Problem with panasonic tv
Turnd off himself when i turn on...
  • bezawit Feb 07, 2008
    panasonic TX-28EX4F
  • 2,322 Answers
It will help us more if you provide more specific info on the model of TV and chassis number.
It looks like the TV is going into shutdown mode base on the info you have provided.
If the TV is goes into shutdown mode, most likely you should have a technician to fix it.
Posted on Feb 07, 2008
    Sergeant:
    Champion:
  • 226 Answers
The circuit board was overheated. then some of the componets was burnt or loose. when you open the case look for the capacitors and resistor that have blown you can easily find the one that has been damaged. the capacitor pops up when blown. go to your techniciah to replace that for you.
  • 983 Answers
May due to power variation the transformer is got damaged or power supply wire has got damaged ....
or
may be transformer has got heated fully and it is out...
or
may be the tube is gone....
or may be due to power variation the short circuit might have been occurred and the circuit board has got cracked....
solution : visit the tv technician and discuss problem....
Ferguson TV help? Can't get the TV to turn on.
sounds like it is stuck on stand by,with out the remote i dont think you will get it to turn on,when mine done it i just turnd it on and off a couple of times by the mains mine came back on.
might work.
Aug 12, 2015 | Televison & Video
How do i get the lines out of a 2005 toshiba tv model #51hc85
somthing is turnd up to high could be the contrast or brightness or the ht needs turning down the ht would have to be done by some one that knows about tvs.
Apr 13, 2015 | Toshiba Televison & Video
Was watching my 40 inch emerson it turnd off and wont start
You have a typical symptom of power supply failure in flat panel TVs
Apr 03, 2013 | Emerson 40" Lc401em2 1080p 60hz Flat Panel...
Screen went blue
Check the input or source button to see where you currently are.
Nov 03, 2012 | Sceptre X370BV-HD TV
I have an sony 32"lcd .the picture turnd into
Sometimes this is caused by a bad connection between the lcd and the lcd driver board. Unplug this cable and plug it again firmly.
Hope this helps!
Apr 07, 2011 | Sony Bravia KDL-32V4000 32 in. LCD TV
Tv turnd on then off after a few seconds and has no picture or sound power light flashes
hello this case could be the lamp so you have to go in the back of the tv and open the little door and pull out the enclosure with the lamp remove the lamp from the enclosure and give us a call 1800-281-8860 our you can visit the web site http://www.discount-merchant.com and maybe you are asking your self how can I know what type of lamp I need check on the enclosure and see the numbers that this part has so those ones are the correct ones if you want to see more information of this you can go to fixyoudlp.com and over there we have the links fo the videos how to change a lamp and many more videos from tv parts.
Regards
Said
Dec 17, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Grainy apperance when HDMI components turnd on
HDMI cable change its sub standard.
Jul 08, 2009 | Televison & Video
Tv turnd off
Your mainboard is damaged, replace it and that will solve your issue.
Jun 06, 2009 | Philips 50PFP5332D 50 in. Plasma...
Why is my tv only red when turnd on
If you have no audio or video take a look at the repair kits here.
www.magnavoxhelp.com
Jun 26, 2008 | Televison & Video
Sansui tmv1916 tv no pic
have a sansui tv with a date of sept 2002 i bought the tv because it was on sale and have since lost the reciepts. anyways , no i need the tv and when powered up there is no picture but the sound comes on fine. i turnd it upside down and beat it and shook it and the pic came on for a min only to turn back off in 5-6 minutes. help. oh and i dont have electrical or circuit knowledge but willing to change a bulb or fuse. as you say that sound is ok and picture also comes some time so please check loose contact in luminance section of chroma ic . weak signal may cause rolling and intermittant picture problem for that checkloose near antena socket thanks
Sep 10, 2007 | Sansui TVM1916 19" TV
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Electro Med Services...
