Computer After trying to reformat my old computer I really screwed up the settings by messing with things I should not have.Now it says boot disc failure insert disc and follow instructions on screen and press help.I think I changed the cmos,c. and bios setting and don`t know how to change them back or what they should be.Can you help?Thanks -Jerry-
  • Anonymous Feb 08, 2008
    Well I`ll try 1 more time with this thing before I shoot it.I know it will still work because I`m the one who messed it up and also know you can`t help me if I don`t get the right info to you.It is an A Open 256 Pentium MMXCPU at 200MHz.Memory test ok 65536K.But now at the end of boot up it says no fixed disks present.Thank you --Jerry-
  • Jerry Feb 08, 2008
    At the end of boot up it now says no fixed disks present,It is A Open 256 Pentium MMX@200MHz,memory test ok.I know I screwed up settings but don`t know how to get them back.
    Genius:
  • 1,142 Answers
You will have to do some steps to fix this up
if you have a desktop system...
1. open your system...replug the hard drive connections.
2. you can see the battery on the motherboard...reseat it
3. rest your bios to factory defaults
4 after that initiate the format
plz specify the system model you have..it will help me in gioving you a better solution
Posted on Feb 08, 2008
If you do not have disc contact your administrtor or computer manufacturer for assistance
Looks like the hard configuration in the BIOS is messed up and needs to be factory/default. Instead of UEFI, set it to legacy/CSM.
If that doesn't work, then the hard drive is either wiped and formatted or Master boot record (MBR) is screwed up.
The MBR is easy thing to fix, simply grab a windows disc, boot it into there, and then look for the command prompt and run these commands
fixmbr
fixboot
For Windows 8 and above, its these
bootrec /fixmbr
bootrec /fixboot
Exit and reboot. Should now be able to see Windows to boot into this time.
Mar 09, 2014 | HP Pavilion ze4300 Notebook
My computer is messed up. It's a Acer brand desktop computer with windows Vista. i have it for a few years. Yesterday when i turned the power button on. After it shows the Acer logo it went to a black...
I'm sorry to hear that. It could be a couple of things.Are you getting any beeps? I would first unplug the power cord. Next I would take the cover off to expose the motherboard and computer internals. Not sure what it takes for an acer. Usually there are screws in the back side. By taking them out side cover should come off and expose internals. Check to see if inside is really dusty. If it is, try blowing out with compressed air. I use the kind you buy at office supply. At this point try to take ram stick off and back on. Try powering back on hopefully this did the trick. If not do you have your original discs, I would try booting up with recovery disc and try repairing pc this way. It should step you through it.
Hope this helps
Mar 19, 2011 | Computers & Internet
How to reformat the computer?
To reformat the windows vista.There are two options to approach the reformat:
  • Option #1: Boot from the Windows Vista DVD. This is more complicated to do, but it destroys all data and partitions.
  • Option #2: Re-install Vista without leaving the desktop. This preserves the previous installation in a folder called Windows.old. Not all info is wiped, however, and you can't destroy your partitions.
First, restart your system. When the computer starts to boot, look for an option before you get to the Windows screen that reads: “Setup” “CMOS,” or “Bios”. This varies between manufacturers. For example, on the boot screen, it says:
“F2 =Setup”.
The option will flash by quickly so be ready for it and react quickly. You may need to reboot a few times to catch it.
Once in the BIOS, look for a setting that says "Boot" or "Boot Sequence". You might have to dig through the menus with your keyboard’s arrow keys to locate the setting. In the listed as Boot Sequence. And to navigate to Startup, then Boot, and then Boot Priority Setting.
When you find the setting, change your DVD drive so that it occupies the top of the list. The hard drive that contains Windows Vista should be listed as second in the boot list.
And put the Windows Vista installation disc in the designated drive. Now, select the Save Changes and Exit option in the BIOS. The computer will restart and will attempt to read the optical drive you just assigned as the first bootable drive.
The system will use the Windows Vista disc to boot and the reformat and reinstall process will start. But You will need to reinstall any programs that are not bundled with Windows Vista and reinstate your preferences and personal files after reformatting the computer and reinstalling Vista.
Windows Vista Home Premium Edition upgrade Click here.This downloadable version of Windows Vista is an upgrade only. Users can upgrade to Windows Vista Home Premium from Windows XP Home or Windows Media Center edition.
All the Best!
Sep 05, 2010 | Microsoft Windows Vista Home Premium...
Bought used toughbook on ebay, no hard drive or OS. using my old hard drive from broken one. get to bios screen, but will not boot up into windows. I'm guessing some drivers may be jacking me up, how do I...
reformat the had drive and install a fresh copy of OS from the compact disc.... once the installation is complete, boot up the computer again... if it works, then every thing is perfect....you can go ahead and install the drivers for your devices in the compter...
please clarify if you have any further troubles in installing the OS in your computer...
May 07, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Restore to factory settings from recovery disc
ok providing you have a restore disk here are the steps that you need to take
first thing is that you have to start the computer and (depending which computer you have) hold the f12 key it will show which you would like to boot first menu (make sure your vista disk is in) goto boot cdrom fist follow instructions this should get you back in to reformat and reloading vista
Dec 10, 2009 | ASUS Essentio Desktop with Intel Pentium...
I have an acer extensa 2305wlmi....i have 3 discs how do i reformat my computer backto factory one says disc1 bootable the others say disc1 and disc 2
The disc1 bootable will be the one you start with. Place the disc in the drive and then power on the computer. If the computer doesn't boot from that disc and instead boots to the old operating system, you'll need to get into the BIOS and make sure that the CD/DVD drive is set to bootable and that the priority is set higher than the hard drive.
Aug 13, 2009 | Computers & Internet
Set-up not working on sony dvd
After reformatting a computer, inserting an optical disc into a drive will not allow it to autoplay (there is no operating system to take control of the situation). If the disc is bootable and the BIOS is configured to allow booting from an optical drive, restarting the machine with the disc in it should allow the system to boot off of that disc. If this is the problem you are trying to describe, press whatever key (F2, F12, Del, etc) allows you to enter your BIOS setup program and ensure that your computer will attempt to boot from your CD/DVD drive, save your changes, and allow the computer to reboot. This should solve the issue.
Jan 17, 2009 | Sony DRU-820A DVD RW Dual Layer Burner
Help
This kind of device its usually a plug and play thing. are u using it as a slave or a the master disc?? make sure the that u plugged it in the right spot, and that the jumpers are correctly positioned. if this isn't your problem, i would recommend doing a zap on it, and the formatting it
Dec 27, 2008 | Computers & Internet
Computers & Internet Logo
330 people viewed this question
Alun Cox
David Payne
David Payne
