Question about Logitech Cordless Mouse
Slow cursor as i move the mouse around,it gets slow very fast and stops all together.i stop to let it rest,it starts out ok, but slows right away.
  • Anonymous Nov 30, 2008
    need to change pointer speed
    Scholar:
  • 110 Answers
Hiya! Check your batteries (if wireless) and try a different mousing surface. They can be picky with reflective or transparent surfaces. If you want, you can check out the mouse curser speed settings by going to Start > Control Panel > Mouse > Pointer Options. You should see a speed slider there.
Posted on Feb 17, 2008
G netbook cursor moves way too fast but i find no way to slow it down. apparently the solution is not in the help file.
The touchpad is very small on this netbook, so the ratio between the finger movement and cursor movement has to be high in order to be able to move the cursor from one side of the screen to the opposite.
The cursor cannot be too slow, because you would have to glide the finger several times on the touchpad to move it across the whole screen.
However, the speed of the cursor can be adjusted in the mouse properties in Control Panel (Start->Settings->Control Panel->Mouse) in the Pointer Options tab. Experiment with different settings to find one that suits you.
With such small touchpad I would suggest forming a habit of rocking the finger on the touchpad to achieve better precision and control, instead of sliding it. Put a finger on the touchpad center and tilt it left/right, up/down - You'll see that the cursor can be controlled quite well this way. And if you need a larger movement, then it's enough to move the finger the normal way.
Good luck and please come back with a rating/testimonial if helped.
Aug 01, 2010 | Sylvania G-Netbook
My cursor has turned into an icon that looks like a padlock, reducing maneuverability. Do you know how to get the regular cursor back? Thank you.
Hi, go to the "Control Panel," from the start menu, click to open, select in the Hardware & Sound category; "Mouse, next you can change the "Pointer" appearance, how "Fast or Slow..." the mouse pointer moves. "Rating the solution is appreciated, thanks."
Apr 03, 2010 | Logitech Marble Mouse Trackball
Mouse moves too fast
You can always control mouse pointer motion (speed), by using Mouse Option in Control Pannel. Open Mouse option in control pannel. Here you can go to Pointor Motion, now move the slider to left side. Click on Apply and check mouse speed. When you get the required speed, Click OK.
Thanks
Mar 21, 2010 | Logitech V450 Laser Cordless Notebook...
Mouse stopped working - cursor won't react
What type of mouse do you have, the brand and the model. Sounds like you need a driver for the mouse you have. If im understanding right you have a wireless mouse?
Jan 11, 2010 | Computers & Internet
Carburator settings
If you have played with them the only way is to get it going pretty well is" ....
find the idle screw - usually larger - and turn in 1/2 a turn - hopefully that will keep it running - then find the 'slow' running screw turn it in until it stops then turn out 1 and 1/2 turns. Leave the fast one alone.
Get it started then adjust idle screw so its faaster if need be.,, now slowly turn the 'slow' screw in then out say 1/2 turn and listen for it either speeding up or slowing down leave it at the point where it sounds ok and try giveing a few 1/2 speed rev ups. If it goes back and idles as before - leave it.
The fast screw... (first make sure your exhaust outlet is totally unblocked - the slightest restriction here will cause it to never run right at high speed). Start it up and then try full throttle - same thing as before try adjust the fast screw first in a little then out until it runs well at what seems the faster speed it can - then check that it accelerates well from idle to full speed. If not adjust it a little more until it does.
Once it will idle ok and return to idle and also run full speed, then you can back off the idle screw until it will idle without the chain racing arond the bar.
Bear in mind th chain wil be racing around while you adjust it so keep fingers kids and idiots well away..because you are adjusting it with that chain moving..
Nov 07, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Can i slow down my mouse cursor
Open the Control Panel. Select "Printers and other Hardware". Select "Mouse".
(Note: If you open Control Panel and it is in Classic View, just double-click "Mouse".)
Select the Pointer Options tab. (The exact tab name may differ.)
There should be a slider button to adjust the speed of the mouse. Click OK.
Thanks for using Fixya.
May 12, 2009 | Logitech Cordless Desktop S 510
Speed strip on touch mouse is too sensitive
remove the touch pad software if u have any installed for the touch mousepad
Nov 24, 2008 | Computers & Internet
Mouse stopped working, but appears ok, batteries ok, can't determine problem
Is the batteries good. If so try,
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Jun 08, 2008 | Logitech Wheel Mouse Optical
USB Optical Mouse is moving haphazardly and fast, without any control. Even if i don't touch it cursor moves. It has been tested on different HP and compaq laptop models. I have tried various plain pads on...
This might help as I brought a wirless mouse and it was wissing around the screen.
If you go to Start on your computer then
Click on CONTROL PANEL then
click on MOUSE then
click on pointer options and you can adjust the speed of it.
Mar 28, 2008 | Computers & Internet
Hope this helps others. My mouse stopped controlling cursor but buttons worked. Problem was it would not work on a black table. Slip a piece of white paper under it and waaala! It works. I'm thinking optical mouse and dark surface might be an issue.
Oct 10, 2007 | Logitech Cordless Mouse
Logitech Cordless Mouse Logo
722 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
