Question about Canon PIXMA iP4200 InkJet Photo Printer
Printer My canon pixma IP4200 has been showing a message of 'Some ink tanks are not installed in place. Confirm that the following ink tanks are in the appropriate position.' & when you press the ok button, it just pops up again & won't print.It's been doing this ever since I changed the 3 colours, but is only saying that the yellow is not in place. Is there any way round this?Regards, Nicola
  • 1 more comment
  • Anonymous Feb 10, 2008
    Yes, i have the same problem.Cartigdes lightness red up and the message still comes back.The printer doesnt do a damn thing.
  • thursodog Feb 10, 2008
    I have since fitted a proper canon ink cartridge & it works fine, it seems my printer doesn't like 'compatible' cartridges.
  • lizzie lady Feb 21, 2008
    Message says more than one ink tank of Yellow is installed and so can not print--- removed and replaced cartridge, cleaned the contacts
You Need 3 Sets Of Cartridge's.Number Them 1 - 3. After Each Refill Put Next Set Cartridge's In .
Posted on Feb 13, 2008
Sounds like you head has gone. JO
Posted on Feb 09, 2008
Installed new ink on ip4200. Black will not print on test page "horizontal box", other colors print. Any suggestion on why the black won't print? Thanks.
The ink tank requires air to flow through it so ink can move from the reservoir to the print heads.
  1. Confirm there is no orange tape across the top of the ink tank
  2. If the orange tape is as shown in Figure (A), it is properly removed.
  3. If the orange tape is as shown in Figure (B), remove the remaining tape to the level shown in Figure (A).
  4. Make sure each ink tank is snapped into the printer.
Aug 26, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
Tip
Duplicate Cartridge Error - Which one is causing it
The purpose of this exercise is to rule out ink tanks that are behaving and isolate the one(s) responsible for the duplicate. Please perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3. Confirm whether the printer recognizes the installed tank properly. If it does, it will indicate it does not detect the other ink tanks, as they are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5. If the printer at any time indicates two of the same ink tanks are installed, the cause will be the last tank installed. For example, if you inserted an ink tank earlier, and you later inserted another ink tank, and it said two of the same inks were installed, the cause of the issue is the last ink tank.
Hope this helps
Mike
on Aug 04, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Why does my canon pixmar IP4200 keep saying two
Maybe one ink chip is faulty. Try to remove one and leave in the other (do the same for each one) to see if printer says something different. Otherwise your ink sensor could be broken.
May 16, 2010 | Canon Pixma MP500 All-In-One InkJet...
THE ORANGELIGHT ON FRONT OF CANON 1P4200 PRINTER FLASHES SEVEN
From manual:
Seven Flashes: The ink tank is not installed in the appropriate position
Possible causes are as follows:
More than one ink tanks of the same color are installed.
Confirm that the ink tanks are installed in the appropriate positions.
Jun 09, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Replaced two ink tanks in my pixma but the lights will not flash
You cant realy do anything, i had the same problem whit my IP5000.
I tryed everything but nothing helped, after speaking whit canon here in sweden they told me to let it be, after next tank instalation it will disappear and you printer will be as usal again. Canon told that the problem is on the chip on the tank. When the printer tell you that the tank is empty or not right just press the blinking yellow button on the printer and hold it for at least 5 seconds.
Good luck
Dec 04, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon Pixma ip4200 printer, error 1414
Hello there,
I've gotten in touch with Canon and have something a little different to try. At the very least the error should change. (Sorry, gallows humor). Please read this entire response before taking action.
After the upcoming test procedure, I have included a link and procedure to contact Canon tech support. The assure me they will replace any faulty tanks.
The purpose of this exercise is either rule out ink tanks that are behaving or isolate the one(s) responsible for the 1414. You should write down the results of this test. Please perform the following:
Click here for the Canon PIXMA iP4200 support page
Then click on e-mail support.
Fill out the form.
Under description, supply the following info:
Error 1414 Ink tank problem on my Canon PIXMA iP4200
The error won't go away.
I have replaced the <color in question> tank, reseated it, yet the error remains.
You will also need to list what inks are being used in the printer. State the type of ink that is being used and the order that the tanks are installed in the print head.
Provide the exact part number (such as BCI-6C, BCI3eBk, etc.) if possible.
The Canon support rep assured me they will be glad to replace the malfunctioning tank(s) for you at no cost. Please
respond with the results, and specify the ink tank(s) that were not recognized correctly.
They responded quickly, professionally and apologetically. They want to help get this resolved for you.
I hope this helps end the frustration you must be feeling. If you need additional help or clarification, click the ASK button.
Mike
If you could take a moment and rate this response, I would appreciate it.
Jun 30, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon pixma ip 4200 printer problems
in the printer driver there is a option that whenever you install a new cartridge it has to be reset otherwise it shows the message the above you quoted. one more option is there that is change the chip of yellow cartridge and black, after doing this please whip circuits of the cartridge and printer carriage block before installing the cartridge
Apr 15, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
IP4200 duplicate ink tanks.
Hello there scubadave,
I've gotten in touch with Canon and have somethinga little different to try. At the very least the error should change.(Sorry, gallows humor). Please read this entire response before takingaction.
After the upcoming test procedure, I have included alink and procedure to contact Canon tech support. The assure me theywill replace any faulty tanks.
The purpose of this exercise iseither rule out ink tanks that are behaving or isolate the one(s)responsible for the dupliucate error. You should write down the results of thistest. Please perform the following:
3.Confirm whether the printer recognizes the installed tank properly. Ifit does, it will indicate it does not detect the other ink tanks, asthey are not currently installed in the printer.
5.If the printer at any time indicates two of the same ink tanks areinstalled, the cause will be the last tank installed. For example, ifyou inserted an ink tank earlier, and you later inserted another inktank, and it said two of the same inks were installed, the cause of theissue is the last ink tank.
Fill out the form.
Error- Duplicate Ink tank problem on my Canon PIXMA iP4200
<Describe how error occurs>
I have replaced the <color in> question> tank, reseated it, yet the error continues.
Youwill also need to list what inks are being used in the printer. Statethe type of ink that is being used and the order that the tanks areinstalled in the print head.
respond with the test results, and specify the ink tank(s) that were not recognized correctly.
Remember: Good things happen to those who Rate.
Mike
Aug 06, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Ink tanks not lit but not empty
Hello there,
Fill out the form.
Mike
Apr 04, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Installed non canon toner cartridges
wilba, I found some info on how to make sure the cartiges are seated properly but it wouldn't paste over...so here's the site: http://www.usa.canon.com/consumer/controller?act=SupportDetailAct&fcategoryid=257&modelid=11641 Good Luck, Tim p.s. They make their money from the inks and toners...you bought from the enemy and the machine cursed you.. best of luck
Feb 06, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
102 people viewed this question
old marine
old marine
