Question about SanDisk Sansa e260 MP3 Player
Sansa e260 restart
I turn on my mp3 the sansa e260 and it just keeps on restarting
  • xcrashx Apr 01, 2008
    when I load music to my sansa only some of the songs appear and when i try to play songs a box that says bad track pops up. the ones that do play it plays half the song and fills the second half in with another song. How can i start out fresh or get this problem to stop?
    Sergeant:
    Champion:
  • 281 Answers
Because you have a problem in the music, you just have to format it than it will come back
Posted on Feb 09, 2008
My sansa keeps restarting itself
I would recommend that you upgrade the firmware on the device..Once the firmware is update you shouldnt have any problems..To update the firmware follow the link below
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Please rate accordingly
Thank you
Computerrep
Mar 23, 2008 | SanDisk Sansa e260 MP3 Player
How do i restart my e260?
Restart?
you mean reset? if so. then just Format it by going to start>my computer>The Players Drive then right click and format.
if your player is frozen then Leave the power button located at the bottom-left hand side for 20-25secs.
If you want to turn on then leave the power buttton pressed for 3 secs
Feb 17, 2008 | SanDisk Sansa e260 MP3 Player
Once i turn it on i cant turn it off and when i go to listen to music it just goes and restarts itself
Sounds like it's froze and needs to be reset. -
Press to power on/off, enter menu, or hold 15
seconds to reset your Sansa.
Or-To reset the sansa = Hold down power button for20 seconds.
If that don't work let me know so i can try something Else?
P.S...Please rate accordingly...
Thank you
Computerrep
Feb 09, 2008 | SanDisk Sansa e260 MP3 Player
E260 Major Problem!! Worst of Problems...
try recovery mode again if you havent already. or when its connected to your pc push and hold record button and the middle click button. i hope this helps. best of luck : )
Jan 12, 2008 | SanDisk Sansa e260 MP3 Player
My sansa froze
have you tried restarting it?
Dec 15, 2007 | SanDisk Sansa e200 MP3 Player
Please help
i'm in the same exact boat - this sucks... what now u brains?
Oct 18, 2007 | SanDisk Sansa e260 MP3 Player
Snasa e260 wont load up
Hi. Your Sansa E260 might be encountering some system errors and would need a Firmware re-flash by setting it to its recovery mode. Try this: RECOVERY MODE Switch your Sansa E260 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E260 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred which caused the player to keep resetting. Step 3: When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E260 and 90-99% of the time, it would boot up successfully. If not, try to repeat steps 1-4 again. I hope this helps. The E260 is a great player.
Apr 10, 2007 | SanDisk Sansa e260 MP3 Player
When turning on screen fades away then restarts automatically
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Mar 09, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
119 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
