Question about Audiovox VE920 9" ULTRA-SLIM DROP-DOWN LCD TV WITH DVD&SPEAKERPHONE Television
Bad sound Ihave tv hooked to dish network ch#116. Has pic but sound is all static Ch#117 has no pic but sound is there. I need to scan manually but don't know how
    Champion:
  • 206 Answers
Being as the set is hooked to a satalight and simply playing what the signal is the problem has to be with the satalight reciever
Posted on Feb 07, 2008
I have a Curtis 24 inch Full HD LCD TV 2425A never used Trying to set it up and their was no book in the box it says to run Channel Auto scan .it is hooked up to Dish satelite ant. .to run the auto...
Used the tv remote go into tv Menu goto SETUP go down Ch. enter pick CABLE and enter again.Tv now will go into auto scanning for CABLE channels.After the auto scan done for the CABLE channels are finish.After this u will able to go to channel 60 to used the dish remote.
Apr 24, 2011 | Curtis Televison & Video
Hi, my Phillips was hooked up and working fine directly to the DISH receiver using the HDMI 1. I moved and had to put the DISH receiver in another room and ran a coax cable to where the TV is now using...
Hey murphypat321,
Sounds like the TV may need to be on ch 73 cable rather than 60 air. Try switching the TV to 73, if it goes to 69 then put back on 60, if goes to 73 good. Once you have that set go to your TV1 and bring up the menu. Go to System Setup (6) -> Installation (1) -> Modulator Setup (5) and change the TV2 setup to either cable if on 73 or air if on 60 and the picture should come in if everything's hooked up.
Hope that helped! You can email me at thomas.faust@dishnetwork.com if the problem persists.
Tommy Faust
DISH Network
Mar 09, 2011 | Philips 42PFL5332D 42 in. LCD Television
Vizio tv seems to have trouble with volume certain ch fox and ch 8 need to increase volume a lot also goes black loses sound g Have dishnetWork does true sound have to be off
It would be our pleasure in assisting you with that. We would recommend using our Volume Leveling feature which is available on our ViP222k, ViP612, ViP722k, and ViP922 receivers. Volume Leveling keeps the volume levels consistent between programming and commercials and prevents drastic volume level changes when watching television between HD and SD channels. Start by pressing the "Menu" button then pressing 6 for "System Setup" then 7 for "Audio Output". Select "Enable" below "Volume Leveling" then select "Done" to save these settings. If you're using a ViP922 receiver from the main menu select "Settings", select "Audio Output", and then enable Volume Leveling. This should help with the volume fluctuation issue you have been having. Thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Oct 25, 2010 | Vizio L37 Television
We move the tv from living room to bed room and we have to change the chanel from 3 to 60 to get the tv to work on dish network, we try to change from 3 to 60 we try evereything whit no result, we call...
Rescan all the channels?Hook the tv and the satalite signal cable in the tv and dish network box correctly check?Go to tv menu.Goto SETUP,pick CH. pick option CABLE enter to rescan all channels.This should have all the channels,belong to the package u order.
Sep 04, 2010 | Televison & Video
I HAVE DISH NETWORK HOOKED UP IN LIVING ROOM, I WOULD LIKE TO ADD IT IN BEDROOM OFF OF THE SAME RECIEVER. I USED A SPLITTER, THE PICTURE IN LIVING ROOM IS CLEAR, BUT REALLY FUZZY IN BEDROOM. I KNOW THEY...
You will need to split the signal with a 900mgz splitter between the living room and other room. if your pic is fuzzy you have a bad splitter or bad cable, try replacing these one at a time and it should clear up. If your getting a sat pic but ti is fuzzy its for sure in the line somewhere fro teh splitter.
Nov 16, 2009 | DISH Network ViP 612
I have a 20 inch sanyo hd digital hooked up as a second tv on dish network receiver. I had to unhook it temp and when I hooked it back up, no picture. I tried channel scan and nothing. How can I get the tv...
bring the tv out to the main tv and hook it up to that connection to determine if it's the TV or the connection. Or try hooking up a VCR to the tv while the TV is set to CH 3. Do you get a blank picture or a snowy Picture?
Sep 20, 2009 | Sanyo Televison & Video
Blurry Sanyo TV
Well after playing around with the tv some more, I decided the problem was probably the cable jack, and tried running the video in/out cables thru the VCR to get around this, which I read generally works but in this case nothing. I had tried the tv on various settings, anytime I put the tv in "video" mode I'd get a blue screen and nothing else. Anyway I found a switch in the back of the Direct Tv box for ch. 3 & 4 settings. So I flipped it but still got a snowy picture, only this time it was on ch 4 instead of ch 3. By sheer accident I put the tv back in video mode while I had the satilites setting to ch 4, and the picture came up crystal clear. Since I didn't mess with it further, I'm not sure if it was the channel selector or the fact that hooked the tv up via the video cables, but whatever it was it did the trick.
I just KNEW this could not be a broken tv despite the fact that everhwere I read online suggested it was. I knew pictures can go out, or sound can go out....but to have BOTH go out didn't make sense to me. Anyway, glad its working! :)
Jun 15, 2008 | Televison & Video
Audiovox 9'' drop down tv with poor sound
You need to go to cable instead of air and search for channel
Feb 07, 2008 | Audiovox VE920 9" ULTRA-SLIM DROP-DOWN LCD...
Sound won't play thru stereo from t.v.
take the main tv digital opti outto sterio ok on ch or from dish box to sterio on a ch
Feb 02, 2008 | Onkyo TX-SR605 Receiver
Audiovox VE920 9" ULTRA-SLIM DROP-DOWN LCD TV WITH DVD&SPEAKERPHONE Television Logo
65 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
