Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Samsung 42 inch projection
When you turn it on the light around the power button blinks 10 times with 6 and 7 being a bit longer. Then it shuts off.
Would love some thoughts?
    President:
  • 4,402 Answers
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Posted on Feb 07, 2008
My Sony wega tv won't turn on goes into standby red light blinks 10 times then shuts off?
Look at the owner manual as the 10 blinks is a error code or Google the model number to locate that information--Sony error codes are general and often misleading.
I would if looking at the set inspect the lamp first.
Aug 28, 2012 | Sony Grand WEGA KDF-42WE655 42" Rear...
Panasonic 42 inch plasma wont turn on. red light blinks 10 times
I unpluged mine and the light was still blinking when it was unpluged. I thought that was weird. So I pluged it back in and just heald the power button in untill the light went out. It went out within ten seconds. I pushed the power button again and the tv went on. WOOHOO!!! Just needed reset, I guess.
Dec 10, 2011 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
MY TV HAS NO POWER I CHECKED THE FUSE IT SEEMS
hello have you checked the glass fuse inside the tv it will be in the power supply beware if replace the and blows again the you have a dead short circuit
regards
shaun
Apr 09, 2010 | Samsung HCN4226W 42" Rear Projection...
Panasonic PT-51HX41 51 inch
the blinking power indicator is actually a error code. How many times does it blink as I can assist you if you let me know how many times the led blinks
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
TV turns off and power light blinks unpluged andd still does it.
Likely to be the STK convergence chips causing a protection circuit to switch the TV off. Have you got any onscreen convergence problems (i.e, colour fringes)?
May 27, 2009 | Toshiba 42H81 42" Rear Projection...
No picture.
Could be a number of things. Check Q423, Q431, R449 also check all your supply voltage legs to see if any are shorted or loaded down.
Jun 24, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung 42" rear projector 1080i
I have the same TV with the same problem. This model have a defective chip, the chip just burnt out. It burnt out on me a bout 2 years ago and it just burnt out on me again last month. It cost me $300 to replace it both times. This model sucks, I will never buy a another Samsung.
Jan 07, 2008 | Samsung PCH521R 52" Rear Projection...
Won't turn on...
It's possible that the convergence IC's may be bad in this set along with a few resistors. A TV repair shop should be able to fix the set for you.
Dec 19, 2006 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
82 people viewed this question
Henry  Thomas
Henry Thomas
