Question about RCA 13R400TD 13" TV
Phillips 27" flat tube tv
The top of the screen looks as if the picture is folded over in to the picture, many fine lines in the upper part of the picture. At the very top of the screen, about 2 inches is black.?
When I turn the tv on there is a fine blue line at the point to where the fold ends.
  • RCA Master
  • 1,229 Answers
You have a bad capacitor. It is located near the flyback transformer. Location is 2465 and the value of the cap is 100volt 10MF @85 degrees. Substitude it with same value at 105 degrees. Have another round and a sixpack to go this evening.
Posted on Jul 24, 2009
  • matt martin
    matt martin Jul 24, 2009
    PS....There is one more important capacitor to replace. I cannot remember the exact location but you will find it. Looking north of the Horizontal output transistor you will see black transistor (regulator IC) located on an heat sink near the edge of the board. The capacitor you will be definitely a 1MF. Votage is 160 or 250 at 85 degrees. Replace with an 105 Degree cap of same value. There is only one cap on the board with this value. This one will continue your start ups and by now is weak. Now finish your drink!
  • 579 Answers
This is a vertical sweep problem. very common. Usually a dried out electrolytic capacitor in the vertical circuit. They are cheap parts. Just replace all of them in the vertical circuit (probably about 4 of them of different sizes).
Hope Ya Fix It.
Posted on Feb 07, 2008
  • 3 Answers
Go to menu. u have a horazontel problem
Toshiba 27WL46 27 in.LCD- Lines top of screen getting worse.
If they are vertical lines, then the LCD panel is going bad, it will get worst with more lines appear as time goes on.
Jan 07, 2010 | Toshiba 27WL46 27 in. LCD Television
My 27 inch emerson flat tube tv only shows the picture in a thin strip how do i fix it back to normal
You will need to replace the Horizontal IC around $80 bucks for the parts and labor. What happen here is when the Horzontal ic gives out the screen basically folds to the middle. Do not shoot the messanger here but have the TV looked at by a professional locally.
I hope this was Very Helpful to you today please leave your feedback and ratings.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Dec 07, 2009 | Emerson EWF2703 27" TV
Horizontal lines on top of phillips tv
bad feedback electrolytic in vertical circuit. need tech.
Nov 23, 2008 | Philips TP2797B 27" TV
Philips 27PT6441 27" TV Problem
jon5902,
Pls note that my experience is with the phillips 27" model27PT6341/07. It may not be the same board as yr model, as I can't remember nor find the service manual anymore. (browse around online for it though)
However, after taking the back off. Look close to the rca jack and svideo connection. Mine is located about an inch from the svideo connection.
Here are some pics that may help you.
http://farm4.static.flickr.com/3215/2337629026_eaa30cfa18.jpg?v=0
http://farm3.static.flickr.com/2411/2337627420_b45bbf1a74.jpg?v=0
The new one is the black and gold one marked 10uf 100v in the pic.
Other users have advised to go as high as 10uf 250v, to avoid having the cap overload again.
PS. I had the lines for about 2 weeks. They got steadily worse then one day my tv looked like it was broadcasting an hourglass. The lines converged in the center and flared outward (no pic).
Sep 10, 2008 | Philips 27PT6441 27" TV
Elongated picture on Sylvania 27" Model # SRT2232S
there is a vertical adjustment on the picture tube it's the yoke as it's called but you can adjust it so much..but it does sound like the tube is on it's way out
Aug 28, 2008 | Sylvania 6427TE 27" TV
2005 phillips crt 27 inch tv
need electrolytic capacitor replaced in vertical circuit
May 07, 2008 | Televison & Video
Lines coming down from the top of screen
Those lines are beaming in from the planet Alenod. For the moment you'll only be annoyed by those lines. But when those lines finally expand the entire surface of your screen you and everything in your viewing area will vaporize. Gosh, If I were you I'd chunk it as quickly as possible and buy a 47" Vizio! They're on sell at Sams! Pleeze hurry!!
Mar 05, 2008 | Televison & Video
Horiz. lines across top of screen.
I agree with solution #2
I recently had my phillips 27" model 27PT6341/07 repaired after warranty expired due to white lines appearing at the top of the screen. The shop advised that it was a capacitor giving me the problem. So, after getting it back, I examined the repair job and the shop had replaced a capacitor at the back of the main board, next to the rear rca inputs. It is labeled 10uf 100v. I was told that it would fail again soon because it is a manufactures defect. For me it is at location 2465. Here are a couple of photos of the part.
Good luck,
Ed
Nov 13, 2007 | Philips 27PT6441 27" TV
Sylvania 27 inch stereo flat screen tv
This problem sounds like a short inside the picture tube itself unless a driver transistor failed that drives the red gun in the CRT. You may have to take it to an authorized repair facility if the picture tube is still in warranty.
Nov 10, 2007 | Sylvania 6427FF TV
Tv problem
Bad capacitor in vertical output IC circuit + check power supply
Last, replace IC.......................T.
Nov 09, 2007 | Philips 27PT6441 27" TV
RCA 13R400TD 13" TV Logo
166 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
