Question about KitchenAid KGRT607 Gas Kitchen Range
Door is out of "plumb"
I recently noticed that my oven door is leaning to the right and rubbing on the trim. Does anyone know of a solution to "replumb" it?
  • Samd007 Feb 07, 2008
    I will try and adjust it as soon as dinner is over... I know that I can hang on to the door longer then..LOL I'll let you know. Thank you
  • Samd007 Feb 11, 2008
    I finally was able to get to the door, I removed it bu there was no way to adjust the door. The model is a Kitchen Aide KGSA906PSS00. There is a small screw above each hinge but they go directly into one hole there is no way to slide the hinge without drilling another hole in it to put the screw into.
  • 770 Answers
You will need to remove the door first....Pull the door open slightly it will hold in that position about 3"-4"open. then grab both sides of the door and pull stright up the door will lift off (Note: Some models require you to remove a screw first to see if you have this type open the door completely and look by the hinge) After the door is off you will see an Adjustment screw on top if the hinge you will need to screw it in or out depending on which side you want to raise or lower. after the adj replace the door to check alignment
Posted on Feb 07, 2008
  • 1 more comment
  • Gary Davd
    Gary Davd Feb 07, 2008
    Did that FIX YA?????
  • Gary Davd
    OK but it is hot now !!! haha
  • Gary Davd
    Gary Davd Feb 11, 2008
    You adjust the screw up and down Well see you rated me thanks for trying guess i will let you seek other help
I have a broken handle on Maytag microwave MMV4205AAS. Other similar posts seem to give the generic response on how to replace handles on "MOST" microwaves, but I do not see how it is possible with the...
Can you provide any pictures? Were you able to remove the inner trim of the door? After removal of door trim did you find the screws holding the handle on?
Dec 31, 2017 | Maytag Microwave Ovens
The front glass of the oven door fell off, didn't break....but, how do I put it back on? Was it just glued?
Hello. Notice in pic 2 of the exploded diagram of the door, part 359 which is the bottom door trim, part# WB07K0379. I believe this holds the glass in the door if I'm thinking of the right model oven. The glass door steel cover (designation 314) is WB57K10049. I'm not sure if your glass panel was glued to the steel cover--that's why I gave the part number for it--just in case it can't be repaired. If you need more info or part numbers, leave a comment and I'll be glad to help you further!
Sep 21, 2015 | GE Profile Spectra JGBP90 Gas Kitchen...
Were does the LH mirror on a 2011 f-250 connect. Removed mirror but disconnect is located some were in door or body. need to know what needs to be removed to gain access
  1. Remove the front door trim panel.
  1. Position aside the front door watershield to gain access to the exterior rear view mirror control switch electrical connector.
4.Disconnect the exterior rear view mirror control switch electrical connector
as you see you have to remove the door panel to have access to the electrical connector in case that you dont know how to do it here are the instructions
NOTE: Left front door trim panel shown, right front door trim panel similar.
  1. Remove the sail panel.
    • If equipped, disconnect the electrical connector
  2. If equipped, lift up and remove the exterior rear view mirror control switch panel.
    • Disconnect the electrical connector.
  1. If equipped, lift up and remove the window control switch panel.
  1. If equipped, remove the window regulator handle.
    1. Position the window regulator handle cover aside.
    1. Remove the window regulator handle screw and regulator handle
5.Remove the door trim panel center screw cover
6.Remove the 2 door trim panel center screws
7.Remove the 2 door trim panel lower screws
  1. NOTICE: Do not pull directly outward on front door trim panel as damage will occur.
    • Lift upward to remove the front door trim panel.
  1. NOTICE: Insert the lower panel tabs first or they can break when installing the front door trim panel.
    To install, reverse the removal procedure
Feb 20, 2011 | 2011 Ford F-250 Super Duty
I have a Whirlpool double oven GMC305PRS01 when you turn on the oven it appears to me making all the right move IE it goes into pre heat and starts counting down but the elements are not getting hot.
Member Discussion on Whirlpool GMC305PRS01 Microwave Oven
Whirlpool Wall oven/microwave combo unit Door message
Does anyone know where the 15 amp fuse is? I replaced the 20amp fuse and it worked for a minute or two and then I opened the door and I blew my circuit breaker. I reset my circuit breaker, replaced the 20 amp fuse and now all I get is the Door message. I also noticed that it fused the outside switch on the right side of the door so I had to open the switch up and un-fuse it. This is for a whirlpool GMC305PRS01 Wall Oven/microwave combo unit.
Also if anyone could tell me the correct position the wire is supposed to be hooked up on the switches? I had someone help me take the switch out and they unhooked the wires and now we aren't sure how they are supposed to be hooked up. My light on the microwave doesn't work either. Is it possible the bulb blew when the fuse blew?
Nov 22, 2010 | Whirlpool GMC305PRS Stainless Steel...
SMEG SA708X oven's symbols have rubbed off, wioul appreciate a photo of the left hand (have only managed to find the dial template for teh right side dial)
Here's a picture of the panel... BTW does anyone know the wiring / have a wiring diagram for the door switch as mine was swapped around by an oven guy just to get it running but now I have a new switch and can't remember how it all goes!!
Feb 26, 2010 | Smeg S1100MFX5 Electric Single Oven
Oven door sqeaks and is hard to open all the way . Is there a way to adjust the hinges on the door? Everytime you open it, it makes a sound like metal rubbing on metal
Adjusting the oven door is best left for a factory trained tech. There is alot involved with getting the hinges and monitor switches working together in harmony. alot of times the bottom grate on the front of the oven rubs on the door and usually gives you the metal on metal sound. the bottom grate just pulls off. Then see if its still rubbing. Be sure that the oven door has all of the screws and they are tight before calling for service. There are 3 screws on the left side and on the right side without them you will have problems.
WARNING: Procedure should be done while
oven is hot. As a result, exercise extreme
caution when adjusting the door.
good luck Sean
Nov 18, 2009 | TurboChef TORNADO Electric Oven
Remove and replace passenger door mirror on 2009 ford explorer XLT, main part , I don't know how to remove the interior door panel. Pictures might help,
  1. Remove the front door trim panel handle bezel cover.
  1. Remove the front door trim panel handle bezel screws.
  1. Remove the front door trim panel lower screws.
NOTICE: To avoid damaging the front door trim panel, do not pull the bottom of the panel outward.
  1. Remove the front door trim panel by lifting upward on the armrest to disengage the panel clips.
  1. Disconnect the electrical connectors.
  1. Disconnect the lock rod cable from the front door trim panel.
  1. Disconnect the door handle conduit and cable from the front door trim panel.
  1. To install, reverse the removal procedure.
be patient during these procedures to not damage the trim panel...they cost $150>275 ec........GL hope this helps
Jul 06, 2009 | 2009 Ford Explorer
Exterior glass trim on Kenmore Electric Range 880-5981
While waiting for someone else to answer my question, I fiddled around with the door parts. I managed to reassemble them! Here's how:
1. start with the glass panel. Slide the glass panel into the slot at the bottom of the front door frame on the stove.
2. next attach the handle. There are slots on the bottom of the handle that fit into the top of the glass panel. Slide the handle slots into the top of the glass panel.
3. screw the handle onto the oven door using the predrilled holes on the inside face of the oven door.
4. last, attach each of the two side trim strips. Slide the top of each strip into the bottom of the handle on each side of the oven door. Then slightly bend the strip outwards so that they are short enough to fit into the bottom slot of the oven door frame on each side of the glass panel.
Jan 22, 2009 | Kenmore 45062 / 45069 Electric Kitchen...
Control Panel
Yes actually i do..... open the lower oven door next to the hinges are 2 small phillips screws, securing two long metal side trim pieces. remove trim. Exposes two more phillips screws Control lifts up and off then Make sure unit has been powered down !!!!!!!!! If the old control is totally blank there is a thermal fuse that has gotten too hot. PLEASE rate my solution...Thank you
Oct 02, 2007 | Whirlpool RBD245PDS Electric Double Oven
KitchenAid KGRT607 Gas Kitchen Range Logo
160 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
