Question about Sakar Talking Caller-ID Speaker Phone
Emergency call Is there a special button to make emergency calls?
When i was opening my camera box i ended up cutting the CD that was inside for the downloading software. what do i do?
Posted on Feb 19, 2008
How to reset Kipor KDE6700TA P06 emergency stop code.
Error P-06 is the failure of the emergency stopping button. Replace the emergency stopping button or if possible check for repair.then by pushing rest/clear button reset the alarm and start the engine. https://assets-cf.criticalpowersupplies.co.uk/.../Kaipor_KDE12STA3_Silent_Generator.
Oct 27, 2017 | Kipor Electrical Supplies
Emerge ups 500 special
Vasanth,
Try replacing the battery, then turn it on.
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
Aug 18, 2013 | Computers & Internet
Cant install emergency brake cable
needle nose pliers great help pulling brake springs back in place.
Feb 05, 2013 | 2002 Dodge Durango
Turn signals do not work nor does emergency blinkers. They sometimes work for a short while then stop working. Vehicle is a 1996 crown victoria.
You probably have a short somewhere or you have a bad relay.
Check in your fuse box and see if there is a relay (a big button looking plug with all your small fuses) that is labeled to control the turn signals. More than likely there is a relay for your emergency lights. Go to your local parts store, get the replacements for your vehicle, pull out the old ones and put in the new ones.
If this doesn't solve the problem, then you've probably got a short somewhere and you will need to go to a shop that specializes in auto electrical to get it diagnosed.
Apr 06, 2011 | 1996 Ford Crown Victoria
Today i pressed on the emergency break on my chrysler 300c and it stuck now i dont know how to release it. i cant even drive the car because the e-brake is on, what should i do to release it? is there a...
Some cars do not have an emergency brake release the way to release the emergency brake is by pressing it again harder than before. I know it sounds strange but some vehicle manufacturers have incorporated the release into the pedal itself. Good luck.
Mar 18, 2011 | Chrysler 300C Cars & Trucks
2002 volkswagon golf gas tank release button inside front drivers door will not open the outside door, where is emergency button?
emergency button it aint got.....pull away the trim inside the trunk to get to the release wire.(what car has an emergency button,never heard of one...)
Jan 27, 2011 | 2002 Volkswagen Jetta TDI
My motorola has an emergency alert button on top, when pressed and held it sounds an alarm on all other radios near it. we pushed it to test and it works well and is a cool feature. however, the call tone...
Your radio may be functioning normally for the emergency alert. Here is an excerpt from the user guide:
Emergency Alert Mode
The Emergency Alert feature can be used to signal members in your
group of your need for urgent help. MR series radios will operate in an
automatic "hands-free" emergency control mode for a total of 30
seconds after activating the Emergency Alert. MR series radios in your
group will automatically advance the speaker volume to the maximum
setting and sound a warbling alert tone for 8 seconds. The alert tone is
emitted from your own radio speaker and the receiving radios in your
group. After the 8 second alert, any spoken words or incidental sounds at
your end will be transmitted to the group for 22 seconds. For the 30
second duration of Emergency Alert mode, MR series radio controls and
buttons will be locked to maximize reception of the emergency message.
1. Press and hold the Emergency Alert button for 3 seconds.
2. Release the button after the LED Indicator glows red and the alert tone
begins to sound. There is no need to continue to hold the Emergency
Alert button or use PTT for your message to be transmitted.
3. After the alert tone ends you may speak into the microphone. Your
voice or incidental sounds will be transmitted. The LED indicator will
continue to glow for the duration of the 22 second period.
4. After 30 seconds your radio speaker will emit a Talk Confirmation
Tone and the LED Indicator will extinguish. Operation then returns to
normal two-way mode.
Note: All Motorola Talkabout EM, MJ, and MR series radios are fully
compatible with the Emergency Alert feature. Radios other than EM, MJ,
MR series can receive the emergency alert signal, but will not respond
with adjusted volume settings, locked controls, or a warbling alert tone.
Users of other radio models set to the same channel and Interference
Eliminator Code will hear a steady tone for 8 seconds followed by the
voice transmission for 22 seconds.
Warning: The Emergency Alert feature should only be used in the event
of an actual emergency. Motorola is not responsible if there is no
response to the emergency alert from the receiving group.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/MR350-351%20User%20Guide%2012-16-08%20KEM-PK14190-90.pdf
Best regards.
Oct 22, 2010 | Motorola MR355R Two Way Radio
How to loosen emegency brake pads to remove rotor. do you need special tool
there is no rear emergency pads,
the pads that straddle the rotor are your rear brakes,
the emergency brake shoes are behind rotor
Nov 28, 2009 | 2000 Chrysler LHS
Have a emergency light with tc on it
the tc is traction control on 05 there is no button to turn off it needs to be serviced if u get a clunk sound from the rear the rear has to be serviced since the rear has special fluids and clutches .the other way the tc comes on is usually with an abs problem the sensors are tied together the tc activates the awd in ur vehicle so when front wheels slip the rear activate
Sep 21, 2009 | 2005 Chevrolet Equinox
Sakar Talking Caller-ID Speaker Phone Logo
24 people viewed this question
Top Sakar Lands Phones Experts
Computer Repairing
Computer Repairing
Andrew Taylor
Andrew Taylor
Are you a Sakar Lands Phone Expert? Answer questions, earn points and help others
