Running screen I have an older model TV that's running constantly horizontaly. It use to run until it warmed up but now I can't get it to stop. I have a number I took off of the Picture tube inside That reads Model # CS-27401 Serial # 007749. Can you help me.
  • symario Feb 07, 2008
    Mitsubishi television 25/26 in
    Genius:
  • 1,694 Answers
No vertical sync lock caused by bad caps on PIP module..
REMOVE module.....solder 22mf / 50v NP capacitors
on bottom of PC board ..VP connector pins 5 to 11 and 7 to 9.
Picture will be stable.....forfeit use of PIP box feature.........T.
Posted on Feb 08, 2008
  • 3 Answers
Go to menu then horizotel set it so it wont have lines
Posted on Feb 07, 2008
I have a L.G. Model #DU-42py10x 56in tv that has red and green vertical lines on tv when started up. does it need a new chip?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 11, 2014 | Televison & Video
Sharp 32 in lcd tv has small horizontal black lines throughout whole tv
a model number may tell me more===trace lines at a slight angle?
More information needed here----
Mar 23, 2012 | Televison & Video
My sharp tv 21" model 21AG2-S have three colours
screen not coming coming standby only display led light
Oct 31, 2011 | Sharp VT-G21 21 in. TV/VCR Combo
I have an older model Sears Craftsman air compressor, 1 hp, 100 psi, twin cylinder. Model 106.154541. The compressor comes on fine, but when the pressure gets to 40 psi or so the belt starts to squeal,...
Could be the bearing in the pully wheel rides on,,not the belt,,,While its running spray some belt dressing on belt to see if its the belt,,,while running get a can of wd-40 with long nosel attachment and spray the armeture that tures pully when you spray it if its the bearing it will stop makeing noise momentarly, than come back again than as you spray it it will stop as long as you spray. BE CAREFUL. Bearings wear out when old,,,like us!
Mar 11, 2011 | Craftsman Air Tools & Compressors
36 inch tube tv - Screen flickers
my problem is don't sound in my mobile LG CE 0168 please help me.
Aug 17, 2009 | Toshiba Televison & Video
Fan runs constantly never turns off
You need a professional.
Stop using the TV until it is repaired.
Continue to use it and your problems will multiply and grow more expensive.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Toshiba 62HM95 62" DLP HDTV
Picture not centered and not stable
this tv does not support v.hold button.
its time to change the tv
Feb 25, 2009 | Sanyo DP19648 19 in. LCD TV
Sony Trinitron KV35V35
Could be a weak Picture tube . You can try turning up the screen control but don't turn it up too much you'll get retrace lines in the picture . Turn it alittle at time until picture comes on then turn it down until the retrace lines go away . Then try turning the tv on and off to make sure it comes back on. Be careful you can get shocked if you do this while it is on and you touch one of the circuits . The control is on the flyback or the module thats on the picture tube it will say screen by it . If this does not work you could have vidoe problems or just the picture is no good . Good luck
Jan 20, 2008 | Sony KV-35V35 TV
I suggest you take your TV to a repairman. The TV will need to be opened up and some adjustments made to the board.
Nov 26, 2007 | RCA F27242GY 27" TV
Red and Green
A screen drive issue is at hand and will require the help of a shop to get it back up to snuff....accordianman
Sep 11, 2007 | Samsung HC-P4363W 43 in. TV/DVD Combo
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
