Question about Phoenix Gold Octane-R 15.0:1 Car Audio Amplifier
Wiring my subs to my amp
I have a phoenix gold 5.0;4 amp ans two mtx 12 inch 4500 sub woofers in a sub zero double ported box whats the best way to hook this up? front or rear channel? should i bridge the amp? hook the speakers up in series or parelell? please help? thank you john
  • 82 Answers
Bridge it and rear channel if you need to know how to bridge let me know
Posted on Feb 09, 2008
Where can i gt wiring diagram for phenix gold 12 dvc sub
YOU CAN GO THIS THIS SITE IVE USED FOR MANY YEARS PUT IN YOUR INFORMATION OF SUB/ SUBS AND GIVES YOU ALL WIRING POSSIBILITY'S.
Rockford Fosgate Woofer WiringWizard SORRY MY CAPS STUCK..HOPE I HELPED.
Oct 03, 2012 | Phoenix Gold Car Audio & Video
Tip
Box specs and airspace for 8 inch subwoofers
<span>Regardless of your wattage rating on your sub woofer, sub woofers</span> differ in only one way. You get an "Open Air" and a "Closed air" <span>Sub woofer</span>, That being said, you'll have to check on your magnet which one you have, to make the boxes for that particular sub woofer. If it is an "Open air" <span>Sub woofer</span>, you should see a hole with "wire mesh" or "metal grid" in the center, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.<br /><br />If it is a "Open air" sub, your boxes should always be sealed with silicone sealant, and no ports are to be cut in your box.<br /><br />Regarding the "Closed air" <span>sub woofers</span>, you should have 2 ports cot in the corners of the boxes just below your sub on the face of the box, and the port sizes should be around 50mm in diameter. Get yourself some 50mm PVC drain piping to use as ports. Firstlycut yourself a 100mm piece and insert flush with the front of the box. Test your sound. then try a 150mm piecs and test again. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 250mm, depending on the frequency of bass you require. Carry on testing the sound on each increment until you find the sound you want, Then silicone the port to the box for permanent fixing.<br /><br />On a 15 inch <span>Sub woofer</span> ranging between 80Hz and 100Hz, the ample box size required should be a box of 9 inches high, x 9 inches wide, x 9 inches deep. Or 400mm high, x 400mm wide, x 400mm deep. <br />Enjoy! <br />
on May 29, 2011 | Car Audio & Video
Tip
Box specs and airpsace for 12 inch subwoofers
<span>Regardless of your wattage rating on your sub woofer, sub woofers</span> differ in only one way. You get an "Open Air" and a "Closed air" <span>Sub woofer</span>, That being said, you'll have to check on your magnet which one you have, to make the boxes for that particular sub woofer. If it is an "Open air" <span>Sub woofer</span>, you should see a hole with "wire mesh" or "metal grid" in the center, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.<br /><br />If it is a "Open air" sub, your boxes should always be sealed with silicone sealant, and no ports are to be cut in your box.<br /><br />Regarding the "Closed air" <span>sub woofers</span>, you should have 2 ports cot in the corners of the boxes just below your sub on the face of the box, and the port sizes should be around 50mm in diameter. Get yourself some 50mm PVC drain piping to use as ports. Firstlycut yourself a 100mm piece and insert flush with the front of the box. Test your sound. then try a 150mm piecs and test again. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 250mm, depending on the frequency of bass you require. Carry on testing the sound on each increment until you find the sound you want, Then silicone the port to the box for permanent fixing.<br /><br />On a 15 inch <span>Sub woofer</span> ranging between 80Hz and 100Hz, the ample box size required should be around 27 liters, meaning that you will end up with a box of 13 inches high, x 13 inches wide, x 13 inches deep. Or 400mm high, x 400mm wide, x 400mm deep. <br />Enjoy! <br />
Can i use a 300 watt amp for 2, 800 watt woofers
yes, but you would not get the same performance as you would if you gave them the suggested power. I have found that it is always better to use a more powerful amp than your subs are rated for (as long as it is clean, high quality, low distortion power). I have had the best luck with name brand amps (kicker,rockford fosgate,phoenix gold,etc...). I hope this will be helpful to you.
Jul 30, 2012 | Phoenix Gold Xenon X10D4 - 10" D4...
Need to know how to wire my system ...I have the infinity reference series 611a I was told it was a mono block but it has two channels on the exterrior...also I have two 12 inch MTX thunder dual voice coil...
it all depends on what kind of box the mtx subs are in as far as wiring the subs. The best way would be take the speaker wire from both sub boxes and run the positive into the right positive then the negative into the left negative. and run 8 gauge wiring kit to the amp because 10 might be to small and 4 is to big 8 gauge is perfect for this amp.
Jul 18, 2010 | Infinity Reference 611a Car Audio...
1501d,, What subs should i use/
I would stick with Kicker or MTX. The best place in my mind to get them is soncelectronix.com
Just try to mach the specs as close as possible. Make sure to look at the recommendations of the subs for the size of the box and the port volume.
Oct 11, 2009 | MTX Thunder 1501D Car Audio Amplifier
Ok, I have a pair of infinity dual voice coil 12" subs, and a pair of audiobahn quad voice coil 12" subs. Boths sets of speakers can handle 450w. Which set of 12's would be best to hook up to this amp, and...
i recomend you just use the best single woofer in a well built box and that will give you better sound at lower gain volumes it sounds like you have too much junk laying around but to get good bass run your sub at 2 ohms if the amp is stable at that impedence
Dec 16, 2008 | Phoenix Gold Xenon-200.4 Car Audio...
Need help with the wiring on amp to subs
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=3&woofer_imp=4 DON'T FORGET MY FIXYA RATING!
Mar 09, 2008 | Phoenix Gold R15.0:1 1500W Octane-R Mono...
Sub Wiring
if you wire the subs in parallel you would achieve 2 ohms which would theritically double your rms, sadly this isn't the case what with wire resistance and such you might get around 270 rms still not that bad. to wire in parellel you run a positive off the amp to the positive on one sub then run a wire from the first subs negative to the second subs positive the run from the second subs negative to the amps negative and bam 2 ohms but be warned this will put more stress on your amp and cause it to heat up faster. peace bro and best of luck
Dec 14, 2007 | Phoenix Gold XS6600 Car Audio Amplifier
Wiring diagram
The LEd wires need a wire run from the speaker to the Fuse block in your car. The small Red wire from the LED will be the one that hooks to Swtiched 12 Volts supply on the fuse block so that your Led Turns on when you turn the keyswitch on. The Black wire goes to ground, or to a metal part of your cars body, probably the same point where your Amp is Grounded.
The Octane R10 is a Single Voice Coil or SVC.
AMP+ to Sub+
Amp- to Sub -
Use 12 guage wire.
Nov 07, 2007 | Phoenix Gold Octane-R 10/10d Car Subwoofer
Phoenix Gold Octane-R 15.0:1 Car Audio Amplifier Logo
247 people viewed this question
Top Phoenix Gold Car Audio & Video Experts
Mark Skinner
Jose Velazquez
Jose Velazquez
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
