Question about Epson Stylus Photo RX620 All-In-One InkJet Printer
Scanner error on screen
I am getting a scanner error on the screen and it makes an aweful noise. I cannot see anything visibly wrong inside or out. Have turned off and on with no help to problem. It happened immediately after I replace one empty ink cartridge.
  • 1 more comment
  • boost14me Feb 15, 2008
    I have the same problem. Scanner error and a loud clunking noise. Help! thanks, G
  • rx620 user Feb 24, 2008
    same problem on Epson PHOTO RX620 tried resetting but doesn't work, still makes noise and gives error message. right after I changed ink. I opened scanner before hitting OK, but then proceeded to change ink. when i closed, it finished printing, but now makes noise AND error message won't go away. please help
  • mompace Jan 27, 2009
    It worked!
    Genius:
  • 1,447 Answers
Turn off printer, open scanner cover. On the right handside of scanner glass there is a switch in which you can toggle to lock and unlock position. toggle it 3x and set it to unlock. turn on printer. you should be able to make use of printer now..
Posted on Mar 01, 2008
Scanner error 14
the problem with scanner assembly
Mar 20, 2013 | HP LaserJet M1120 MFP All-In-One Printer
Dryer starts then makes aweful noise then stops timer keeps ticking then when you try to start it again it doesnt do anything
If it is a grinding noise then it is probably a bad bearing. If it is more a squell it could be the belt slipping in addition to a bad bearing. If it is a banging sound it could be the belt.
Jun 19, 2011 | Dryers
Delonghi coffee machine making an aweful noise,
Hi. Husband asks: When you first turn the machine on at the power point, does it make a motor sound and then stop, or is the awful noise apparent at that time.
If the awful noise starts as soon as you turn it on, then most likely there is a motor problem which will need to be seen by a Service Center.
To locate information about De'Longhi in your country, refer to http://www.delonghi.com/
May 24, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Won't print; making a funny crunching noise; dialog screen says "scanner bulb warming up"
This is a problem in scanner section on your printer.You need to disassembly the printer and pull out the scanner section.Open the cover of scanner section and you'll see the mirrors inside.You need to clean the ash from these mirrors using cloth which leaves no hairs.
WARNING! If you don't have a technical skills don't try to do anything.
If this not help you need to replace the scanner section.
Oct 28, 2009 | HP LaserJet 3330 All-In-One Printer
Canon pixma mx700 error code 5010
5010 is a scanner error from the scanner on top. Canon has no parts for these and you can only replace the entire top of your machine. If you can get it apart, you might clean and lube, but it's not made to be opened.
Jul 03, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Hidden files are not showing
Hi there.
It sounds like you have a virus on your machine, apart from not being able to view hidden files and folders is there anything else thats going wrong with the PC at all?
for example on start-up do you get any strange error messages or has the recycle bin name been changed?
Jun 08, 2009 | Microsoft Windows XP Professional
My record player works but makes an aweful noise like the turntable in rubbing up against somethin
If it is a loud hum besure there is a ground wire connected to the back of the receiver from the turntable.
Apr 24, 2009 | Audio Players & Recorders
Getting error code Code[ffff:0024]while scanning
while i am trying to scan the images .. i am getting the error code like Code[ffff:0024] while warming up the scanner, besides a sound from the scanner making it power off (light inside the scanner goes off ) so that i could not get scanned anything ... what will be the reason ? please suggest me the trouble shoot kaarthik
Apr 14, 2007 | Acer Scan to Web 3300U Flatbed Scanner
Epson Stylus Photo RX620 All-In-One InkJet Printer Logo
719 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
