Question about Universal Remote Control MX-3000 LCD Touchscreen Remote Control
Dynamic Entertainment System MX3000 - Frozen!
The remote recently has stayed lit in the charging cradle and does not change when pressed, not does the TV respond to anything... unplug and replug the battery? My installer is apparently out of business!
  • kdegrace Feb 22, 2008
    I have the same problem that the remote seems to be frozen and I cannot get in touch with the company who installed to help. At first I thought it was a defective battery, but could not find anywhere to purchase a new one. Does anyone have any suggestions as to who can repair and re-program?
  • Ganapathi Hegde Dec 16, 2008
    Can I get their e-mail ID? I also need 2 numbers of PC046067-H.
I have the same problem and phoned Sevenoaks sound and vision 01892 531543. Cost of new battery is approximately 70 pounds + 5 pounds P&P. I have ordered the battery lets see how long it takes them to deliver the product.
Posted on Nov 21, 2008
I have the same problem with my MX3000 entertainment system battery by PowerCell P/NO: PC046067-H. Need a replacement battery.
Posted on Mar 30, 2008
How do I do an automatic code search on a ge unigersal remote control model 24993 - v4
1 manually turn on device(TV, VCR,ect. Be sure batteries are good in remote.
2 press and hold the CODE SEARCH button until the red indicator stays on,then release Code search button.
3 press and release mode button (TV, VCR, ect) the red indicator blinks,then stays lit.
4 press channel up( up to 300 times) until device changes channel. The red indicator blinks,then stays lit.
5 Press the Mute button release to lock in code
Tips if you go pass the code use channeldown when channel change hit the mute button and release it to install code.
Apr 12, 2015 | GE Televison & Video
Dynamic entertainment system mx3000
Get rid of it, and buy a new one. It will be the best.
Oct 17, 2013 | Universal Remote Control MX-3000 LCD...
Mx3000 does not charge when in cradle. nothing
I agree with ceocass, however if you find that the contacts are clean and you have made certain that the charging cradle is plugged in you may simply need to replace the battery.
Please note that the replacement batteries for the MX3000 Universal Remote Control, p/n's Powercard PC046067-H & PC036067V3 have been discontinued.
TheBatteryStore.com now carries an alternative battery, p/n PL056067V3 which is a 2,100 mAh typical capacity battery that can be used as a replacement.
Please confirm that the connector type is the same as your battery prior to placing your order. We only carry this battery with the Version 3 connector which has a built in pressure release tab.
The link for the product page is: http://www.thebatterystore.com/replacementbatteryforuniversalremotemx-300037v2100mahli-ionpolymerrechargeable.aspx
If you have any questions please contact TheBatteryStore.com at sales@thebatterystore.com.
May 27, 2010 | Universal Remote Control MX-3000 LCD...
My screen is frozen in updates. It tells me to press ps button to use my controller. What is this?
Its the very middle button on your playstation remote. If its saying press the ps3 button on your control its possible your ps3 is not frozen but your ps3 remote has just turned off..
Press the very centre button and check the lights on the top of the joypad. Are any lights lit solid? Once the light comes on solid the controller is active. If these do not light youll need to charge your ps3 remote with the usb cable that came with the ps3.
Also if your ps3 remote is lit for number 2, hold down the ps button, very middle for about 5seconds. Should have an option for reassign controllers, select that and put your controller to number 1.
Hope this helps
Apr 20, 2010 | Sony Playstation 3 (PS3) Console
Need TV codes for using the comcast DTA remote
try these codes for broksonic 10236,10463,11911,11938, 10030,11935,11929
Apr 25, 2009 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
MX3000 Battery replacement
My company carries a replacement battery for the MX3000.  The p/n for our replacement is PC036067-(V1 or V3 suffix)  You can reach me via email at sales@thebatterystore.net and I will be happy to help you.
There are three important considerations concerning this battery.
1) Please note that the original version, supplied by Universal Remote p/n PC046067-H for the MX-3000, was discontinued by the battery manufacturer.  The PC046067-H had a typical capacity of 1800 mah.  My company has worked with the manufacturer to provide a replacement that has a typical capacity of 1400 mah but is identical in size to the original although slightly thinner.
2) Universal Remote used two different connectors on the PC046067-H with no deviation of p/n.  We carry our replacement with both connectors (our p/ns use suffix V1 and V3 to differentiate).  V1 is a simple white plug and V3 is different in that it has pressure tab built in.
38ba6a7.jpg V1
e965134.jpg V3
Mar 22, 2009 | Universal Remote Control MX-3000 LCD...
MX3000
Sep 22, 2008 | Universal Remote Control R7G Remote...
Philips magnavox, universal remote
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Apr 23, 2008 | Philips Magnavox MRU1400 Universal remote...
remove the batterys and look for 1 to 4 screw holes. have a thin bladed knife to push in on the seam and to pry open. I start at the battery box side.. once apart you might have 1 or 2 small screws holding the curcit board down and some prongs to . Remove the srews and push the prongs to the side and pull off the board . you will be at the rubber button side. clean as much as possible. notice the inside of the buttons. you can use a pencil to draw on the inside to act as a conductor for the bad buttons that are worn
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Dec 31, 2007 | Universal Remote Control MX-3000 LCD...
what kind of battery does this thing take?
Nov 06, 2007 | Universal Remote Control MX-3000 LCD...
Universal Remote Control MX-3000 LCD Touchscreen Remote Control Logo
1,001 people viewed this question
Top Universal Remote Control Televison & Video Experts
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
