Your DVD will be (or should be) connected to your TV using either HDMI cable, Component Cables + Audio, Composite Video + Audio or other A/V connection. Your TV remote will have an input selector that switched the source signal within your TV. This can also be called source selector. In any case, you need to push this button on the remote to rotate through sources (if only one button) or push the button labeled DVD, for instance to select the DVD inputs. Please note that only one type of connection should be used such as HDMI or Component, but not both.
1) Set your TV to channel 3. 2) Insert a pre-recorded tape into this unit. 3) Press the OUTPUT button on the DVD/VCR so that the VCR OUTPUT light is lit. • If noise appears on the TV screen, press the VCR/TV button on the remote control. 4) Press the PLAY button once. 5) After a few seconds, press the PLAY button on the DVD/VCR for 3 seconds. • The RF output channel will change to channel 3 from channel 4 and you will see a playback picture. • When a picture does not appear on the TV screen, repeat step [4]. 6) Press the STOP button to stop playback.
Look for loose contacts in power outlet, RC Jacks, sockets, cables. Change input device to some other like a DVD that you are sure works. Swith off TV, switch off power, remove plug and retry after 48 hours.
If problem persists, call in a qualified service technician.
check the close circuit switch inside the system. its maybe stuck, try to wiggle it a bit and it might work again.
the switch is at the end of the tray when it is closed, its a small black push botton swith.
be careful not to fry it when installing a new part
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback. Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder. Hookup between TV, DVD recorder and VCR is completed. Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV. Hope this info will help you.
There's a chance that when the Tv doesn't turn on, it might be because the power supply might be defective, but for a more exact info i'm missing more details, discountdashmerchantdotcom, try it they'll troubleshoot you for free and you'll see what's the issue with the tv
Can you turn it on with the remote? Do any of the other function swithes on the tv work vol,ch up,down,menu etc. If switches on set do not work check in menu for button lock feature. keeps kids from pushing buttons.
I found this on the PROSCAN website under customer support manuals.The website is www.oncorpus.com.I hope this information helps you with your problem. IMPORTANT THE LABEL SIDE OF THE DVD MUST FACE THE BACK SIDE OF THE TELEVISION 1. Press the ‘INPUT’ button to select ‘DVD’ mode, if no disc is inserted yet, the display shows ‘No Disc’. 2.Insert a DVD with the printed side facing towards the rear of the TV/DVD Player (see below) 3.The TV will first display ‘Loading’, then change to ‘DVD-video’. Most DVDs will show some preliminary information then stop at a main menu screen. 4. Press PLAY/PAUSE to play it directly. Or press the DVD-MENU button to access the disc menu during playback. 5.Use the direction button on the remote control to select the desired option. Press ENTER to select the option or press the ► button. Playback will now commence. 6.After playback, press the EJECT button on remote control or EJECT button on TV/DVD to remove the disc. Note: No function‘’ will sometimes appear on the screen after a button is pressed. This indicates that the function is not supported at the current time.
That's because this is a quad. It compresses all 4 video feeds into 1 file. When you play it back, it decompresses the video and shows you each camera. Playback through this unit is the only way to see 1 camera at a time.
To be able to copy 1 camera shot to a DVD, this is what you need to do:
You need to have a TV with Video in and Video out jacks.
Connect the Quad to the TV Video in jack and connect the TV Video out jack to your DVD Video in jack. Playback a single camera shot on the quad to the TV and hit record on your DVD. - The DVD will record whatever is shown on the TV.
