Question about i-mate JAQ Pocket PC
Why does the JAQ keep dialing 9 while in a call?
  • yankoski Feb 14, 2008
    Why does the JAQ keep dialing 9 while in a call? How can I fix it?
  • Anonymous Dec 18, 2008
    my i-mate jaq keeps dialing 9's
    Problem Solver:
  • 6 Answers
I believe it just the touch problem when it touches ur ear or face. better to keep phone in locked position. also go to following
http://www.youtube.com/watch?v=jCiQoBzW1D4
>>>babamanan@gmail.com
Posted on Feb 21, 2008
I cant fax
Take your cell-phone, and dial the same number, to see if you get the same "busy" signal.
If the telephones in your business require you to "dial-9" to get an "outside" line, be sure that your FAX is also following that "dial-9" protocol, and also waiting 1 or 2 seconds after the "dial-9", in order to get the dial-tone from the "outside" line.
Dec 10, 2009 | Brother MFC 240C All-In-One InkJet Printer
Tip
Hi, i got new Imate-jaq. I am facing problem in synchronising the imatejaq with...
Your battery has been depleted past a chargable state.  This is a due to a bad design in the phone that doesn't monitor the battery power state well enough.  It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
on Dec 28, 2007 | T-Mobile MDA
Is there any other way to reset my imate JAQ .... its internal function of factory reset is notworking plzz tel me some way to format i-mate JAQ i-mate JAQ WinCE version:- window mobile 5.1.422 AKU 3.2.0 i...
1. Turn off your device.
2. Hold down the Send button, End button and Camera button.
3. Do not release Send, End and Camera, press the Power button.
4. After on-screen indication, release all the buttons.
Please Vote...
Sep 08, 2009 | i-mate JAQ3 Smartphone
How to do factory reset of i-mate JAQ
here is how to do a hard reset:
note: all three at the same time
1)push stylus into soft reset hole + press FN key + press right soft key.
2) phone will restart to factory settings
enjoy.-->
Dec 25, 2008 | i-mate JAQ3 Smartphone
Imate jaq having problem to connect the pc
I have problem to conect with my PC with imate jaq so p/l let me know at ashok_manandhar@hotmail.com
Sep 07, 2008 | i-mate JAQ Pocket PC
Modem drivers for imate Jaq
I have i-mate JAQ. I want modem drivers of JAQ for xp operating system.
Could you please tell me the path or the link.
Thanks in advance.....
Jul 19, 2008 | i-mate JAQ Pocket PC
Issue with imate JAQ
Dear Have u got ur GPRS or EDGE service activated from AIRTEL. Pls confirm it, if yes then following are the settings for airtel.
go to
>>START>>SETTINGS>>CONNECTIONS
connections>>Add a new Modem connection
>>Enter name-airtel or Mobile office
>>select a modem>>it should be Cellularline (GPRS)
>>NEXT
>>eNTER THE NAME AS IT SHOULD BE DIALED
>>enter airtelgprs.com (all small caps)
>>NEXT
>>FINISH
NOW again go to START>>SETTINGS>>CONNECTIONS>>connection>> Advanced>> select networks
There will be two options
1-prog that automatically connect to the internet
2-prog that automatically connect to a private network
>> for both options select >>My ISP
>>tab OK
Feb 29, 2008 | i-mate JAQ Pocket PC
Password
u need to hard reset the phone>>>babamanan@gmail.com
Feb 09, 2008 | i-mate JAQ Pocket PC
Synchronise and connection problem in Imate jaq
hello! pradeep
let me tell u if u r using windows XP as an operatin system
then activesync creates some problem it is better to download activesync 4.5 which is the latest one and your problem will be solved. you can download it from net...
Dec 28, 2007 | i-mate JAQ Pocket PC
i-mate JAQ Pocket PC Logo
27 people viewed this question
Top i-mate Computers & Internet Experts
iphone service
Oloyede Monsuru
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
