Question about Samsung LE32R41BD 32 in. HD-Ready LCD Television
Lcd tv I have a 32in samsung lcd tv. it has started to freeze and the picture goes into squares and appears to jump. it doesnt loose the picture but it is getting frustrating. do you have any ideas why?
  • LB1510 May 18, 2009
    Similar problem but mine freezes on ITV1, C4, ITV2, ITV3 all other channels are ok.. Have no problems on these stations with an analogue set. I don't seem to be able to make any changes to the setup as this area is 'greyed out'. Any thoughts?
    Problem Solver:
  • 13 Answers
Can you u check in the DTB mode, the signal strength & the number ot errors ??
may be you will have to check your antenna connection. Normally it is due to bad signal.
Posted on Feb 14, 2008
Picture is jumping lg55lb7500
10 Ways To Fix A TV Picture That Jumps Jerks or Skips ...
https://removeandreplace.com/.../10-ways-to-fix-a-tv-picture-that-jumps-jerks-or-skip...
Aug 5, 2016 - QUESTION: When I watch my TV, the picture sometimes jumps. How do I test it to see if it's the TV or another issue? If your TV picture is jumping while watching cable, satellite, or streaming, there are a few things you can check. See below for the best solutions to fix a TV where the picture seems to "jump" or ... Missing: lg55lb7500
Picture jumps every few seconds. - Forums - CNET
https://www.cnet.com/forums/discussions/picture-jumps-every-few-seconds-375282/ Dec 26, 2009 - 5 posts - ‎2 authors
I have a Samsung LN -T4061F model I bought two years ago. Over the past two days I have noticed that the TV picture jumps every few seconds. In the trouble sho... Picture Issue on my Samsung Television/Blu-Ray
23 Aug 2010
Samsung UN55C8000 Jumping images
7 Apr 2010
More results from www.cnet.com
Missing: lg55lb7500
How to Stop Jitter on a LCD TV ' Techwalla.com
https://www.techwalla.com/articles/how-to-stop-jitter-on-a-lcd-tv Mar 31, 2015 - When using an LCD television you may notice occasionally that the picture jitters, or jumps down the screen. This makes watching the set rather disorienting and may even cause headaches. Fortunately, there are a few troubleshooting steps you can take to correct the jittery picture issue before calling on a ... Missing: lg55lb7500
Picture jumping - The eBay Community
https://community.ebay.com/t5/Technical-Issues/Picture-jumping/td-p/26963824 In the last few days, when I have been viewing photos/pictures in a seller's listing, they have been flickering and jumping until I viewed the.Missing: lg55lb7500
Feb 21, 2018 | Televison & Video
No picture black and white lines on samsung lcd 32in 450
Sounds like a T'Con fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Defective screen-shots to LCD TVs are given. You can see and confirm the fault to your TV.
Apr 02, 2014 | Samsung LN-S4051D 40 in. LCD Television
Picture jumps
Sounds like a fault with the connection to its T'Con board to display panel. Check for any loose contact at the both ends of connection sockets to LVDS cable. (Low Voltage Differential Signaling) {that involves transferring a signal on a wire and its opposite over a second wire to allow the receiver to reconstruct the signal by difference}. Re-seat all the cables that comes to and goes from the T'Con board once, and check. Contact any service technician. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. http://electronicshelponline.blogspot.com/
Jan 24, 2014 | Samsung LN-T4071F 40 in. LCD HDTV
Baird tv has no picture but sound ok. picture lights up when turning on and off but then goes out.y
Hi Anon,
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
If your TV, flatscreen, or monitor is more than 5 years old it is more like to have suffered a component failure.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Jan 07, 2014 | Vizio GV47LF Television
Samsung ln26a330j1d lcd tv picture freezes or just goes to white screen
BAD CAPACITORS!!!!!!!!!!!!!!!!!!!! FIND'EM
SWOLLEN ON THE TOP!!!!
Nov 14, 2013 | Televison & Video
Picture on Samsung lcd LNT5271F is blurred sometimes lines color distortion double images then goes away and will come back. Part of the screen will go completely lines then come back. Starting to happen...
Had this exact problem diagnosed by a local repair shop as a bad LCD panel. According to the technician there's a loose ribbon cable on the panel and it would cost as much to replace/repair as a new TV.
May 12, 2010 | Samsung LN-T5271F 52 in. LCD Television
Samsung 32in. model no. LE32R73BDXIXEU
is there sound?Does the tv menue display? Likely main board. replace any swolen capacitors on power board first.
Sep 01, 2009 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Normal picture mode make the sharper picture quality but smaller screen apparance
If the broadcast is in 4:3 (square) then either you can have the black bars on the side, or the TV can stretch the image to fill the screen.
Nothing wrong with your set. The broadcast must be in 16:9 to fil the screen.
Aug 07, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Samsung LE32R41BD 32 in. HD-Ready LCD Television Logo
262 people viewed this question
Jerry Greenberg
Jerry Greenberg
