Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Hoover Runabout steamVac -No return in Recovery Tank
I have a Hoover Runabout steamVac With model number F5824-900 that doesn't **** back the water into the recovery tank and It looks as if a part may be missing next to the bottom bush????
I read in another post a seal on the engine could be warped from heat but don't know how to locate it. Hope to find the answers here. Thanks!
  • Hoover Master
  • 1,545 Answers
There is a duct in the front of the water recovery tank that you remove to install the upholstery hose. If this duct is missing or not installed properly you will have no suction
Posted on Nov 13, 2017
5 Suggested Answers
  • 3 Answers
SOURCE: Hoover SteamVac Dual V Carpet Cleaner # F7410-900
Turbine assembly is bad. Get part #23 here http://www.vacuumcleanershop.com/hvrmdlf7205900.htm#B2
Not to bad to put in.
You can also find them on Ebay cheaper.
Posted on Jul 01, 2008
  • 3 Answers
SOURCE: We need the OPERRATING MANUAL for Hoover Steamvac 6020-900
download the manual for hoover F5810 at hoover.com. it's the same for your model.
Posted on Feb 11, 2009
  • 97 Answers
SOURCE: Hoover steamvac not picking up water
you don't have the recovery tank lid on correctly.
Posted on Jul 19, 2009
  • 377 Answers
SOURCE: I need the schematic diagram for a Hoover Agility
You will find this URL of help:
http://www.ereplacementparts.com/search_result.php
Please provide a Thumbs Up if you find this solution helpful.
Paul
Posted on Oct 04, 2010
It will not pick up the water. Help !!!!!
Problem #1 - My Steamvac is not Sucking!
If your Hoover Steamvac was working properly and suddenly it is not sucking any water, nine times out of ten, the culprit is the lid on the lower recovery tank. The lid on the lower tank (or dirty water tank) needs to hinge at the front and snap down at the back in order to creat a proper seal. If the lid snaps on but is not locked on at the front, you will not get any suction. Simply take the lid off, and ensure that when you put it back on, it must hinge on the front tabs of the tank.
Problem #2 - My Steamvac is still not Sucking!
Right now you are thinking that you shouldn't have let your brother borrow your Steamvac. And you are right, because he used the hose attachment and returned it with the hose still attached to the front of the tank (some models only). Now when you try to use it there isn't any suction. In this case, you are missing your tank duct. On models where the stair/upholstery hose attaches to the front of the recovery tank, one must remove a square plastic piece in order to attach the hose. This square plastic tank duct must be replaced before the Steamvac will operate properly in the upright position. hope this helps ive copied it
Oct 09, 2016 | Vacuums
My hoover steamvac wont **** up dirty water float
Check your filter screen insde the upper tank. if your model has a wrap around filter try to pull it down about 1/2" to maximize air flow.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Apr 15, 2010 | Hoover F7431-900 SteamVac Vacuum
My Hoover Steamvac Widepath will NOT pickup the water after dispensing. I checked the hose inside the cleaner, there was a cut in the hose so I put electrical tape and completely sealed the cut. Still...
Hi, empty the recovery tank of the Hoover SteamVac if the cleaner fails to pick up dirt. Once the tank is full, many Hoover models have an automatic shutoff that stops the cleaner. If the does not resolve the pickup issue, check the hose of the machine and remove any blockage.
Examine the water tank if water does not dispense from the SteamVac. It could be empty and need of a refill, or you may not have locked the dispenser firmly in place. The detergent tank should also be looked at and filled if empty.
Take care
Apr 12, 2010 | Hoover F6213-900 SteamVac Agility...
Hoover spin brush model f5914-900 wont draw water back out of carpet
Please remove the recovery tank and check and see there is a black rubber ring seal on the large vacuum tube that rises from the base to meet the bottom corner of the recovery tank. This rubber seal may have fallen off the tube and be found laying under the hood. It seals the vacuum source to the recovery tank.
Oct 28, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Can't figure out how to get my hoover runabout steam vac to pick up
Assure the ring gasket is in place under the hood. A round rubber gasket must be in place on the round tube under the hood where the recovery tank sits to connect the vacuum from the motor to the round tube on the bottom of the tank.
Also be sure the recovery tank lid is properly aligned to the recovery tank.
If you are unsure about operation, please reference the following manual:
http://www.hoover.com/pdfs/manuals/F7431900.pdf
Oct 05, 2009 | Hoover F7431-900 SteamVac Vacuum
Jul 19, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Recovery tank not working
recovery tank empty where do you look to see where the hair ball is so i can clean it
Mar 28, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steamvac Deep Cleaner
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40578&thid=661545
Hoover SteamVac Deep Cleaner
Posted by Alex987 on Jun 10, 2008
I can't seem to figure out how to use it =(
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5807 SteamVac Wet/Dry Vacuum. Well, there are 2 tanks, one is the water solution tank that is on top and the other is the water recovery tank of which is on the bottom. You use the trigger assm to release the water and the Hoover SteamVac works the best on the pull back. You can spry the water going forward but pull it back very slowly and let the brushes do the scrubbing for you and the dirty water pickup. There is a ball in the dirty water pup tank that will rise to the top and stop the water from coming in, @ that point you need to empty and rinse out the recovery tank and re-install. If you run out of solution the top tank cap or cover is the measuring cup to determine the amount of solution – usually it is one cap full and extremely hot water, there is a switch for the carpet and the upholstery, if the handle is in the released position then the brushes down below should be moving – just look in the brushes window and see if they are moving – if the handle is in the upright position then you can remove the attachment hose and then use the attachment and the revolving brushes will stop. I hope this will help you in working with the Hoover SteamVac. If not contact the Hoover Co and get an owner’s manual and give them the model # and serial #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 10, 2008 | Hoover F5807 SteamVac Wet/Dry Vacuum
Hoover SteamVac LS F5899-910
Did you try to clean first the unit..
Jun 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Replacing valve on water tank on hoover steamvac
buy the whole tank not worth the time to repair the valve
Oct 08, 2007 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
295 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
