Question about Eiki LC-SD15 SVGA LCD Projector Multimedia Projector
Bulb Life How long should a bulb last on the Eiki LC-SD15? We have one projector that we have only had one year and the bulb light is blinking to replace. Is it better to turn off the projector after each class or leave it on during the day?
  • 2,336 Answers
The bulb should last for about 2500 hours as per the manufacturers.
Try resetting the timer even without replacing the light bulb. Check page # 49 of the PDF file on how is done.
http://www.aboutprojectors.com/pdf/eiki-lc-sd15-manual.pdf
I would suggest to turn the projector OFF when not in use.
Good Luck.
Posted on Feb 07, 2008
  • 115 Answers
This is 2000 Hours, 160 Watts, UHP lamp. dont keep it on always.Check the usage and then replace the lamp. It's better to turn off the projector after each class.
The lamp is around $400.00 for Eiki LC-SD15.
Viren
Rave Services India
How can I find the bulb life remaining?
1,turn on the projector
2,press and holding down "UP" for 20 seconds,
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Mar 05, 2014 | Eiki LC-XB28 XGA LCD Projector Multimedia...
Yellow circle
burned in lcd panel, which will need to replace the complete optical block with 3 panels and polarisers, which is costly !!
Sep 27, 2011 | Eiki LC-SD15 SVGA LCD Projector Multimedia...
Eiki lc-sd15 has no power. The lights do not come on when plugged in and nothing works.
near the lamp door is a small hole with a resetable thermal fuse under it, try to push pin carefully
Jan 18, 2011 | Eiki LC-SD15 SVGA LCD Projector Multimedia...
Can't find a reseasonable price for eiki replacement lamp lc sd15 6103177038
That is a Sanyo type lamp. Try searching ebay, there are several dealers that sell through there and ebay will search in price order for you.
Hope that helps
Dec 09, 2010 | Eiki LC-SD15 SVGA LCD Projector Multimedia...
Bulb won't work
If you are sure that you installed the new bulb correctly , then I recommend that you reset your projector . Some projectors don't realize that you changed the bulb physically until you reset them .
please rate !
Apr 14, 2010 | Eiki LC X986 Multimedia Projector
Our Eiki LC-986 projector has worked flawlessly for at least 3 years. Last week, the projector shut itself down after approximately 30 minutes of use. This happened at least 5 times, so we replaced the...
It sounds like it is overheating. Are the fans all working? If so, try opening the casing and blowing all the dust out with a can of air from Staples/Office Depot. If the fans aren't working you may need to replace them.
Jun 15, 2009 | Eiki LC X986 Multimedia Projector
Have a number of same model projectors lc-sd15 stop working .
Are you a UK school district? the thermal trip has been a problem on sevral makes of projectors including Sanyo, your problem now may be lamps what hrs do you have on the lamps?
Marc Engineer
Apr 06, 2009 | Eiki LC-SD15 SVGA LCD Projector Multimedia...
Projector stays on for a while then shuts down
Two things that usually gives this symptom. One, internal heat sensor will shut down projector if extreme heat is present, usually caused by dirty filters, fan failure, etc. Two, your bulb has reached its life end.
Feb 02, 2009 | Eiki LC-XG210 Projector Multimedia...
Eiki LC-SD15 SVGA LCD Projector Multimedia Projector Logo
223 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
neOen
Level 1 Expert
Jaime Hernandez
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
