Question about Canon NP 6050 Copier
Nothing is copying
The copier just stopped producing copies. It now is displaying an error of E532. Is this an easy fix or does it require a repair technician?
  • Diane Cangemi Feb 08, 2008
    You guys are wonderful! It did have a jammed staple. Although we never use the stapler, the solution worked. Thanks!
  • Canon Expert
  • 1,326 Answers
E532 is a sorter problem. Have you replaced the staples recently? If so try to remove any jamed staples from the stable cartride and try to reinstall as shown on the inside of the soter front door. You can also try to turn the copier off and unplug the sorter and reattach it and turn on the power. See what happens, if that does not work and you don't really use the sorter, unplug it and detach it from the copier and make a exit tray and there you go. If you do use it call for service.
Posted on Feb 08, 2008
Copy and Scanner not responding
Copier may require you use the scan feature to make copies either ise the feeder otr flatbed. Press start on machine for manual entry but still use scan to get things working.
Nov 15, 2013 | HP HEWLETT-PACKARD CN583A Officejet 6700...
While copying, system error E007 appears and machine stops immediately. As machine stops copying paper also get stuck.
E007 Fixing film rotation error
Inspect fixing film for damages
Main Cause/Symptom: Fixing film sensor failure
Countermeasure:
- Check the connector of the fixing film sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
Feb 02, 2011 | Canon iR 2016i Black and White Copier
Cant get my canon mx330 printer to work
Multifunction devices usually require two separate inks to acquire functionalities. For example, an empty ink cartridge especially the color ink may still produce copies without multi ink features. However, any attempts to dismaunt the ink cartridges would require restorations from the computer settings. First, inspect the printer for empty accessories that require replacements. After acquiring and replacing ink cartridges makes way for the next processes. Second, connecting the printer that has been restablished would produce display results requesting printer copy allignments. Attempt to print a document to produce the results for alligments. Goodluck
Jan 12, 2011 | Canon PIXMA MX330 Multifunction InkJet...
The problem issue the photocopy machine canon ir2016j was printed copy any more for example i want copy 20,out side within copy 20 i want 10 wen i stop the machine copy will contine to operate so please...
The procedure for stop copy is you press red and then machine ask you left or right pointer for yes or no.Is thath way did you stop copying?
If yes it may be machine system problem.
Mar 02, 2010 | Canon imageRUNNER 1023iF Black and White...
Manual feed from upper tray copy produced line
Vertical lines are caused by one of two things. 1. The photosensitive drum in the toner is scratched or the fuser has a problem. Either is an easy fix.
Oct 07, 2009 | HP LaserJet 3330 All-In-One Printer
How to get the copy counter on the display?
Press the stop/reset key, start key
and the left copy exposure adjustment
key in the order presented and hold
them down.
Press the stop/reset key. entering service mode.
Enter the number of the maintenance
item to be executed using the copy
exposure adjustment keys or the zoom
+/- keys
enter 000 start to print staus report.
Do not change any settings...only use 000 to print report, then 001 to exit service mode after it has finished printing.
This is very important so that you dont render your machine useless.
To exit service mode-
Enter 001 using the copy exposure
+/- keys, and press the start key.
Jun 05, 2009 | Kyocera KM-1505 Copier
''Error Code c200''
Drum Charge Corona Wire broken or shorted. Wire will have to be repaired or replaced.
Caution High Voltage.
Mar 31, 2009 | Office Equipment & Supplies
Printing blank pages
open the door and look for a unit that has some small hair like wires, are they intact or is one missing /broken???
Oct 30, 2008 | Canon imageCLASS MF6550 Monochrome Laser...
Very faint copies
You need developer added to your machine. When it is added properly to the toner, your copy quality will improve.
Sep 01, 2008 | Office Equipment & Supplies
Canon NP 6050 Copier Logo
172 people viewed this question
old marine
old marine
