Question about Koutech Systems Koutech Black FPM920-B 9-IN-1 Front Panel Multifunctional Device - RETAIL (DSKTFPM920BK)
  • I am building my first computer and I'm installing a Koutech Black FPM920-B 9-IN-1 Front Panel Multifunctional Device . The installation manual is less then desired. I was wondering if there is any other information on installing this device. Any information would be appreciated.
  • Thank you
How to conect front panel
For this you need the motherboard manual.
If you do nor have it, download it.
The setup procedure will be at the beginning, after the specifications. The two cables from the front panel that are important are the (power on , LED reset) cable, and the USB cable.
Both these cables are built to the Intel developed, case standard, on most PCs.
The problems start when you are building a PC with an old case. The wires from the front panel will be all separate.
The motherboard manual will have the location of the pins, and the "pin out" for the motherboard.
The color lead is positive, and the white is negative.
The speaker wires are red and black, and the polarity does not matter.
Do them one at a time. Start with power on, when you have found the proper pins and hooked up the leads, then reset, then power LED, then HDD LED, and last the speaker.
Then find the USB pins and connect the USB cable to the motherboard.
The PC should boot, assuming the other components are installed.
Sep 02, 2015 | Computers & Internet
MFC-8660DN
HI,
Click HERE to download the user's manual.Please refer the troubleshooting steps.
Click HERE to download setup guide.
Goodluck,
Please don't forget to rate the solution.
Mar 28, 2008 | Brother MFC-8660DN 5-in-1 Laser...
Tip
How to test, and setup the Fax machine on HP multifunctional printers.
Hi.
Please follow the instructions below to install and test the fax on an HP multifunctional unit.
1 - before connecting the printer install the software in the CD provided with the printer on the computer. The fax unit will also work in stand alone mode, but without installing the software you will not be able to control the unit from the connected computer.
2 - Have ready a phone cable. Ensure that the phone cable that you want to use has only two connectors:
3 - Connect one end of the telephone cord to the telephone jack andthen connect the other end of the cord to the socket labeled 1-Line on the back of the HP fax printer.
4 - The multifunction HP is now ready to send and receive Fax.
To send a basic fax:
1. Load your originals.
2. Enter the fax number by using the dial button on keypad.
3. Press START FAX Black.If the device detects an original loaded inthe automatic document feeder, it will send the document to the numberyou entered
If the Fax is not sending, then check that the original is loaded properly, then run the fax test following procedure below:
  1. press Setup
  2. select Tools
  3. select Run fax test
  4. press OK
Or:
  1. Load the original into the input tray.
  2. Press the Setup button (the one with a wrench) on the unit control panel.
  3. Press right arrow, select Tools, then press OK.
  4. On the Tools menu, press the right arrow to select Run Fax Test, and then press OK. The fax diagnostic test prints.
  5. Review the report.
If the test does not return ALL PASS , then setup the fax manually.
Change the HP fax settings
  1. Disconnect the telephone cord from the single-line telephone and then plug it into the port marked 1-Line at the back of the HP product.
  2. Press the Setup button (the one with a wrench) on the product control panel.
  3. Press the right arrow to select Basic Fax Setup or Advanced Fax Setup, then press the right arrow again to change settings to the settings listed in the table below.
After verifying Fax settings, try again sending a fax.
If still no luck, try calling the HP number listed on your user manual. In that case there may be a fault.
Also ensure that you do not have a VOIP phone rather than a landline phone, in that case setup will be completely different.
You can find driver software and manuals using the link below:
HP SUPPORT.
Regards.
on Feb 26, 2010 | Office Equipment & Supplies
I have a laptop using Windows ME os. I purchased your WL-GI-600n wireless card along with your USB-SOUND 7 adapter. When I run setup I get a message saying "plug in USB multichannel audio device...
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
also you might need to update the sound drivers
click start control panel administrive tools computer management device manager sound video and game controllers could be a yellow question mark? right click to re-install drivers
if you dont have a motherboard disk you will need to download the sound drivers
hope this helps
Jul 18, 2011 | Computers & Internet
I lost the installation of my ir3300 and we need to install it in one of our new computer
Hi, web site, should have your solution:-
The Canon imageRUNNER iR3300 Photocopier/Copier/Multifunction ...
The Canon imageRUNNER iR3300 Photocopier/Copier/Multifunction Printer/Multifunctional Device will handle all of your office or workgroup's tasks.
www.canoncopiers.co.uk > Discontinued Photocopiers
Jun 05, 2011 | Office Equipment & Supplies
Have problems installing 4GB memorycard?
hope this helps
May 18, 2011 | Computers & Internet
Cannot install rockbox on my sansa e250
did you extract rockbox...........did you patch it you need this also (DOWNLOAD THIS FROM HERE) http://download.rockbox.org/bootloader/sandisk-sansa/sansapatcher/win32/sansapatcher.exe
once you do this plug device to pc...copy what was extracted and paste to root of the device
installation link http://download.rockbox.org/manual/rockbox-sansae200/rockbox-buildch2.html#x4-60002
manual http://download.rockbox.org/manual/rockbox-sansae200/rockbox-build.html
have fun rock with the box
Feb 03, 2009 | SanDisk Sansa e250 MP3 Player
Install
Dear Enoos,
You can download the USER Manual for your multifunctional device from this site:
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=07de5232f3bc15c147b350e34b063010&q=Samsung+SCX-4521
It will be guide you step- by- step installation procedure.
Regards
Apr 16, 2008 | Samsung SCX 4521F All-In-One Laser Printer
MFC-240C Driver Install Issues WINXP SP 2
http://www.nodevice.com/driver/company/Brother/Multifunctional.html
HEAR U WILL GET THE RIGHT DRIVER.....
1 ST DOWNLOAD IT....
THEN GO TO MY COMPUTER AND RIGHT.CLICK
GO TO PROPERTIES
GO TO DEVICE MANAGER
NOW  SELECT U R DEVICE(PRINTER) ETC.NOW UPDATE U R DRIVER.....GIVE DRIVER DESTINATION MANUALLY....(LOCXATION WHERE U HAVE SAVE U R NEW DRIVERS)
I M SURE U R PROBLEM WILL BE SOLVED
dont forget to tell me u r problem solved or not
best regards & best of luck.
Oct 23, 2007 | Brother MFC 240C All-In-One InkJet Printer
Koutech Systems Koutech Black FPM920-B 9-IN-1 Front Panel Multifunctional Device - RETAIL (DSKTFPM920BK) Logo
46 people viewed this question
Top Koutech Systems Televison & Video Experts
Marvin
Marvin
Are you a Koutech Systems Televison and Video Expert? Answer questions, earn points and help others
