Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony32fs120 I think my board blew. The tv fell and a piece of the board broke off. I tried fixing it by jumping the circuits. When pluging in the mains it goes into protetion mode. I checked continuity and it seems fine. I tried to get a diagram but witout success. here in South Africa you do not get other boards that will fit, and to import one will cost too much then I can just as well buy a new tv and will sadly would have to let the sony go Can you please help? Johan Sorry for the bad english
    Problem Solver:
  • 5 Answers
1. Try your Memory to replace.
2. Check all estated voltage in each particular section.
3. TRy also to replace your MICOM / System IC if your Confused.
Posted on Feb 21, 2008
Lightning struck my house and my tv went out I think it blew something in it like the circuit board are ther more than one board in these tv
If the power light doesn't come on then first look for a fuse. It's very likely a fuse. If all fuses are good and power comes on you might have lost a circuit board. Check eBay for boards. Part numbers are printed on them. They just unscrew and unplug. However it could be either board.
Dec 11, 2014 | Mitsubishi WD-73C9 73" DLP TV
Emerson TV SN: 011-40401078 Model TC1379 The power switch came loose and fell inside. I don't know if it broke or came apart. I only found the plastic piece and don't know how it attaches...
Well somtimes buttons break off of tv's because that they are old so its not worth fixing an old tv
now a days most people just buy a new one then instead of fixing the old one. Or you could find someone that fixes old tv's too. To find an old tv like the phiilps one we used to have you would probally need to go to an antique store or and a pawn shop or a secondhand store or a garage sale then. Or the dump because sometimes people put things in the dump like CRT tv's to get rid of them then.
Aug 22, 2011 | Emerson TC1351 13" TV
My tv fell and I think the sensor is ruined. The remote now won't work. The plastic isn't broke, but I think sensor is broke as the tv fell on it's face.
most of the time, the circuit board cracks around the remote sensor, when there is a fall like this. the TV will have to be taken apart to check this. Do you have that capability?
Nov 30, 2009 | Samsung TXN1430F 14" TV
Need Location of Part # on right front circuit board (if looking at it from the back of the tv) I just finished soldering in new IC heat-sinks on this board and set on top of TV and a cat jumped on it...
I think you will find the board for this set is not available or if it is not at a reasonable price.
Usually if a fairly small part of the board is broken off it can be repaired-----I can tell you what is involved in this type of repair if you give me some idea of how bad the damage is.
I have repaired circuit boards broken in half---once fixed they are not pretty but will work perfectly.
let me know if I can help you--I am here to help.
SD TECH
Oct 09, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
3 blinking power button lights RCA R52WH77
have you tried checking some voltages in the convergence board it could be the damage is there and not the deflection board since the 320vdc was connected thru the yoke. you can also try to deactivate the convergence board to see if the tv set will remain on this will give you a better idea of where the problem is. good luck!
Aug 13, 2009 | Televison & Video
Sony 32fs120
If this is indeed a Sony KV32FS120 then I would bet your CRT'S shadow mask is warped severley as well which will cause many rainbows in the picture once the set is up and running. Count the loss and replace the set.
Feb 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a 27 jvc tv
The connector that just fell off when the cable was pulled will have to be replaced by a service center, Sometime the connector will just come out ot the solder joint and can be replaced. Sometimes it breaks off part of the circuit board, if it broke the board it is not likely that anyone will be willing to try to fix it.
Nov 29, 2007 | JVC HD-56G886 56" Rear Projection HDTV
Tv wont ome on
noavatar_s.png By nonexpert_s.gif Greasmonk
Rank: Apprentice
Rating: 0%, 0 votes
Heres what mine did:no picture no sound, when i hit the remote the indicator light went out....piece of crap is six months old, cant find any info on it, cant get a hold of anyone at Trutech.
So i took it apart, on the board that the power cord is attached to, i found six blown capacitors. There is also a big ass one in the middle of that board which looked ok but blew out the bottom.I replaced them, and im watching it as i type.
Its fairly easy but if your not comfortable soldering on a cheap circuit board, take it to someone.
I hope it helps, i think this repair will fix the other Trutech models with the same problems.
Eric
ed44309@hotmail.com
Oct 02, 2007 | Toshiba 42HP84 42 in. Plasma HDTV
Fd trinitron kv-27fs320
I think you may have a cold solder joint or burned loose connection somewhere in your power supply. Also maybe a crack in the circuit board. apparently when you moved the tv you "fixed" the problem temporarily. Stargazer
Jan 23, 2007 | Sony FD Trinitron WEGA KV-27FS320 27" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
