Question about Aiwa CDC-Z127 CD Player
CDs wont play
I noticed my CD player skipping a lot and poor sound quality several months ago. Eventually it quit playing all together. I put a CD in and it attempts to read; it displays 00:00:00: and shows track number 1. I hear some clicks then it displays "E02" and ejects the CD.
I tried to put a lense cleaner in last night, but it wouldn't read that either. It probably didn't spin enough (or at all) to clean the lense.
Radio works fine, and it played burnt and regular cd's all the time. Now it won't play either.
  • Anonymous Oct 26, 2008
    I have the sam problem except mine tells me there isnt a disc insterted.
    i cleaned the bottom lens with contact solution and it solved it.
  • 86 Answers
Archo69..big chance your laser is on its way out..it also can be the bottom lense is dirty to ,but this requires your stereo to be removed .dismantled and cleaned manually
Posted on Feb 08, 2008
Cd skips
my best conclusion would be your player might be copyright protected to the point were you'd be able to hear the music but wouldnt be able to enjoy it.... different player or better quality CD-R's would be your best best. . .
Dec 29, 2012 | Teac AD-800 CD Player
My sony cd player plays most discs but not all? Why?
I have several CD players and I've found some CDs will just not play on some of them. If you have a changer with 300+ discs they are more likely to be fussy than one loaded in a flat tray.
I'd suggest you try playing the CD in another CD player or your computer, if it won't play in them it is the disk. I had one which would not play in any machine, it was a copy I made on a poor quality closeout of blank CDs at Good Guys when they closed, it turned out the blank CDs were of poor quality.
I hope that might help you.
Apr 21, 2012 | Sony Audio Players & Recorders
I bought a Radio Shack cd cleaner (cd w/little brush on it) to clean the lens of the cd player however the machine won't recognize the disc when inserted so I cannot figure out how to "play" it. Many of...
yes here is a simple easy way to get them to stop skipping, stick them in the freezer portion of your fridge, only if the cds have scratches on them, even the smallest scratch can cause a perfectly working cd player to make the cd skip, stick the cd in the freezer for about 15 or 20 mins and pull it out and play it, i have used this method for a lot of my video games as well and have never had to buy any "cd player cleaner cds" i hope this helps
Jul 16, 2010 | Sony CDP-CE575 5-Disc CD Changer
My jensen wont play cds wen it dose it skips
use a common cd/dvd optic cleaner .... they are cheap .. what is going on is your cd player cant find a track so it shuts off ..
Feb 10, 2010 | Jensen Car Audio & Video
CDs skip
Hello
Ok, it sound to me that the laser lens which actually reads the cd's has some dirt particles on it.
There is a very cheap method of solving this problem.
Just go to any cd shop and buy yourself a decent laser lens cleaner disc, follow the instructions and you should be set.
Kind regards
Andrea
Dec 13, 2009 | Technics SL-PD6 5-Disc CD Changer
Hi, i have a 1984 fisher studio standard cd player. when it plays, it sounds excellent and works fine. the machine will play cdr's as well as normal cds. however, some cds it simply will not spin. it...
Thanks for the informative write-up. So few know how to describe a problem (example: it's broke) or have the intuition to check a few things out.
A surviving 1984 CD player? Good for you. And they originally said the lasers would burn out in a few years.
Don't read too much into sound quality and tracking of defects for this problem. It sounds like a load status sensing problem. Does it make the thee clicks when you load no disk or one upside down (to simulate a bad disk)?
You're probably on the right track with the tilt. I suspect you need to locate the sensor that 'sees' the presence of the disk in the first place. Can you try your troubleshooting with the covers off and observe what may be different at the tilted angle?
Nov 07, 2009 | Audio Players & Recorders
5 disk cd player skips or wont play cds
check if you are using a good quality cd's and still you have the problem check if the cd's r clean and out of scratch and in good condition
after this still you have the problem then its the player fault
the lens inside the player must be cleaned
so, use a lens cleaner and clean it and then check it
thank you
Apr 22, 2009 | RCA RS2663 Shelf System
Skipping
i have the same problem there but i no how to solve it....
its not hard just go any buy new good quality cds i found that sony work very well with the axis 9s and when your making new cds from widows media player just turn the burn speed down to med speed an best quality you do this by going on the littel drop down menu underneath burn go to more options then it will say burn speed change to med go onto the bottem slider and put that in the middel an it works like a dream
Feb 09, 2008 | Nu Mark AXIS 9
Skipping
If you go out and buy a cleaning disc it may help. You should really clean a car cd player at least ounce or twice every 6 months to get the best sound and play out of the unit. You can pick these disc up at any walmart , kmart , or computer store. Hopefully this can help you out
Dec 18, 2007 | Kenwood KDC-MP228 CD Player
Lens Knocking Against The CD - All CDs skip or diginoise then fail.
Take the small back cover off and take some electrical grade contact cleaner and spray all around the lens area, that worked for me.
Mike
Jul 29, 2007 | Sony CDP-CX400 400-Disc CD Changer
Aiwa CDC-Z127 CD Player Logo
211 people viewed this question
Top Aiwa Car Audio & Video Experts
fordexpert
Andrew Taylor
Andrew Taylor
Are you an Aiwa Car Audio and Video Expert? Answer questions, earn points and help others
