Hitachi 50H72 Convergance issue
I have been scanning the boards here and need a little bit more help. My Hitachi has the separate colors with the curve on the top and bottom middle of the screen. A search on here pointed towards a IC replacement. Replaced both IC's with no change in picture. Am I possibly looking at some blown Pico fuses or something else that I am missing? Also, in relation to the Pico fuses, I read they would be located near the IC's, but does anyone know what they look like and how I would use the mulitmeter to test them? Or am I looking at a totally different fix? Thanks ahead of time for any help and suggestions!!
  • HenryFan Feb 07, 2008
    CORRECTION - It's actually a Toshiba, not a Hitachi. Sorry about the mix-up
    President:
  • 4,402 Answers
They look like tiny resisters,you check them with an ohm meter and they should show little resistance, have you checked the resisters in the convergence area there should be about 6 of them 1.6 ohm to 3.9 ohms.
Posted on Feb 07, 2008
  • Cary Farah
    Cary Farah Feb 08, 2008
    doesnt mater they both use the same part
Convergance issue
No colors alignment to any colors R,G,B.The tv convergence board are dead.The 2 STK convergence ICS and some or all it resistors must be to replaced to solved convergence problems.The shop will cost U $300-350 for parts and labors.
Jul 06, 2010 | Hitachi 43GX01B 43" Rear Projection...
My Hitachi 51 inch TV's color "comes and goes".
your problem is in the color circuit there is a ic that controls that circuit it can be located beside the micro ic.if your not a tech have a tech look at your tv for repairs since it is 51in there is a a separate circuit that controls that the color the main board can be change good luck
Mar 13, 2009 | Hitachi 51F59 51" HDTV Projection...
Need resister
DIgikey should have it. It is a 2Ohm 1 watt resistor.
Feb 08, 2009 | Toshiba 50H72 50" Rear Projection...
TOSHIBA 50H72 50IN. REAR PROJECTION TV BLUE COVERGANCE PROBLEM
you have a convergence ampliphier ic failing that will need to be changed and then adjusted
average repair cost for this are 280.00 to 320.00
Jan 20, 2009 | Toshiba 50H72 50" Rear Projection...
Convergance,and distorted projection,colors will not align
These tv's have a separate convergence power supply that goes bad. This will cause the problem you are having. Depending on the age of your tv, the board may be available
Dec 07, 2008 | RCA P61927 61" Rear Projection Television
Hutachi 43inch rear projection 5 yrs old
Hitachi Convergence
Check out the Convergence Gallery. If you see the colored outlines or color shading as in the Gallery, you have a convergence problem.
The repair for a Hitachi requires the replacement of the defective IC or ICs and any damaged or smoked resistors. Some models don't have a separate convergence board and the board is not usually available for the ones that do have a separate convergence board. Usually there is little alignment required after the repair. If you play with all the adjustments before the fix, hours may be spent re-aligning.
If you change the original ICs with substitute "new and improved" parts that are talked about in the blogs, you will probably create problems. Use the original ICs and resistors.
Don't monkey with it.
This is a delicate and difficult repair. If not done by someone with some electronic repair experience, the TV will likely end up as junk or cost considerably more for a tech to fix the damage done.
If you live in Calgary, call me. If elsewhere, find a competent tech.
easyab
Jul 30, 2008 | Samsung HCN4226W 42" Rear Projection...
Hitachi Model 43FDX20B Pink and Green Colors only
The convergence IC's you speak of are always mounted side by side and use the same #'s and are mounted on big metal heat sinks . Most start with STK392-??? . Also you may have bad resistors that are discolored and need changed as well . Some sets are protected by fuses but don't look like the typical glass fuses. They are pico fuse which could be green or yellow in color but look like resistors but do not have the color bands . Replacing the board could require a total convergence alignment. If you decide to take to a shop your avg. cost could be $250 to $300. If you do it yourself IC's and resistors or fuse would run around $50 to $70 bucks . Don't by the $9.95 IC's as they do not hold up as well . They should cost $20 to $25 apiece . Good luck
Mar 04, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Convergence IC's are at locations IK04 and IK05. There are some resistors that will be burnt up on the board as well. Replacement IC's are stk392-150, and are easily purchased, even off ebay. For the resistors you may have to get the location numbers and research the value. If you need the resistor values you can email me and I will get you the info.
Mar 04, 2008 | Hitachi 43FDX20B 43" Rear Projection...
Hitachi 51f500 magic focus
convergance amp ic bad
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 12, 2007 | Hitachi 51F500 51" Rear Projection...
TV Flickers up and down and screen is shifted to the right w/ red color dominating the screen.
the last hitachi that had this problem i fixed it bad finding bad solder conenctions throughout the board that the convergance ic's are on, also i foind some on the two main board in my repair. hopefully resoldering the convergance foard will fix the jitter or jumping around problem. if the picture is too red you can also try turning down the screen control slightly. good luck
Jan 02, 2007 | Hitachi 51F500 51" Rear Projection...
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
