Question about HP OfficeJet 6110 All-In-One InkJet Printer
HP ac/dc adapter 0950-4340
The green light on the plug turns off as soon as I plug it in to the printer. I unplug the adapter and replug in to the wall and the green light comes back on.
Any suggestions?
D.J. Miller
  • 2 more comments
  • DjRaceman Feb 09, 2008
    Interesting suggestion...when I plug it in that way, the light on the power supply plug just barely flickers...doesn't fire the printer up though..
    D.J.
  • Anonymous Feb 15, 2008
    I have the exact adapter situation when trying to use it with an HP laptop. Same adapter.
  • MJhnsn Feb 23, 2008
    Exact same problem - green light comes on adapter, but goes off once inserted - no combination of what was plugged into what first matters. Does anyone have a solution to this, or determined that it is simply a faulty adapter?
  • Anonymous Mar 30, 2014
    No lights but AC adapter shows 18 volts DC at plug
    Master:
  • 619 Answers
Hi , plug first the adapter to printer before plug it to ac outlet.
Posted on Feb 09, 2008
  • 24 Answers
Fiend your solution direct from hp. Here is your solution....
HP ac/dc adapter 0950-4340 - 11fe055.jpg
http://www.intel.com/motherboard/prob676ijt65/solution
823
Posted on Feb 28, 2009
Laptop is turning on and off
Remove the AC adapter (Charger)
PROPER method is to disconnect the power cord of the AC adapter, from power; THEN unplug the AC adapter from the laptop.
Same thing in reverse to plug the AC adapter back in.
AC adapter is plugged into laptop, THEN AC adapter is plugged into power.
Unplugging the AC adapter from the laptop, while being plugged into power; can cause a Voltage Spike.
You may get away with it for years, and several laptops; and have no problems.
However it only takes ONCE, to fry out the SMD fuses, Multi-Layer Ceramic Capacitors, and Power MOSFET's, on the laptop motherboard's DC to DC circuit.
Jus sayin'.
Moving on........
AC adapter removed, remove the Battery.
Press the Power On button in, and hold in for a count of 10 seconds.
Let go.
Do this procedure 2 more times.
(Draining residual power)
Reinstall the Battery. Attach the AC adapter, plug AC adapter into power. Let the Battery charge 24 hours.
Then turn the laptop on, and tell me what happened.
Regards,
joecoolvette
Mar 15, 2013 | HP Pavilion Computers & Internet
Unit will not come on-power ok ac to dc adapter ok
Great job on checking the power from AC to DC adapter. Also, make sure to plug the printer straight to the power outlet in the wall, bypass any surge device or power strip. Unplug and replug the power adapter in the printer, make sure it's properly secured and in the right position in the slot. Press the power button if needed. If this doesn't help at all, I strongly suggest you contact Lexmark Technical Support to further investigate the problem. I hope I can assist you more on this matter.
Jul 01, 2010 | Lexmark X5495 Printer
My dell D630 won't power up and the light from the ac adapter turned off whenever I plug it on the dc socket of the laptop. I tried unplugging it and then replugging it back to the outlet the light from...
Please remove the Battery and try to turn ON the Computer and try connecting to any other known power outlet. if the same issue persists, then the service may be required
Jun 24, 2010 | Dell Latitude D630 Notebook
HP Deskjet 9800 will not power up. Tried replacing power cord and tried plugging into a different power outlet. The little green light on the back of the power supply unit comes on, but the printer will...
Is there power coming out from the supply end
Is is a DC or and AC output supply?
If is it an AC output supply tyhebm in the back of the HP had an AC to DC converted that is realy a diode bridge and should contain a fuse in the circuit somewhere on that board
Jul 27, 2009 | HP DeskJet 9800 InkJet Printer
2wire 2701HG-B got red light on power & green light on wireless
Issue that you have mentioned its very common among 2Wire modems. Most of the cases we have diagnosed Modem usually OK but the AC Adapter, AC adapter somehow comes from 3rd party with low quality production. Due to its circuit design internal heat dries up the DC output capacitors. So DC output comes up with ripple and it cause modem to not work properly. You may change the AC adapter or you can change its Capacitors. Same rate AC adapters will work fine. Just make sure polarization is right.
If Issue continues you may post for further diagnosis
Good Luck
Jul 09, 2009 | 2wire 2700HG-B Router (2700HGB)
Bad motherboard for M1730
With the Dell laptops, if it were a broken power jack you would know by looking. It would show signs of missing/broken solder around the solder points. You could do a continuity test with a Volt/Ohm meter. However this would be tough with the barrel plug dell uses.
Now as far as getting someone to repair it for you. Iwould recommend a guy I use in florida. I originally found out about him on Ebay, he does a great job repairing motherboard issue (on the component level). He has ALL the proper equipment to ddo this. I have provided a link to his Ebay contact page. Send him an email, I am sure he can fix ya up.
May 19, 2009 | Dell Inspiron XPS M1730 (N09X7304) PC...
take out the battery of your machine and plug in the power. if it works well, suspected faulty battery. you need to replace it.
May 19, 2009 | Dell Inspiron 6000 Notebook
Laptop will not turn on
Unplug the ac adapter from the back of the computer. Make sure it's plugged to an electric outlet. check if the ac adapter light is solid green. if not. then you have to replace it.
If it is solid green, reconnect it to the computer, if the light on the adapter goes out as soon as you plug it in to the system, you need to replace the motherboard. call dell to seek your options for replacement.
Mar 02, 2009 | Dell Latitude D600 Notebook
C4180 Won't Power On
Make sure the plug is all the way into the AC adapter. Then, you will need someone to verify the output of the AC adapter. You should have a 16VDC and a 32VDC output from the adapter. If that is good, you have an internal problem with the printer. If the output voltage(s) are missing you will need to replace the AC adapter.
Here are the specs:
  • Input voltage: AC 100 to 240 V ~ 1 A 50–60 Hz, grounded
  • Output voltage: DC 32 Vdc===940 mA, 16 V===625 mA
  • HP part# 0957-2146 Call 1-800-227-8164 for availability.
  • Nov 19, 2008 | HP PhotoSmart C4180 All-in-One Color...
    Supersonic SC-299TDVD
    Battery back needs to be connected to the DVD player when charging. connect the batter pack to player. Run the DC/out from the battery pack to the DC/in in the player. plug the charger into the wall.
    if that does not work, you have a bad battery
    Dec 27, 2007 | Supersonic SC-299TDVD
    HP OfficeJet 6110 All-In-One InkJet Printer Logo
    254 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
