Technics stereo integrated amplifier su-g91
I have one and all it does is have this saying overload!!! what can i do to fix this problem for once and for all??? please help me.................thanks alot... hope to hear from you all real soon........
  • 1 more comment
  • tjnodes Sep 09, 2008
    Technics SA-GX290 Displaing OVERLOAD SHUTDOWN. I have tested both Power Modules, Power transistors, Resistors and completely traced and tested all component's along the OVER LOAD Protection trac form connector CN903. Everything test good and their are no hot spots on the board or components. This connector connect's to the front control panel behind the Disply. Thier does'nt appear to be any seconday power past the fist stage relay. Any help would be greatly appreciated. Tom
  • firebird9976 Oct 21, 2008
    I have the Technics av control receiver sa-dx750. It is old but just recently ran into the problem of it shutting down. I can get about 2 hours out of it then it shuts down and shows an error message F70. Having to do with the power supply. How do I fix it??
  • touch4in1
    touch4in1 Oct 15, 2012
    there is a short in the conection in the front panel re flow all points you will not see the break it will be hair line hidden and it expands when it gets warm causing the unit to short i have repaired 4 total so far this year alone all same issue some times i could not even find it testing it either due to the unit was cool and not being pushed hard enough to make it short
I had the same problem with the over load kicking in and shuting down the sound i the opened the unit to see. all the fuses where good and where.when i put it back together i then noticed that when i turned up the volume the rear fan did not work after palying with it some how started working and sound was as good as new and did not cut off. its been working fine since then
Posted on Jul 16, 2008
    Novelist:
    Scholar:
  • 96 Answers
It sound like you have burt the output stage, for some reason, u have over driven the speakers witch blew the output ic's, or have shorted output. To check if you have shorted output unplug the speaker's and try again to see if the mesage goes away, if it doesn't open the top cover to see if you can see if there is burt resistor's or fuses, if so replace them, then try again without speakers connected, never put the volume to max, why ?????? I just don't get it. Leave the volume to 1 or 10% capacity to try thing's or with earphones this is alway's to me the best way, if for some reason it keep's burning fuses, then it is ether the power supply depending witch fuse blow's or the output amp stage, most likely if is the output amp, the two big ic's you see, check on googles with the part # on them this will tell you what they or.
Hope this helps
Bob the builder.
Posted on Feb 08, 2008
  • robert landry Feb 08, 2008
    Hi, Also check for cold solder joint on the ouput, I also seen this problem on panasonic, it seem to be a common problem with them.
Hello ive got a diffrent problem ive got a technics hifi and when u put it onto aux it says txe-rvc and cd is dc its all the wrong way around what can i do thanks
Posted on Aug 29, 2009
I have a Technics SU-G91 amp that is stuck in overload even with no input. I have tried giving it a quick blast of air to dust and still nothing. All help is appreciated!!
Your Technics unit will remain in the overload (protect mode) state until component failures have been corrected. The output stages and/or associated components may have failed.
Sep 02, 2016 | Technics Audio Players & Recorders
How do I hook up a stereo reciver to the technics su-g91
I assume you want to use the SU-G91 as a power amplifier to drive your speakers. If your receiver has connections for inserting an equalizer (may be labeled pre-amp output and power amp input), remove the jumpers between the pre-amp and the power amp, then run cables from the pre-amp to the SU-G91 inputs. You can have an equalizer between the receiver and the integrated amplifier.
If this is not available, use the recording output (for a tape recorder on older receivers). Note that the volume control on the receiver will be bypassed with this connection.
Sep 23, 2012 | Audio Players & Recorders
Tecnics SU-G95 stereo overloaded
Power down,disconnect the speakers and power back up. If it still say's overload, it needs to go to service. If not, check your wires, connections, and speakers one by one to hunt down the problem and correct. Hope this helps
May 25, 2009 | Technics SUV500 2-Channel Amplifier
I have no sound in teh left channel , could be an integrated ?
Hey, The model of the amplifier is SU-G91 Technics.....If you could help......Thank you.
Apr 08, 2009 | Technics SA-EX320 Receiver
Technics SU-G91 OVERLOAD PROBLEM
THe amp has detected a problem and shutdown to prevent further damage. This unit has 2 amp pacs inside and one or both have failed. If you can solder, you can fix this yourself. The main amp pac is an SVI3206 and can be purchased online for about $60.
Keep me posted.
Dan
Oct 17, 2008 | Audio Players & Recorders
Su-g91
Have you checked the fuse in the unit?
Aug 31, 2008 | Technics SA-AX540 Receiver
I had the same problem. As soon as the volume reached about 24db it would go into overload. I was able to fix it by soldering all the connections on the larger power module. The one connected the the heat sink. When I took it apart there where several solder points that had come loose.
Oct 10, 2007 | Technics SA-AX540 Receiver
1,660 people viewed this question
 Grubhead
Grubhead
