Hitachi VCR and Phillips Magnavox TV
VCR plays but the television stays on a channel. How to you set the TV to work together with the VCR. We do not have the manuel for the TV or VCR
    Novelist:
    Champion:
  • 232 Answers
Mentor, sounds like it`s wired incorrectly or your using RCA cables (yellow, red, white ends) out of the vcr into the tv, If your using RCA cables the tv`s "input" (on the remote) has to be switched to "video input 1 or 2" etc to see the vcr tape. If you want to see the vcr`s picture on channel 3/4 you have to tell me if your using a cable or sattelite box and then I can tell you how to wire it with the coax cable, let me know, BMW Rider
Posted on Feb 07, 2008
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dvd hookup to phillips tv without inputs
Have yourself a VCR that has a Scart input, or Video in, and feed the DVD in there. Connect your TV to the VCR, and tune it in to the video channel, using aerial lead and tuner.
When you flick VCR to AV1 (or similar) you should see the DVD appear on the TV Video Channel :)
Mar 14, 2009 | Philips Magnavox 27MS343S 27" TV
I have an universal Philips Magnavox remote don't know the model # but I just need to know how to search for the codes. I can't remember how.
These are generic code search instructions for Phillips/Magnavox
Programing with Code Search
1. Manually turn on (TV,VCR,etc.) to be controlled.
2. Press and hold Code Search button until red indicator stays on.
Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.).
The red indicator blinks, then stays lit.
4. Press the Channel Up button repeatedly ( up to 300 times )
until the device to be controlled changes channel.
The red indicator blinks, then stays lit. If you accidentally
overshoot the code required, press the Channel Down button to
backtrack through the library until the device changes channel.
Pressing Channel Up changes direction to forward again.
Press and release the Mute button to install the code.
If the device you are installing does not have a Channel Up button
use Play(VCR only) or Power, on all other devices.
Jan 03, 2009 | Philips Magnavox Learning Universal Remote
T.V. shuts off when I try to play a DVD in the built-in player
Try putting in a VCR tape let it load and hit stop. If the set stays on it's the VCR deck causing the problem. It will be either be bad sensors or LED or possibly the mode switch. Let me know if this helps.
Oct 15, 2008 | Philips Magnavox 27MS343S 27" TV
DVD input with signal access
IF I understand you correctly, the VCR, Satellite, etc is connected using an RF modulator/coaxial cable wire going into Antenna in
IF this is true, then you have an AV IN port (red, yellow, white) free on the back. Just connect the red, yellow, white from the out of the DVD - you can use 1 or 2 - just remember which one you used; and connect it to the AV IN on the back of the TV.
THEN press ch down on the TV remote until you get to "AV1" - it is below channel 2; double check DVD player to make DVD is playing and voila!
Jun 22, 2008 | Philips Magnavox 27MS343S 27" TV
Need codes for a philips universal remote code sheet
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 21, 2008 | Philips Magnavox Learning Universal Remote
Manual
Hope this helps :)
Jun 01, 2008 | Philips Magnavox Learning Universal Remote
Sitting in a cheap hotel room after work and have to get up to change the channel, have a Philips universal cl034 remote but do not know how to program it to the older Hitachi tv.
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1500115_AD_EN.pdf
Here is the link for your remote.
Here is the list.........
Save Code list for future reference Refer to the setup procedure below and look up the 3 digit code for your brand of TV, VCR, etc., from the list below.
Refer to the Owner’s Manual for your remote for more information.
TV including LCD,
Plasma, & Panel TVs
HITACHI ........... 0410 0507 0815 0607
....... 0808 0002 0502 0710 0701 0802
....... 0707 0315 0515 0715 0519 0324
Direct Code Entry
1. Press and hold the CODE SEARCH
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
Code Search (by Brand)
Lets you search for a code for a specific
Brand within the Code Library for a
particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to
be controlled.
2. Press and hold the CODE SEARCH
button until the red indicator remains
button.
3. Press and release the desired Mode
indicator blinks off once.
4. Press and release the numeric button
(0-9) corresponding to desired
Manufacturer (see table below).
Note, pressing “0” performs a full
library search same as Device Library
Code Search Method.
5. Press the CHANNEL UP button ((or
POWER or PLAY (VCR only))
repeatedly until the device to be
6. Press and release MUTE to install
the code.
Note, when all codes under a Brand
have been searched the red indicator
flashes rapidly for 3 seconds.
Code Search (by Device)
If after trying “Direct Code Entry” or
“Code Search (by Brand)” your device
does not respond, or if your brand is not
listed, try doing a device search of the
code library for your code by following
the steps below.
button.
4. Press the CHANNEL UP button
then stays lit.
5. Press and release MUTE to install
the code.
Most users will want to store VCR
codes under the VCR button, Cable
codes under Cable, etc. If you want to
store a VCR code under Cable, etc., first
follow the procedure for Direct Code
Entry and press Cable in step 2 of
Direct Code Entry, then enter ANY
VCR code in step 3 of Direct Code
Entry. Then follow the steps above for
Brand Search or Complete Search.
Brand Search Table
Look up your brand in the appropriate
column (TV, VCR, etc.) in the table
below. Look for the digit (1, 2, 3, etc.)
that applies to your brand, and enter it
in step 4 of “Code Search (by Brand).”
Digit
6
78
90
TV
RCA, GE,
Proscan
Zenith
Philips,
Magnavox
Sony, Panasonic,
Sharp, Toshiba,
Daewoo
Hitachi, Sanyo,
LG-Goldstar,
Samsung, JVC,
Mitsubishi
Sylvania, Fisher,
Curtis-Mathes,
Emerson
N/A
N/A
N/A
ALL
VCR/DVD/DVR
RCA, GE,
Proscan
Zenith, Apex
Marantz, Philips,
Magnavox
Sony, Panasonic,
Sharp, Toshiba,
Daewoo, Yamaha,
Denon
Hitachi, Sanyo,
LG-Goldstar,
Samsung, JVC,
Mitsubishi
Sylvania, Fisher,
Curtis-Mathes,
Emerson
N/A
N/A
N/A
ALL
CABLE
Scientific Atlanta
Jerrold
Tocom, General
Instrument,
RCA, GE,
Proscan, Pioneer
Zenith, Gemini
Philips,
Magnavox
N/A
N/A
N/A
ALL
SAT/DBS
RCA, GE,
Proscan, Pioneer
Zenith, Gemini
Philips,
Magnavox
Sony, Panasonic,
Sharp, Toshiba,
Hitachi, JVC,
Samsung
General Instrument,
Echostar, Dish,
Hughes, Primestar
N/A
N/A
N/A
ALL
CD/AUDIO
RCA, GE, Proscan
Zenith
Marantz, Philips,
Magnavox
Sony, Panasonic,
Technics, Sharp,
Toshiba
Hitachi, Sanyo,
JVC, LG-Goldstar,
Samsung,
Mitsubishi
Sylvania, Fisher,
Curtis-Mathes,
Emerson, Optimus
Pioneer, Teac, Nad
Kenwood, Yamaha,
Denon, Onkyo
N/A
ALL
HDTV Set Top Boxes
HITACHI . 0538 0324 0336 0931 0834
Mar 04, 2008 | Televison & Video
TV seems to be "stuck" in VCR mode after power surge
your tv is playing dvd means your video &sound section is ok. as it is not playing cable means that there a problem in tuner section only. if cable connection &its socket is ok.
Sep 25, 2007 | Philips TS2768C 27" TV
Televison & Video Logo
141 people viewed this question
Top Televison & Video Experts
