Question about Philips Magnavox 9P6034C 60" Rear Projection Television
TV HAS HIGH PITCH SOUNDS
I HAVE A 60IN PHILLLIPS MAGNAVOX TV. WHEN THE TV IS ON, A HIGH PITCH SOUND COMES FROM THE TV. COULD IT BE OUT OF BALANCE? IT SEEMS WHEN WE PICK UP THE FRONT OF THE TV IT STOPS.
  • angie Feb 07, 2008
    IS THERE AN EASY FIX FOR THE HOT HIGH VOLTAGE TRANSFORMER? IS IT A COSTLY REPAIR?
  • suleiman Feb 23, 2008
    My TV also beeping sound that comes from it when it is turned on. It is a bit high pithched and the screen is black. Occasionally you can hear the voice from a show on the TV. What do you think is wrong and how much would this cost to repair?
THANK YOU FOR YOUR HELP!!!
Posted on Feb 07, 2008
    President:
  • 4,402 Answers
Most likely the HOT high voltage transformer is squeling
good luck
please mark the post with a fixya
  • Cary Farah
    Cary Farah Feb 07, 2008
    the transformer is 100-200 plus labor, not to hard to fix be dangerous it has high voltage that can kill a person if you don't know what your doing.
How do i fix this problem ? clanking high pitch sound coming from intake.
have a compression test done as it may be a loose valve seat insert
balance shafts are just shafts and unless you have done a bearing for the shaft it will not make a clanking sound as there is no pressure applied to the shaft
basically a balance shaft is like a flywheel that takes vibrations out of the motor
Oct 26, 2015 | 1991 Buick Park Avenue
I have a philllips 60in rear projection model num 60p8342a just has red green and blue lines accross the screen no sound untill i power off then picture will flash for about 1 second and turn off any i...
Most likely bad convergence chips--set uses two of the stk-392-120 chips and in this case one is shorted--only way to prove it is unsolder all 18 pins on each chip and see if set powers on and stays on---will look bad but you will know one of the chips is your trouble.
May 28, 2012 | Philips Televison & Video
Hi: My Magnavox flat screen turns on and off. It also makes a high pitch noise and then there is no sound and it also shuts off. Is it worth fixing?
Hello, what's the model or size of screen for the magnavox, the high pitch noise could be an audio power amp starting to get intermittent, and the power on/off could be due to the over current sensor circuit detecting the audio problem. Depending on the model number you would have a seperate power, audio and signal board in the TV. If he TV is 27" or smaller all these circuits are part of a mother board.
Jul 28, 2010 | Televison & Video
I have a Phillips Magnovox Projection T.V. It's making a high pitch sound, after it comes on for a few seconds it shuts off. I have to keep hitting the on button several times, it then stays on, but the...
Hi,it sounds like a problem with the color wheel.The color wheel is a disc looking that the light of the lamp goes trough it to create the colors .It spins at very high rpms and through time it will begin to go bad and it will make that loud humming noise.Here;s instructions to replace the color wheel: http://guides.fixyourdlp.com/samsung/bp96-01579a.php Good luck and May God bless you!
Oct 20, 2009 | Philips Magnavox 9P6034C 60" Rear...
Sound trouble
If you have a cell phone or wireless internet this may cause interference. If you have any of these close them out and see if it still does the sound.
Feb 15, 2009 | Sony KV-27XBR45 27" TV
TV wont come on anymore
Common problem. Check the site www.tvrepairkits.com. They should have a kit to fix it.
Oct 05, 2008 | Philips Magnavox 9P6034C 60" Rear...
Sound but no picture 60in phillips television
I beleive you can get a chip to fix this problem from www.magnavoxhelp.com.
Aug 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Mitsubishi HD1080 60in TV
First do a self test diagnosis. you can search Mits tv or read my solutions.
Mar 10, 2008 | Mitsubishi VS-60609 60" Rear Projection...
High Pitch sound during spin cycle
sometimes the high pitch will come from rear bearing open door pull up on basket see how far it moves up down also ck the pump for thngs in it
Feb 24, 2008 | GE WPXH214A Front Load Washer
Ringing sound
i would first try to located inside where it's coming from most of the time it's the high voltage fly back needs to be reseated
Jan 03, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
149 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
