Question about Toshiba 57H82 57" Rear Projection Television
Toshiba 57h82 model tv
Im having fuzzy wavy lines on my screen and a white vertical line bouncing around. waht could be the problen i see others saying it could be the caps on the hyper board if thats the problem how many do i need to change and how would i get the hyper board out?
  • tonia walker Feb 07, 2008
    i tryed to send you a video but it wont let me
    President:
  • 4,402 Answers
Can you post a picture?
Posted on Feb 07, 2008
  • Cary Farah
    Cary Farah Feb 08, 2008
    it has to be a pic.
I have a Toshiba 57H82 rear projection tv. It has colored wavy lines on the screen and no picture.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 19, 2011 | Toshiba 57H82 57" Rear Projection...
About two months ago when we first turned on the TV there were wavy lines across the whole picture. When it warmed up they would go away. Now, the lines are there almost all the time and it's getting...
hi
You are experiencing a lack of vertical deflection or vertical collapse. Since it will come back the first thing I would suspect is “ring cracks” in the solder joint in the vertical circuit, mainly the vertical IC. These suspect solder joint can be re-soldered and the television set repaired.
I would suggest that you contact a local servicer. If you are repairing the set yourself, be careful, there is always a risk of shock when dealing with electronics.
OR
Check your equipment connections. Disconnect your equipment (VCR, DVD or set-top box) from the TV and reconnect, making sure each connection is in tight.
OR
chek this site,i blieve u will b helpfull
http://www.dshosu.com/how-to-fix-toshiba-rear-projection-hdtv-wavy-lines/
regards
Jul 01, 2009 | Toshiba 57H82 57" Rear Projection...
Toshiba 57H82- Distortions on the picture screen
You have leky caps in your regulated power
supply they are typ 220 uf 200v and are large
and round next to flyback
Jun 23, 2009 | Toshiba 57H82 57" Rear Projection...
Screen blank except for horizontal flat line - sound ok
YOUR TV WAS ASSEMBLED IN LEBANON TENNESSEE THERE IS A NATIONAL SERVICE DEPTMENT AT THE FACILITY.1-615-444-8501
Mar 03, 2009 | Toshiba 57H82 57" Rear Projection...
How to fix fuzzy pic & red,blue,green lines on your screen?
Typically this is due to a convergence chip failure. This repair can be done pretty easy with the proper instruction. Have a look at this video to help determine if you truly have a convergence problem.
Jan 26, 2009 | Toshiba 57H82 57" Rear Projection...
Picture all distorted cold warms up ok
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 06, 2008 | Toshiba 57H82 57" Rear Projection...
Toshiba 50H82 Wavy Lines - Jittery Picture.
Dont have the manual - sorry - but this is the most likely cause.
Projection TV sets have two very common problems listed below.
*Screen Looks 3-D
*Colors wont align
Nov 11, 2008 | Toshiba 50H82 50" Rear Projection...
White lines on screen
im sorry my friend I do not understand what a funny marrior is? LOL If your complaining about white lines at only the top of the picture, then I would say that your problem is with the vertical sweep circuit. Most likly a capacitor in the vertical preamp really small ones next to the jungle IC or the capacitors that are used as waveshapers in the vertical drive and output. If the entire screen is white lines then the screen drive is too high so back it down till the lines just disapear. if that wont turn down, theres a filter cap on the sweeop supply or the CRT socket board is bad. Good Luck
Oct 08, 2006 | Toshiba 32HFX71 32" TV
Toshiba 57H82 57" Rear Projection Television Logo
186 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
