Gestetner printer error sc371
I wonder if you can tell me what error sc371 means on a gestetner dsc38u laser printer
  • brian c
    brian c May 11, 2010
    That is a toner density adjustment error for the yellow developing unit.
    This probably happened when you first turned it on, and the machine detected a problem with that unit.
    Was it asking for toner before this happened?
  • 96 Answers
SC371 YellowiD Sensor Detection Error
Posted on Feb 09, 2008
Would like to know if there's a downloadable print driver for Gestentner DSc525 printer for mac
Ricoh now supply the Gestetner drivers but the DSc525 is not listed. I wonder if this driver would work though.
Sep 23, 2011 | Gestetner DSc525 All-In-One Laser Printer
I have a Gestetner DSc38u and when I print colour I get a 'red'/'pink' line about an inch from the top of each page. Any suggestions?
If the line is only red or pink, it is most likely caused by the magenta PCU. Replace this PCU and your problem will go away.
Occasionally the magenta developer unit can cause a red or pink line, but the problem is more than likely from your magenta PCU. The PCU is easy to replace, and instructions will come in the box if you order an OEM replacement unit.
Jan 22, 2011 | Ricoh Aficio 3800CMF Laser Printer
Error code Sc552 wont clear
hello this is what will solve your problem
1. Check if the pressure roller thermistor
is firmly connected and clean it.
2. Replace the fusing unit.
note: check terminals may be durty also
the thermostat
Dec 13, 2010 | DSC GESTETNER - DSc38u Color Printer
We have a gestetner DSm622sp we are getting an error code SC320.
Hello sir; the error code you have display, that's means laser motor don't work, replace it!
May 18, 2009 | Gestetner DSm515pfd Digital Copier -...
Printing blank page with error message SC322
This is an SC error related to the laser unit.
Switch off and on the printer. If the error still appears, the printer has a defective laser diode or a defective Laser unit.
Please call an engineer to repair your printer.
Good luck and please rate me, thanks.
Oct 06, 2008 | Gestetner P7535n Laser Printer
Error message SC471
This is transfer belt home position sensor error.Clean the belt and the sensor.
May 27, 2008 | DSC GESTETNER - DSc38u Color Printer
DSc 38u Printer User Guide
There is no online manual on their site, but there is a knowledge base that may help you here:
http://www.nrgcss.com/drivers/Page2.Asp?Brand=gest&Vw=&Fltr=0&Ky=1021730003&Usr=&Cat=11&Mdl=173&Pvw=1
Use the tabs to choose between drivers, utils, knowledge base etc..
May 27, 2008 | DSC GESTETNER - DSc38u DT1 Color Printer
Color registration
Whenever you change the fuser unit you have to do the fuser registration.You have to use the manual feed tray with A3 or 11x17 paper for this registration.The details should be inside the new fuser box carton.
May 16, 2008 | DSC GESTETNER - DSc38u Color Printer
Gestetner-2412Z copier-error code UF
UF is a panasonic code,the u means user fix.If you have an users guide it will tell u what to do.
Mar 03, 2008 | Gestetner DSm515pfd Digital Copier -...
Gestetner dsc38 error code
You have an improper black toner density. Likely your black toner suction mechanism is clogged or the black toner supply clutch is not working.
Feb 21, 2008 | DSC GESTETNER - DSc38u Color Printer
192 people viewed this question
jasbo
jasbo
