Question about Vacuums
Vacuum smells I have a 6 year old rainbow vacuum model E and it smells terrible everytime I use it. Probably because often times i don't remove the water basin after vacuuming and just let it sit. It's my own fault however now I don't know what to do to get rid of this terrible smell. I've water cleaned the hepa filter, not able to remove the separator screw to clean. Can you give me some suggestions?
In addition to vinegar, baking soda (sodium bicarbonate) is also an excellent remedy for many odour problems.
Try generously sprinkling baking soda on a rug you wish to clean, and afterwards, vacuum up the spot.
Rugs, and dirt may be broomed beforehand, and you may want to spread the soda over a large enough area to avoid having a small "clean spot".
Repeat as necessary, and buy the bigger boxes of baking/washing soda. It has many more great uses that you can discover.
Posted on Apr 04, 2008
  • 552 Answers
My wife happens to have a rainbow that I picked up at an auction for $2.00.
When it begins to smell, we use a quarter cup of vinagar in with the water and use as usual.
You may not apprectiate the smell of vinagar, believe me, it works.
It may take a couple of vacuum sessions and changing of the vinager water each time, but one good thing about vinagar, it is an old time disinfectant.
Posted on Feb 07, 2008
How do I replace the fuse on a rainbow vaccum?
The D4 model Rainbow has a Thermal Cut Off
This has to be manually replaced. It is attached to the Field 120v D4
If this has blown, then most likely something is causing. The Armature Tall 120v D4 could be going bad.
You can also speak with our technical support team Contact Us
RainVac
Jan 27, 2016 | Rainbow D4se Classic Canister Vacuum...
I bought my rainbow se vacum 4 years ago and I was using it and suddendly stoped working, I try to on no power I on and off not working at all. what shall i do is there posibility to work again.pls.help...
Hi, there is no reset button on a Rainbow vacuum.
All SE series vacuums have a built in thermal and load fuse on the motor, and if it blew, it has to be replaced, or wired directly, with out it on there.
Motor brushes are usually the source of a non working Rainbow D4 and SE and all model Rainbow vacuums and when they burn out, they usually take the motor armature with them, from excessive heat and flare electrical arking to the armature. It is probably the thermal and load fuse, that is your problem, if you did not smell any electric burning type of smell, before it quit. It could be the power switch, but not as likely as the fuse. If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Feb 13, 2010 | Rainbow 75th Anniversary Canister Vacuum
My e series rainbow smells very badly... my teenager often leaves the water in for days and that nasty smell has saturated the sweeper itself. How do I get the smell out
You should always put a new hepa filter in any E and E2 series Rainbow vacuum, when it taken to a new home, or every two Years, or so, or if your Doughter makes it get funky smelling. :-) It will smell like the home that it was in, or how ever it smells, until you do.
You can also use fragrances, and deodorizer air freshener in your vacuum, which not only eliminates odors, it add fresh aromas to your air that you breath, in your home, also.
Replace the hepa filter first thing.
The water separator is the thing that spins in the center of the motor where your water basin attaches to it. It looks like a cone shaped fan looking thing. It should be cleaned after every use.
Use your Rainbow separator cleaning brush, or a tooth brush, if you do not have the Rainbow one. They are just like tooth brushes.
Never store your Rainbow canister on your water basin, with or without water in it. It can and will ruin your vacuum in dew time.
You can get manuals either here,
http://www.rainbowsystem.com/ or here,
http://www.rainvac.com
Thank you,
Ralph
Jan 05, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow stops shortly after starting to vacuum
There is a thermal fuse on the motor field that sometimes fails. Sometimes the fuse does what it is supposed to do - prevents motor from overheating.
Causes:
a) Improperly worn motor brushes
b) bad motor bearings (that usually leads to uneven motor brush wear)
c) very dirty cooling air filter
To access filter and the motor - use small flat screwdriver to remove clear side panels. You will see 4 or 6 Phillips screws. Remove screws - cap will come off.
Good Luck,
Rocky
Mar 17, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow Vacuum smells like something is burning.
When it is running look on top of unit to see if there is any flashing from the brushes, if your unit has been getting pretty hot on top, it would probably be motor brushes. These are not very expenseive to replace and by doing so you will have your unit for so many more years.
Dec 31, 2008 | Rainbow 75th Anniversary Canister Vacuum
Rainbow E series
The belt looses it tensile strength (tightness) over time. But it's the part about funny sounds and shutting down that concerns me. If it smells like a tire fire then it's the belt if it smells like plastic and burned hair then the motor has a bad field or armature. Probably one of the carbon brushes got hung up and burned a segment in the armature.
Oct 02, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow SE makes Squealing Noise when switching it On/Off
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=528929
Rainbow SE makes Squealing Noise when switching it...
Posted by ray_s51 on Apr 20, 2008
My Rainbow SE works and runs strong but when I switch it on and off for approx. 20 to 30 seconds the motor makes a loud squealing noise. Do I need to oil something or what? Nothing smells, it does not make the noise all the time, but it does more often than not. Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum.
The Rainbow has 3 fans in the bottom of the motor and if they are weak they will make noise from the motor unit. Watch out… the repair of the Rainbow may exceed the cost of a new motor of which will solve your problem of noise and separator --- compare the cost and the labor and make a decision. The separator is part of the armature, the separator should be able to be removed and that might be one of the things making noise. As normal maintenance the separator should be removed and cleaned after every use and re-installed, then place a newspaper or towel under the motor unit and turn on the Rainbow and spin the moisture out of the motor unit. This should be done every time you use it. If you have further questions please feel free to contact your local vacuum cleaner dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Apr 20, 2008 | Rainbow E series Canister Wet/Dry Vacuum
How do I remove the pin on my Rainbow Vacuum Model SE clips?
When I used to repair Rainbow SE vacuums for a living, I had a long nail of small diameter that I had filed the end off of just for this purpose. The pin you need to remove is grooved on each end to "catch" in the plastic housing, but a slight tap with a hammer, using this "nail" will do the trick. When you're ready to re-attach it, just tap it again to put it back in place.
Apr 04, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Brush Repair Question
Could be that is the case if it is a plastic smell, and the brush roll is loud when turning. Depending on which model you have, either have to replace the nozzle or if the brush roll sits in a removeable tray, you can replace it. If you take it in for service, it will probably run $80+ parts and labor.
Mar 02, 2008 | Vacuums
Vacuums Logo
431 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
