Back to:
Tags:
Panasonic SC-AK500 CD Shelf System
Error Code F61 (by 4 users)
posted by feedom on Feb 07, 2008
Help! What specifically can I replace to see if it's faulty?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by Guest, posted on Aug 03, 2008
that F61 pops up every time i try to turn on my stereo what do i do?
Comment by CMax53, posted on Apr 07, 2008
F61.........the stereo turns on long enough to show the error code then shuts down
Comment by herbnspice, posted on Mar 11, 2008
The set was on & it suddenly stopped there was somewhat of a popping sound. then the unit was turned on again it came on ,but the sound as though something is frying. then the volume became low.
Solution #1
posted on Mar 04, 2008
Not Rated (0)
imiboy
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
You can't do much with this the AMP is dead. you need to replace it. it could cost alot.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Error Code F61:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Guest
Rating: 0%, 0 votes
The AMP is dead you
Thank You!
Can you Help with these Audio Shelf Systems problems?
Audio Shelf Systems
i need firmware for mp4 playbox pb-415.Thank you I NEED A...
Audio Shelf Systems
no longer plays cd's or cassettes( I know, it's old, so am...
Audio Shelf Systems
Looking for manual and where I could purchase a remote...
When the remote stopped working I sent away to Panasonic...
When a homemade CD is inserted, the player does not read...
Loading problems.
Repair Service
Find Audio Shelf System Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
