and out
I have an INFOCUS model #LP425Z and when you turn it on the screen flickers rapidly from true color to no color. What are some causes for this malfuction? Is the bulb going bad? It was working properly then I stored it in my clean dry closet for about seven months, took it out and ceilling mounted it and it has flickered from that point on...
  • isabellacons Aug 31, 2008
    I have an LP425z I used it last night no problem, then tried it again this morning and light wont stop flickering. I will change the bulb to see if that is it... bulb currently has 587 hours on it. If changing the bulb fixes it I will post this ...but know I have tried every adjustment know, resetting etc to no avail at this point. Help.
  • 36 Answers
Check connections, board, and unit itself around the Color Wheel.
Posted on Aug 24, 2009
My dell e6400 is flickering rapidly that you cant read anything as from when you turn it on.
Sounds like a damaged display or GPU. Try an external display to confirm either way.
Jun 02, 2016 | Dell LATITUDE Computers & Internet
Infocus IN10 projector is flickering
it is likely a grounding problem associated with the connection of the power supply to the main board.
Jun 08, 2010 | InFocus LP70+ Multimedia Projector
Tv went grayscreen, flickering. turned off, then
When you had gray screen and flickering you had only one problem - color wheel. After "putting everything together" you have totally different problem, caused by multiple possibilities like: forgotten connectors, cut/jammed cables/wires, lamp not being inserted properly, lamp door not being set properly, disconnected color wheel, etc. Try to open rear cover and redo what you have done. Remove optical block, check everything visually and slowly put everything back. If still no luck - then only skilled TV repairman may (or may not) help.
Mar 10, 2010 | Samsung Televison & Video
Lp70 flickers and color wheel chirps at the same time. It's worse with more white in the image. Colored screen shots or dark movies have limited flickering. No issues prior to hookup to computer (Infocus...
it's chirping because it's trying to keep in sync with the dmd chip. for the refresh rate, go into the menu and first reset the settings to factory default. if this doesn't clear it up, try matching the signal.
Jun 09, 2009 | InFocus LP70+ Multimedia Projector
REMOTE
good luck. infocus has nothing having to do with any of the lp4xx series. they don't even have lamps. try ebay.
Apr 11, 2009 | InFocus LP425z and LP435z Replacement...
Color Wheel
you'll have to replace it. bad news: infocus doesn't make them anymore. sorry
Dec 07, 2007 | InFocus SOFTCASE, LP425Z Multimedia...
Problem with INfocus LP425z Colorwheel ?????
That unit has a bearing color wheel, if it was not stored proper, it could be sticking. That would explain the power cycling. giving it a bump start if you will. Yes you can open and inspect to see if color wheel "free wheels"
Feb 21, 2007 | InFocus SOFTCASE, LP425Z Multimedia...
925 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
