I have this system and when it works it works well. However, I am
having some strange problems with it that I cannt seem to be able to
identify. One is that it will not turn off. When I
hit power off it comes back on within a few seconds. It
doesn't turn on the music, but the display sayd HELLO and all the
lights flash. It does not play a cd or the turner if it is in that
mode, but it is on.
The other problem I have is that it seems to not want toplasy certain
CDs. Some of them play fine and others skip. I thought
maybe the CD was damaged, but I see it even happens on brand new
CD's I tried using a lazer cleaner, but that didn't help.
What could these problelms be and can they be fixed? If so, where can I send it to be fixed?
Comment by JanPre, posted on Feb 09, 2008
I think the not shutting off problem was due to a power hit we had during an electrical storm, even though I had a surge protector on it. ...either that or it's haunted. Thats a running joke in our house now. The thing is haunted and mocking us when it turns itself back on.
Comment by JanPre, posted on Feb 11, 2008
On the laser reading issue. Many times a cleaner will not do the job. You need to open the unit up and clean it with a q-tip and alcohol. If that does not do the job then the laser has gotten weak and needs to be touched up. If you know how to use a meter and are comfortable on opening up the unit I could help you further on this. If you are not then you will need to take it to a reputable repair shop.
Comment by Crossedwires, posted on Feb 11, 2008
if it is the unit then A reputable shop should be able to do this job for no more than 60.00 We would have done it for about 50.00 That should give you an idea of what to be expecting. Ask them thier labor rates up front. You may also want to check with the manu and see if they have an authorized repair shop in your area. Also ask others who have used them to be sure they have a good rep.
Other than that GOOD LUCK TO YOU!
Was this solution helpful? Show your Appreciation by rating it:
Post a New problem for Audio Shelf Systems
Email this problem
Can you Help with these Audio Shelf Systems problems?
Looking for a standalone DAC,...
GE Slim Spacemaker Stero CD...
Cambridge Sound Works radio/cd...
cd will not play
