When we turn it on red flashing lights appear can u help.
system error is the problem
Depends on how many red lights are flashing...
if you have 3 flashing red lights your machine has a hardware failure which means unfortuanatly your beloved is dead. in which case take it back to the shop and demand a new one. this is a very common problem.
if its only one red light the problem is your av/component cables are not connected correctly....good luck
SOURCE: xbox 360 1 red light
E64: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc.
If your system is underwarranty i would take it back to get a new one if not you will have to call MS and see what it will cost you to get it fixed.
SOURCE: 1 red light problem
hi, it sounds like a case for microsoft. but a word of advice. you can upgrade your warranty first if it has run then phone them up a week or two later to say your system has developed a fault but i didnt tell you this. ha
SOURCE: Xbox F73 Fault
E73: I/O Hardware Error - Couldn't calibrate HSIO Bus from edram: this error is likely caused by a problem with the Ethernet port or supporting control devices
SOURCE: red light blinking system error E74
this might be a hardware failure. try turning it off then back, or try keeping a fan on it when you play on and if that doesn't work call 1800myxbox there you'll find step by step instructions to send it down to texas and get it fixed. if that happens three times you will recieve a brand new xbox 360 that has that problem fixed. also keep in mind to keep your hard drive before you send it to be fixed. i really hope this helps with your problem
-good luck
Red Ring of Death: Red Flashing XBOX 360 Lights Explained
Common Xbox 360 Red Ring Errors
The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error,
follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
XBOX 360 Red Light error, or Red ring of Death RORD is a
very common issue, and can happen anytime.
There are different Error numbers related to RoRD, and appears on screen
starting with "E".
Red light problem can be fixed! there is a XBOX 360 repair
guide available that covers this problem and also all other common XBOX
problems. You can get your copy XBOX 360 Repair Guide, you can download it and
get help to fix your console. Please feel free to message me if you need
further assistance
click here to download.....................
I have three red lights flashing? I bought this from a local dealer not directly from microsoft? What can I do to get this fixed?
