Question about Cameras
Digital photo frame
How do I transfer images from Picasa on my computer to my new digital frame
  • 871 Answers
Hi there
you can do that by inserting our digital photo frame to your computer via usb and as soon as yor pc recognizes the photo frame, you can try and sending your photo towards it. you digital photo frame has internal memory so you might wana transfer those pics there. running from picasa however, you need to explore using picasa and as soon as picasa recognises the digital photo frmae, you can transfer now.
hope this helps..
Posted on Feb 07, 2008
  • earl norman llanera
    earl norman llanera Feb 07, 2008
    another way is to use a flashdrive and be sure that the pics are insde the flash drive then insert it to the usb outlet of the digital photoframe.
Cannot down load pictures to frame from computer
The following instructions should be able to help you transfer pictures/images and music from your computer to the frame.
Power ON the frame.
Connect the small end of the USB cable to the USB port on the side panel of the Digital Photo Frame.
Connect the larger end of the USB cable to the USB port on your computer.
You will see some extra "Removable Disc" drives in "My Computer" -- One for each of the memory card slots on the Digital Photo Frame. And the last one is for the Internal Memory of the frame. Double-click on the last "Removable Disc" icon to access the internal memory of the frame. From here you can copy images and music files to the frame. You need to transfer the images or music files into this folder (which is the internal memory of the frame). Copy the files from your computer and paste them in this folder.
The picture files should be in the "standard JPEG" format and the music files should be in the "mp3" format.
To disconnect the Digital Photo Frame from your computer:
In Windows, on the bottom taskbar, right click the icon which appears in a green color, (this icon has an arrow pointing towards the left) and select "Safely Remove Hardware".
The Safely Remove Hardware" dialog box will appear. Select "USB Mass Storage Device" and click "STOP"
On the next dialog box, click "OK" to remove the storage device.
On the next dialog box, select "CLOSE" and disconnect the USB cable from your computer.
Now you should be able to see the pictures on the digital photo frame.
Thanks.
Mar 13, 2011 | Coby DP-772 Digital Picture Frame
Help i need to transfer music from my computer to my digital photo frame how do i do it
Are you having any problems with images? To get music on it, excatly like images but make sure it in a mp3 format, if it from itunes it normally in acc format etc
Dec 09, 2010 | PANDIGITAL 7" Digital Photo Frame With...
Transferring images
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com )
Jul 31, 2010 | Sharp VE-CG40U Digital Camera
Will Not View All Pictures In Photo Directory
Take the camera and tag the pictures and select all of them and tag/ favorite and protect and tag some more directories you can create. That will delay transfering the pictures but all of them will transfer to files.
Vitally
Mar 01, 2009 | Kodak EasyShare EX1011 Digital Picture...
How do I transfer pics from my computer to digital frame sv811
Connect the frame to you computer via the USB cable. Your computer should see the frame as a removeable storage device (new drive letter) if there's memory on the frame to store images. If not, then get a cheap memory card or USB key for $20 and put the images there.
Jan 11, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Transfer from computer to memory card
http://wwwuk.kodak.com/global/en/service/downloads/dln_ekn029310.jhtml?pq-path=3906/2308/2316
you haveto install driver from above link..and then try to transfer photos from camera to pc...
after that from pc you can transfer to photo frame...
Jan 07, 2009 | Nextar N7 - 7 Digital Photo Frame with...
Not all jpeg images will load on 7'' Pandigital Photo Frame
I was having a problem too with my Smartparts frame. All the pics were from the same camera but some of the vertical (portrait) orientation shots wouldn't show right. Just a bunch of thin colored lines. After some phone calls I did try to "resize" the photos to the "resolution" of my frame (had to look that up too). My frame is 640 width by 480 high. So I took a shot and changed all the goofy photos to 480 width (since they were vertical) and let Photoshop change the the other number. Low and behold the buggers are showing up fine now. Well on to my next problem - focusing with the new D90. I think that one is going to be more challenging yet. Hope this helps you out.
Dec 30, 2008 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Card read error on the digital picture frame - brand new. I bought this 7" digital photo frame from argos and I insert the SD card whilst the device is turned off, when I turn it on the message reads...
Put the card back into the camera and off load/take off your pictures (Put them on the computer). Then, put the card back into the camera and go to your options menu. Find the format feature, and format the card. Take some new pictures and then try putting the card back into the picture frame. Does it work? If so, transfer the images from your computer back to the card. If it continues to work, then Great! If not, more than likely there is an improper or corrupt file among your photos.
Good Luck!
Dec 12, 2008 | PANDIGITAL 7" Digital Photo Frame With...
How do I load pictures from my computer to the memory card in my camera?
You have to first download the images to your computer and Save them in a folder. Then connect the USB cable from the digital photo frame to the computer and transfer the photos you want onto the frame. Some time you have to change the photos name to alphabetic order so you photoframe will display the pictures in the correct order.
Feb 20, 2008 | HP Photosmart 635 Digital Camera
Cameras Logo
327 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
